Wing chord line alignement to spars
cj.tremblay(at)videotron.
PostPosted: Sun Sep 02, 2007 12:20 pm    Post subject: Wing chord line alignement to spars Reply with quote
Hi Guys,
I am in the process to fix the ribs to the wing spar (right wing). I fixed the spar on my work table with iron corners, same attachments for ribs on the work table. The wing of CH640 have 9 and 10 Front & Rear Ribs, identical on Y and X measurement.
I would confirms 2 ideas about the chord line alignment of the wing.
1) The chord line should to be perpendicular oriented to the Spar, in the Assembly doc, it’s say the Wing ribs must be 90 degrees to spars ;
2) The chord line, if this above assumption (1) is right, should be at the same distance (y) from the table top, for both nose and rear ribs.
Am I right ? This will help me to obtain a perfect ribs alignment with spars.
Thanks again
______________________________________
Christian Tremblay
A guy who build a CH640 aircraft from plan
http://www.zodiac640.com/
 Filesize:  2.68 KB
 Viewed:  1571 Time(s)
