fklein(at)orcasonline.com Guest
Posted: Fri Sep 07, 2007 11:17 am Post subject: Tailplane torque tube installation |
I am at the happy stage of preparing to tap home the four drive pins,
attach the washers and cotter pins, and call it good; my goal is to
ensure (or raise the level of probability) that no slop EVER develops
between TP9, the two TP12's, and TP4. The question facing me is whether
or not I should loctite these components together.
I've read the posts of those who have ventured into the tailcone to
deal w/ such slop (or "play") with profound admiration; if I'm ever in
the company of a Europaphile who's done this successfully, everyone
present will enjoy a round of drinks on me.
Since I am installing the 3/8" pins, my sense is that preventing wear
from occurring is the key...hence the notion that loctiting now is
better (and easier) than doing so later. My sense also is that if for
some reason in the future I find the need to remove the torque tube,
warming up the loctite so it will release will be the least of my
problems. Having taken the torque tube to a machine shop to have the
1/4" holes enlarged for the 3/8" pins, I now have a good interference
fit with no play whatsoever.
It appears to me that the best way to apply loctite in this situation
would be to rotate TP9 & TP12 on TP4 away from the holes, dispense the
loctite in the holes of TP9 & TP12 onto the surface of TP4, and then
realign the holes, drive the pins, and "Bob's your uncle".
Mentally, I've run this thru my "min/max regret analysis" and concluded
that this is the thing to do. If anyone thinks this is unwise, please
let me know before I do something stupid! And, if you'd known about
the wear issues of these components when you were at this stage, would
you have used loctite?
Thanks for all responses,
Fred
A194
believed to be clean.
r.collings(at)onetel.net Guest
Posted: Fri Sep 07, 2007 11:53 am Post subject: Tailplane torque tube installation |
Fred Have a word with Roger at E04 [He is in the office Mondays, Wednesdays
& Fridays] before you glue it up for good, the one thing I have learnt
building my Europa is that as soon as you have put something together you
find a compelling reason to take it apart again!
I am putting together a mod at the moment which if accepted replaces the
drive pins with fitted bolts as I don't like the idea of glue .Regards
Richard
Posted: Mon Sep 10, 2007 3:22 pm Post subject: Tailplane torque tube installation |
This just in from E04 on subject topic.
Begin forwarded message:
[quote] From: "Roger Bull" <roger(at)europa-aircraft.com>
Date: Mon Sep 10, 2007 1:29:24 AM US/Pacific
To: "Fred Klein" <fklein(at)orcasonline.com>
Subject: RE: Tailplane torque tube installation
Fred,
We shall probably soon be issuing a Service Bulletin which will
probably
require the TP9 and the two TP12's to be Loctited - however this is
still not finalised with the PFA.
If it goes ahead the preferred Loctite will be 603, which is strong and
which is reasonably oil tolerant. However it goes off very quickly,
and
you wouldn't have time to do it as you suggest below. We have carried
out tests, and the bond is strong enough if the Loctite is introduced
by
capillary action to the components when they are in position.
I suggest you wait until the Bulletin is finalised and published - it
will give enough detail for the method.
Best regards,
Roger
Posted: Mon Sep 10, 2007 9:51 pm Post subject: Tailplane torque tube installation |
Hi! Fred
Sorry but I'm not "your uncle" but I do have a perfect removable fix to
all the problems which doesn't have any doubts about the mixing of glue
and metal components. I have already suffered it the hands of Loctite on
the nose wheel yoke spindle if you remember? It cost me 18 months
flying, thanks but no thanks.
BOB Harrison.
Robt.C.Harrison
