Alfred Buess
Posted: Thu Feb 16, 2006 11:18 am Post subject: AW: SL-30 |
Vaughn,
In the panel of my XS monowheel I installed aluminum panel fascias of 3
mm thickness. The SL-30 is in the right hand side panel just below the
RMI MicroMonitor tray (about 115 mm below the top of the panel). The
SL-30 tray is mounted flush with the aluminum panel fascia. This mode of
installation gives just enough clearance between the SL-30 wiring and
the firewall. If you want more details, I could send you a picture.
Alfred
Alfred Buess
E-Mail: ykibuess(at)bluewin.ch
Europa XS #097, Monowheel, Foam shortwing, Rotax 912S, Airmaster 332 CS
Sanding, priming, sanding........
-----Ursprngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Vaughn &
Gaye Teegarden
Gesendet: Donnerstag, 16. Februar 2006 13:45
An: europa-list(at)matronics.com
Betreff: SL-30
--> <N914VA(at)starband.net>
I see from my search that a few of you have put a Garmin SL-30 nav/com
in their Europa. I have purchased 0ne, but it appears to be too long to
install in the panel. I haven't cut anything, so I'm looking for someone
to tell me how they did it and where in the panel did they put it.
Thanks in advance.
Vaughn Teegarden, the wiring idiot
XS mono
