ELT Installation
Goto page 1, 2  Next
ropermike
PostPosted: Tue Sep 04, 2007 5:31 pm    Post subject: ELT Installation Reply with quote
Hello guys! Once again I come to draw upon your ultimate wisdom. I am getting my Mkll ready for my E-LSA flightworthy inspection. I have ordered an AmeriKing AK-450 ELT. Where is the best place to install it? Thanks in advance....Mike
The next best thing to playing and winning is playing and losing!...Mike Hillger
John H Murphy
PostPosted: Tue Sep 04, 2007 5:45 pm    Post subject: Re: ELT Installation Reply with quote
I have the same ELT. Need the same info. for my Firestar II. I understand the remote is not an option - but a requirement. Not sure if I have enough real estate on my dash.
Richard Pike
PostPosted: Tue Sep 04, 2007 5:53 pm    Post subject: Re: ELT Installation Reply with quote
Here is a picture of the ELT location on the FSII. The remote switch is on the side of the fuselage ahead of the throttle lever, can shoot you a picture tomorrow if you want.
http://www.bcchapel.org/pages/0003/FSII%20Hot%20Box.html
Richard Pike
MKIII N420P (420ldPoops)
a58r(at)verizon.net
PostPosted: Tue Sep 04, 2007 6:01 pm    Post subject: ELT Installation Reply with quote
As a faa-ticketed mech, I have installed a bunch of ELTs in GAs, some
were AKs. The main point is to make certain the box is very securely
bolted/fastened to the airframe...Ty-raps are NG. The box has to
"feel" the sudden stop/crash to get a signal out of it. I bolted or
riveted the mount longitudinally to a primary structure. The panel
control can be mounted most anywhere. Until anyone gets over the leg-
bending, maybe they oughta switch to OFF on landing!
regards,
Bob N. FireFly 070 Old Kolb
ropermike
PostPosted: Tue Sep 04, 2007 6:33 pm    Post subject: Re: ELT Installation Reply with quote
Thanks for the help guys. What is this about a required remote switch? My DAR did not mention this to me.....Thanks, Mike
John H Murphy
PostPosted: Tue Sep 04, 2007 8:03 pm    Post subject: Re: ELT Installation Reply with quote
In regards to the remote. I was told by a DAR that it is required and it must be positioned in an area that can be seen "comfortably" from the PIC seat. I read that to mean the front panel.
lcottrell
PostPosted: Tue Sep 04, 2007 8:48 pm    Post subject: Re: ELT Installation Reply with quote
Here is where I mounted my ELT. I made a bracket to hold it on the top of the tube, butting it up against the front wing attatch bar. This is in a Firestar, and I was just out of room. I mounted the remote on the right side of the nose cone.
Larry C
 Filesize:  72.63 KB
 Viewed:  730 Time(s)
 Filesize:  80.3 KB
 Viewed:  710 Time(s)
Thom Riddle
PostPosted: Wed Sep 05, 2007 2:53 am    Post subject: Re: ELT Installation Reply with quote
I believe, but can't document any regs on this, that if the switch on the ELT is reachable in flight, then a remote is not required. The primary reason for the remote switch is to be able to control it from the pilot's seat and since the vast majority of Standard Category aircraft have the ELTs located as far aft as possible, per recommendations, then a remote switch is a requirement to make it controllable in flight.
Back when I was flying a Cherokee, and the original ELT (located near the tail) went belly up, we had to replace it plus add the remote switch to be legal.
On our Allegro 2000, which is a factory built S-LSA, the ELT is located just behind the pilot/passenger seats and reachable in flight. It has no remote switch and was certificated that way.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
rlaird
PostPosted: Wed Sep 05, 2007 5:26 am    Post subject: ELT Installation Reply with quote
--> Kolb-List message posted by: "ropermike" <ropermike2002(at)yahoo.com>
Hello
advance....Mike
Mike --
In my MkIIIC, I put my AK-450 ELT behind the left seat, mounted on a tube. The remote control was placed, of course, on the panel. The hard parts were the ELT mount, which I had to fabricate, and then a place to put the antenna, which, again, I had to find a place for (I made an aluminum "box" that fits around my large capacitor) and fabricate a mount.
