gis-air or x-pak strobe plsu vans fiberglass extensions
vhimsl(at)roadrunner.com
PostPosted: Thu Sep 06, 2007 6:02 pm    Post subject: gis-air or x-pak strobe plsu vans fiberglass extensions Reply with quote
Has anyone tried to use the fiberglass wingtip position/strobe extensions from Vans with the gis-air (x-pak) LED/Strobe system? I am thinking of the LED system as it is $400.00 versus over $700.00 for the whelen non LED one.
I guess I have problems spending $700.00 for 2 strobes and 4 light bulbs.
If so, did it work? Any problems?
Thanks!
Vince H.
Idaho
RV-8 Finish
 Filesize:  15.11 KB
 Viewed:  743 Time(s)
bertrv6(at)gmail.com
PostPosted: Fri Sep 07, 2007 6:54 am    Post subject: gis-air or x-pak strobe plsu vans fiberglass extensions Reply with quote
On 9/6/07, Vince-Himsl <vhimsl(at)roadrunner.com (vhimsl(at)roadrunner.com)> wrote:
Thanks!
Vince H.
Idaho
RV-8 Finish
Vince: installed them on my rv6a. they worked fine...the only thing was Van's sent me to
right side ones, I had to return one so that they would send the correct one.. They said I never
return it etc.. had a big problem with them..I had proof I mailed it back... finally they send the correct one.
Be sure you get one for the left and one for right side, they are not interchangeable...\\
Bert
rv6a
 Filesize:  15.11 KB
 Viewed:  745 Time(s)
