Unhappness is a dead battery
rstone4(at)hot.rr.com
PostPosted: Tue Aug 28, 2007 6:06 am    Post subject: Unhappness is a dead battery Reply with quote
Members,
This message is for those of you who experence long periods between flights in your aircraft. Since I am involved in so many other activities I am one of those who sometimes go for a month to six weeks before I fly my aircraft so I had a problem of the battery going dead or so weak that it would not turn the engine over. I tried to do a prop start one time and found out that with the Jabiru 3300 engine, this is impossible. Anyway I solved my problem with a small charger that stays connected to the battery all the time. I have enclosed a copy of the add from Harbor Freight catalog so you can see the price has been reduced. This trickle charger may be left on the battery all the time but there are some trickle chargers that must be watched because they are manual and will over charge and ruin the battery.
My first attempt to send this out was returned by the system as being too large because I scanned the whole page in the Harbor Freight catalog, I then tried to use the URL and that would not work so this is the 4th try and I hope it goes this time.
Tracy Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
 Filesize:  422.17 KB
 Viewed:  516 Time(s)
DaveG601XL
PostPosted: Tue Aug 28, 2007 8:20 am    Post subject: Re: Unhappness is a dead battery Reply with quote
I do the same thing with my motorcycle in the winter. In my area, there are enough periods to ride during winter months that I do not winterize the bike. There are, though, enough cold snaps to keep you from riding for a month or so. I have the $40 Battery Tender brand that monitors the voltage and only trickle charges when needed. Has worked well for three winters now on the same battery. I hear that some t-hangers in my area do not have electrical power so I have been thinking about solar alternatives. But that can all wait. I need to finish the airplane first.
David Gallagher
Cincinnati, OH area
dredmoody(at)cox.net
PostPosted: Tue Aug 28, 2007 8:24 am    Post subject: Unhappness is a dead battery Reply with quote
I use a different brand of battery minder in my ultralight. I hard wired a pigtail plug to the battery. The pigtail plug is sort of like a two wire version of a trailer light plug. I bought that at Radio Shack and it is installed such that the + terminal can't accidently reach ground and drain the battery. Everytime I put the plane up in the hangar, the last action is to plug in the battery minder and I never arrive to a dead battery. I too, have breaks in my flying access so it is a must for me.
Dred
---- robert stone <rstone4(at)hot.rr.com> wrote:
Members,
leo(at)zuehlfield.com
PostPosted: Tue Aug 28, 2007 9:38 am    Post subject: Unhappness is a dead battery Reply with quote
List,
I use the same float charger as Robert Stone. Three years now. I
bought a 1/4" Phone Jack and Plug from Rat Shack. My battery is mounted
behind the passenger seat so I mounted the Phone Jack on the side of the
fuselage about 6 inches above the trailing edge of the wing. Wired the
Phone Plug to the float charger. I leave it plugged in all the time -
except in-flight. (Smile
Leo Gates
N601Z
hrs1(at)frontiernet.net
PostPosted: Tue Aug 28, 2007 1:14 pm    Post subject: Unhappness is a dead battery Reply with quote
What is a float charger? Robert Schoenberger do not archive.
Leo Gates wrote:
List,
mounted behind the passenger seat so I mounted the Phone Jack on the
side of the fuselage about 6 inches above the trailing edge of the
wing. Wired the Phone Plug to the float charger. I leave it plugged
in all the time - except in-flight. (Smile
Leo Gates
N601Z
PostPosted: Tue Aug 28, 2007 1:25 pm    Post subject: Unhappness is a dead battery Reply with quote
A float charger, AKA battey minder, is a charger which remains connected to the battery for extended intervals. It monitors the charge status of the battery and only charges until the battery is "topped off" then goes back to monitior mode. It won't just keep charging indiscriminately until it cooks your battery to a premature death.
Dred
don_lewis(at)swbell.net
PostPosted: Tue Aug 28, 2007 4:24 pm    Post subject: Unhappness is a dead battery Reply with quote
See this
http://www.vdcelectronics.com/batteryminder_12117.htm
I think VDC makes the best... I have 4 of them... You can catch
them on sale for $ 40- $50... Worth every penny....
Don n FTW
Gig Giacona
PostPosted: Wed Aug 29, 2007 6:58 am    Post subject: Re: Unhappness is a dead battery Reply with quote
Did you notice this at the end of the page?
Not for use with Aviation Specific batteries. See models 12248-AA and 24041-AA aviation specific charger-maintainer-desulphator-conditioners.
[quote="don_lewis(at)swbell.net"]See this
Don n FTW
quote]
W.R. "Gig" Giacona
601XL Under Construction
