jsnafziger(at)yahoo.com Guest
Posted: Mon Sep 10, 2007 12:54 pm Post subject: Rocker arm & Valve clearance |
I went over the rocker arm & valve clearance per the maintance manual
(task card 247). It states a clearance of 0.3 mm for both valves,
cold.
The clearances on mine (romanian m14p) were mostly 0.3 mm for the
intake valves, but 0.45 mm for the exhaust valves. I set them all at
0.3 mm per the manual, but due to the consistancy of the exhaust
settings, I thought I'd ask if anyone has found a similar thing?
The placard on the nose case states 0.010", but I thought 0.012"
(0.3mm) close enough.
John
http://smallbusiness.yahoo.com/webhosting
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
george(at)gesoco.com Guest
Posted: Mon Sep 10, 2007 1:33 pm Post subject: Rocker arm & Valve clearance |
You are correct. .012 is closer. It is normal for them to ware. We recommend
adjustment at 30 hours from new and then every 100 hrs.
George
