Series 7 POH
dwparker
PostPosted: Wed Sep 05, 2007 5:06 am    Post subject: Series 7 POH Reply with quote
I am nearing completion of my Series 7 and am trying to get all the documentation together for the inspector. I have everything except a POH. I have talked to Kitfox and they do not have one created yet.
What have other Series 7 builders done to satisfy the POH requirement? Is there anyone out there that has one I can buy, beg, borrow, or steal?
Dana Parker
Westport, IN
Float Flyr
PostPosted: Wed Sep 05, 2007 8:31 am    Post subject: Series 7 POH Reply with quote
You may want to check with your DAR on this but I believe as manufacturer of the airplane it is your responsibility to write the POH for your particular airplane.
It doesn't have to be a thick document like the later model Cessna's have. Early super cubs had a POH/Maintenance Manual that was only a few pages.
[img]cid:471332616(at)05092007-06A5[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  591 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
kerrjohna(at)comcast.net
PostPosted: Wed Sep 05, 2007 9:06 am    Post subject: Series 7 POH Reply with quote
rdmac(at)swbell.net
PostPosted: Wed Sep 05, 2007 2:01 pm    Post subject: Series 7 POH Reply with quote
Others may disagree but I do not think a POH is needed to get your aircraft
inspected and a temporary airworthiness certificate issued. I had two
inspectors from the FAA offices in OK City check me out and they never asked
about a POH. You just need to fill out all the FAA forms and make sure they
are worded exactly the same letter for letter word for word.
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
kirkhull(at)kc.rr.com
PostPosted: Wed Sep 05, 2007 4:39 pm    Post subject: Series 7 POH Reply with quote
The purpose of the test phase is to generate the information for the POH.
You cant print the book before you have written the story.
