haavard-iversen(at)c2i.ne Guest
Posted: Wed Sep 12, 2007 1:39 pm Post subject: SV: Rocker arm & Valve clearance |
It is 0.3 med mer that is correct for both!
www.yaknorway.com
-----Opprinnelig melding-----
Fra: owner-m14pengines-list-server(at)matronics.com
[mailto:owner-m14pengines-list-server(at)matronics.com] På vegne av John
Nafziger
Sendt: 10. september 2007 22:54
Til: m14pengines-list matronics.com
Emne: Rocker arm & Valve clearance
I went over the rocker arm & valve clearance per the maintance manual
(task card 247). It states a clearance of 0.3 mm for both valves,
cold.
The clearances on mine (romanian m14p) were mostly 0.3 mm for the
intake valves, but 0.45 mm for the exhaust valves. I set them all at
0.3 mm per the manual, but due to the consistancy of the exhaust
settings, I thought I'd ask if anyone has found a similar thing?
The placard on the nose case states 0.010", but I thought 0.012"
(0.3mm) close enough.
John
http://smallbusiness.yahoo.com/webhosting
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
