topglock(at)cox.net Guest
Posted: Thu Aug 30, 2007 11:26 am Post subject: G-PTAG gets it up again ! Special note to most about pitot |
Good on ya, Bob. Good to see you back in the air...
Jeff - Baby Blue
310 hours
R.C.Harrison wrote: [quote] <![endif]--> Clean Clean DocumentEmail MicrosoftInternetExplorer4 <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} <![endif]-->
Hi! All,
Pleased to report that after 18 months grounded “Me and my bird got it up” today. First landing was a little rusty especially since I hadn’t thought to do a stall test to prove the ASI was good so landed a little fast, second was fair but the nose came off as a secondary lift was caught in time.
Quite a learning curve knowing where the power is, compared with the noise of the Jabiru Six etc. but I expect I’ll get used to it! Thrilled to find the temperatures are all good …especially with the massive changes to the front of the cowl and the barrel hood fitted.
Just a note to other Europa operators:-
My ASI problem was partly due to a disturbed pitot pipe connection, but also importantly to note that the “o” rings on the pitot pipe connectors at the wing fitment were badly perished, only really identifiable by removing them but not without a replacement to hand!
The size of the “o” rings for 1/8” connectors is :- 3/16” ID 5/16”OD making a sectional diameter of 1/16” for the rubber. There will be a dozen or so in the “assortment “ box held by any hydraulics or pneumatics outfit. Suggest the club gets a supply provisioned. IMHO an annual inspection should remove these rings and put them under a magnifying glass considering how important the instrument is to safe landing. Mine must be 10 years old with the kit being collected in 1997 plus however long on Europa’s shelf!
Smile is beginning to break out ……!
Bob H G-PTAG
Robt.C.Harrison
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
| [b]
