gareywittich2000(at)yahoo Guest
Posted: Sun Sep 09, 2007 6:11 pm Post subject: Relays used on Flap / Trim Motor Control |
Greetings:
Does anybody have a recommendation (Mfg, Part No.)
for Relays that they have used to control the
direction of the Flap and Trim (Az & Elev) Motors ???
Thanks, Garey
vft(at)aol.com Guest
Posted: Sun Sep 09, 2007 6:31 pm Post subject: Relays used on Flap / Trim Motor Control |
http://www.aircraftextras.com/
Danny Melnik
F1 #25
Melbourne (FL) Rocket Factory
kcflyrv(at)comcast.net Guest
Posted: Sun Sep 09, 2007 8:08 pm Post subject: Relays used on Flap / Trim Motor Control |
Hello,
I'm in the process of replacing the relay for my elevator trim. The people
at Ray Allen Co. are really helpful. Until recently, mine has been trouble
free for over 5 years and 650 hours. Check there website (at)
http://www.rayallencompany.com/
Ken Cantrell
pbesing(at)yahoo.com Guest
Posted: Sun Sep 09, 2007 8:38 pm Post subject: Relays used on Flap / Trim Motor Control |
Radio Shack sells many. I put a wiring diagram and the p/n is on there too. This is only one way to do it, and is for wiring two sticks on the flap circuit. There are other ways to skin that cat, like wire them so only one works at a time, etc, but this one worked out well for me.
http://lacodeworks.com/besing/flap.htm
Paul Besing
Garey Wittich <gareywittich2000(at)yahoo.com> wrote:
[quote]--> RV-List message posted by: Garey Wittich
Greetings:
Thanks, to amazing places on Yahoo! Travel. [quote][b]
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sun Sep 09, 2007 10:17 pm Post subject: Relays used on Flap / Trim Motor Control |
Nice simple idea but don't hit both the up and down switches together!
You will pop your flap breaker.
Doug Gray
On Sun, 2007-09-09 at 21:38 -0700, Paul Besing wrote:
| Quote: | Radio Shack sells many. I put a wiring diagram and the p/n is on
out well for me.
Paul Besing
Greetings:
ssamps(at)gmail.com Guest
Posted: Sun Sep 09, 2007 11:56 pm Post subject: Relays used on Flap / Trim Motor Control |
The relays I use are these and can be seen at http://211.217.75.113/Promotion/PDF%20CATEGORY/Relays%20&%20Solenoids.pdf go to page 41 and then look for part number 619-760. This is the Farnell catalogue, not RS.
In the USA I think Farnell is called Newark. You will find the same part in all the major catalogues, or B&C if you want to pay a lot more for the same part.
Steve
Posted: Mon Sep 10, 2007 12:05 am Post subject: Relays used on Flap / Trim Motor Control |
Hopefully the other person in the other seat won't have their hand on the stick while you are landing I never had to worry about that, but yes, there are other ways to wire it, but I wanted to keep it simple as I could, and even this was alot of wiring.
Paul Besing
Doug Gray <dgra1233(at)bigpond.net.au> wrote:
[quote]--> RV-List message posted by: Doug Gray
Doug Gray
[quote] Radio Shack sells many. I put a wiring diagram and the p/n is on
like wire Luggage? GPS? Comic books?
