mattreeves(at)yahoo.com Guest
Posted: Sat Sep 08, 2007 4:13 am Post subject: How to check an alternator?? |
Okay, I wired my ammeter backwards and here's what happens.
I start the plane and the ammeter is on the positive side slightly.
I turn on NAV lights, strobe lights, landing lights and the ammeter goes MORE positive and stays there and the voltage goes from 15 to right around 14. Turn off everything, the voltage goes to just under 15 and ammeter goes to zero.
So I don't think my ammeter was wired backwards.
It appears my alternator is charging normally but I think my ammeter needs to see a therapist.
Matt
"Robert L. Nuckolls, III" <nuckollsr(at)cox.net> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III"
At 04:30 AM 9/2/2007 -0700, you wrote:
[quote]Hi Bob !!
Thanks for the help and suggestions !! I really appreciate you and all I
learn from you.
So, I did exactly as you said, and you are 100% correct. I left on a
bunch of stuff for about 10 minutes, then started the plane and
immediately noticed the ammeter was slightly on the negative side, maybe
reading about 4 negative amps. The voltage read just under 15 volts -
say 14.7 the whole time and stays there but within about 3 minutes, the
ammeter came back up to zero and stayed there.
I wired the ammeter and external shunt as per Van's Aircraft instructions
and my brother Danny (which you've all heard from many times) says there
are 2 other ways (according to Dynon) to wire the ammeter which I might do.
I'm not sure of the best or correct way to wire the ammeter [quote][b]
nuckollsr(at)cox.net Guest
Posted: Sat Sep 08, 2007 6:32 am Post subject: How to check an alternator?? |
At 05:12 AM 9/8/2007 -0700, you wrote:
| Quote: | Okay, I wired my ammeter backwards and here's what happens.
goes to zero.
to see a therapist.
Matt
We need to see the schematic as to how your ammeter is wired.
The classic battery ammeter is wired between the bus and the
battery and all loads run from the bus side, all power is fed
to the battery (via alternator) from the bus side. Hence, the
minus-zero-plus ammeter is a indicator of rate of discharge/charge
for the battery. Alternator off and all things on, the ammeter
should show not slightly, but significant discharge left of
zero. Alternator on after starting and then recharging a
taxed battery, the ammeter should show a significant charge
of the battery that subsides with time.
You've consistently used "slightly" to describe ammeter
movement and you've yet to give us words that suggest that
the ammeter is in a position to properly sense and display
the charge/discharge conditions cited above.
This gives rise to two, possibly concurrent conditions:
(1) the ammeter is the wrong size . . . expects to see
much larger currents than your system experiences such
that all indications are "slight" versus "significant".
(2) the ammeter may not be properly positioned in the
system. You need to acquire specifications for the
ammeter and deduce whether or not it is wired per the
instructions that came with it.
Is the ammeter "calibrated"? I.e., does it have the
word AMPS on the front? What is the full scale value
on the face? -30 to +30? -60 to +60? Does this device
have a shunt or just two fat wires that carry all the
current to be monitored?
Peter H
Posted: Sat Sep 08, 2007 1:34 pm Post subject: How to check an alternator?? |
Matt MORE positive under more load = ammeter is wired backwards.
Peter
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Reeves
Sent: Saturday, 8 September 2007 10:12 PM
Subject: Re: AeroElectric-List: How to check an alternator??
Matt
>Hi Bob !!
>learn from you.
>I'm not sure of the best or correct way to wire the ammeter | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234[b]