[img]cid:part1.04090207.08040609(at)cavediver.com[/img]
[img]cid:part2.05090003.03040106(at)cavediver.com[/img]
[img]cid:part3.06090405.03070404(at)cavediver.com[/img]
 Filesize:  3.46 KB
 Viewed:  16615 Time(s)
 Filesize:  3.85 KB
 Viewed:  16617 Time(s)
 Filesize:  11.48 KB
 Viewed:  675 Time(s)
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
a58r(at)verizon.net
PostPosted: Wed Sep 05, 2007 9:21 am    Post subject: ELT Installation Reply with quote
Looks good, Larry.
regards,
ropermike
PostPosted: Wed Sep 05, 2007 11:11 am    Post subject: Re: ELT Installation Reply with quote
Thanks Larry and everyone else for the help and pictures. I talked to my DAR this morning and he said if the ELT can be turned on easily from the pilot seat, the remote was not mandentory. I will decide where to mount it when it comes in and go from there...thanks again, Mike
Soon to be "N177RM"
planecrazzzy
PostPosted: Thu Sep 06, 2007 3:00 pm    Post subject: Re: ELT Installation Reply with quote
The Remote , isn't for your convenience.....It so you can
see the "Light" in case the unit was accidently turned on.....
it's supposed to be mounted where you would see it ....
Gotta Fly...
Mike & "Jaz" in MN
 Filesize:  59.84 KB
 Viewed:  698 Time(s)
 Filesize:  60.5 KB
 Viewed:  665 Time(s)
Warning light "on" ( far right )
 Filesize:  59.97 KB
 Viewed:  665 Time(s)
Dennis.Kirby(at)kirtland.
PostPosted: Fri Sep 07, 2007 6:28 am    Post subject: ELT Installation Reply with quote
"ropermike" asked, << my Mkll ... I have ordered an AmeriKing AK-450
ELT. Where is the best place to install it? Thanks in advance....Mike >>
Hi, Mike -
Here's how I did it: For installing a AK-450 in my Mark-III, I attached
it to the side of the six-inch tail boom tube, near the forwardmost end
where it attaches to cage structure. I fabricated a pair of wooden
saddle blocks to interface between the 6" tube and the flat ELT base.
Two large hose clamps hold the setup securely against the boom tube.
Access to the ELT switch is easy, right behind the pilot's seat back.
Dennis Kirby
Mark-III, 912ul
Cedar Crest, NM
ropermike
PostPosted: Sat Sep 08, 2007 9:16 am    Post subject: Re: ELT Installation Reply with quote
Thanks Dennis......I got a nice surprise yesterday when my ELT arrived from aircraft spruce. The remote switch was included! I dont know why, but I was afraid it didnt come with the elt and I would need to make another order. Thanks again, Mike
cristalclear13
PostPosted: Sun Sep 23, 2007 5:36 am    Post subject: Re: ELT Installation Reply with quote
Hi Mike. I am currently at where you where at a couple weeks ago. I have an MKII also and I need to know where to mount the ELT. I have the same ELT you do. Did you get yours installed? Do you have a picture of where you put it?
Also I'm wondering where you put your colored markings on your airspeed. Do you have those V-numbers?
Cristal
ropermike
PostPosted: Tue Sep 25, 2007 5:21 am    Post subject: Re: ELT Installation Reply with quote
Never exceed speed for Mk ll is 80 mph according to the old construction booklet I acquired with my plane....Stall speed is about 37 mph for my little fatty, 424lbs dry plus Fuel and Pilot. Stall with passenger aboard is 40 mph...I gave a 5 mph yellow warning before stall and before 80 mph. We have a sign shop that builds signs for us at my work. I measured my airspeed indicator with a caliper and had him cut me three circles, red, yellow and green. He makes signs with vinyl and sticky backing. I carefully cut and applied the partial circles to my indicator......ELT is mounted on a aluminum plate I riveted to the two tubing members just behind the pilots seat. I had to move and reglue the mobile antenna on top as I have a strobe box just beside the elt. Elt remote is installed on panel. (see pic). The antenna was the tough one. I finally mounted it on the top of my aluminum gap seal using a generous doubler.......N number is on the boom tube....My inspection is scheduled for Thursday, 9-27-07. Keep fingers crossed for me!.......Mike
 Filesize:  66.92 KB
 Viewed:  672 Time(s)
 Filesize:  54.45 KB
 Viewed:  625 Time(s)
 Filesize:  68.52 KB
 Viewed:  639 Time(s)
George Alexander
PostPosted: Tue Sep 25, 2007 7:50 am    Post subject: Re: ELT Installation Reply with quote
ropermike wrote:
<<<<SNIP>>>>
<<<<SNIP>>>>
Mike:
Didn't have a chance to check for a specific reference... and... your inspector may not care.... and if s/he does, it is an easy fix.
