frank.phyllis(at)mindspri Guest
Posted: Fri Aug 31, 2007 1:14 pm Post subject: No charge |
I'm having charging problems again.
Using the Z16 diagram with Rotax 912 ULS.
I had a charging problem before and found my "C" wire connector from the
Voltage Regulator was not properly seated. When I made good connection
I got a charge.
Today there's no charge again, according to the Dynon & GRT voltmeters.
I believe I have a good connection to the regulator but not sure how to
test.
Suggestions? Other possible problems to consider?
Frank McDonald
Posted: Fri Aug 31, 2007 1:26 pm Post subject: No charge |
frank.phyllis(at)mindspring.com a écrit :
| Quote: | Using the Z16 diagram with Rotax 912 ULS.
I got a charge.
test.
Franck,
Have you checked the regulator ground wire ? It should be the same size
as the positive wire, since it will carry the 18-20 A current.
Best regards,
Gilles, Z16 with dual battery
http://contrails.free.fr