The Vne normally is indicated by a short line placed at the appropriate point on the ASI (your case 80 mph) and "perpendicular" to the point. It is not normally indicated by a red arc.
Some think that this may be picking the fly dung out of the pepper, but .....
Good luck on your airworthiness inspection!
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
jindoguy(at)gmail.com
PostPosted: Tue Sep 25, 2007 10:18 am    Post subject: ELT Installation Reply with quote
Mike, You didn't mention the DEA tag (they don't call it that, but it is in fact). It must be:
made of stainless steel (aluminum isn't considered fire proof).
It must contain the following information:
Manufacturer
Model
Serial Number
The information must be EXACTLY as it's printed on your registration hard card. You do not have to use anyone's manufactured tag, you can make it yourself. I bought a set of 1/8th steel stamps from Harbor Freight so I could make them as needed and not have to go to an engraving shop. This has been covered in previous posts, and as was noted then, the information on the tag MUST be EXACTLY as it is on the hard card. You can guess why the blob is on the upper right corner of this one from my trike.
Rick
On 9/25/07, ropermike <ropermike2002(at)yahoo.com (ropermike2002(at)yahoo.com)> wrote:
--> Kolb-List message posted by: "ropermike" <ropermike2002(at)yahoo.com (ropermike2002(at)yahoo.com)>
Never exceed speed for Mk ll is 80 mph according to the old construction booklet I acquired with my plane....Stall speed is about 37 mph for my little fatty, 424lbs dry plus Fuel and Pilot. Stall with passenger aboard is 40 mph...I gave a 5 mph yellow warning before stall and before 80 mph. We have a sign shop that builds signs for us at my work. I measured my airspeed indicator with a caliper and had him cut me three circles, red, yellow and green. He makes signs with vinyl and sticky backing. I carefully cut and applied the partial circles to my indicator......ELT is mounted on a aluminum plate I riveted to the two tubing members just behind the pilots seat. I had to move and reglue the mobile antenna on top as I have a strobe box just beside the elt. Elt remote is installed on panel. (see pic). The antenna was the tough one. I finally mounted it on the top of my aluminum gap seal using a generous doubler.......N number is on the boom tube....My inspection is scheduled for!
http://forums.matronics.com/viewtopic.php?p=136314#136314
http://forums.matronics.com//files/elt_remote_652.jpg
http://forums.matronics.com//files/elt_202.jpg
http://forums.matronics.com//files/as_ind_796.jpg sp; - The Kolb-List Email Fo the many List utilities such as the Subscriptions page, ://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List - NEW MATRONICS WEB F=======================
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
when you live at the airport.
 Filesize:  80.23 KB
 Viewed:  616 Time(s)
cristalclear13
PostPosted: Tue Sep 25, 2007 5:19 pm    Post subject: Re: ELT Installation Reply with quote
Thanks for the information and pictures Mike. I have a cloth gap seal...don't know where I could put my antenna. My Mark II is fully enclosed but there is no divider between the seats and the gas tanks. Someone suggested putting a brace around the very front of the boom tube and mounting the ELT there and perhaps putting the antenna behind that.
cristalclear13
PostPosted: Wed Sep 26, 2007 9:03 am    Post subject: Re: ELT Installation Reply with quote
I've attached a drawing (BTW-I'm NOT an artist or an engineer Smile ) of what I'm talking about.
 Filesize:  652.14 KB
 Viewed:  676 Time(s)
Goto page 1, 2  Next
Page 1 of 2
