Posted: Sun Aug 26, 2007 10:00 am Post subject: Name that plane!! |
Hello all,
I recently came across this photo of a plane. Anyone care to venture a
guess as to what it is????
Thank you, Mike in SW
Utah
Oh, BTW, I DO know. Kudos to the first guy or gal that gets it right!!!
Find a local pizza place, movie theater, and more….then map the best route!
http://maps.live.com/default.aspx?v &ss=yp.bars~yp.pizza~yp.movie%20theater&cp=42.358996~-71.056691&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=950607&encType=1&FORM=MGAC01
Posted: Sun Aug 26, 2007 10:27 am Post subject: Name that plane!! |
My first photo was rejected. Hope this one gets through. Mike
| Quote: | Hello all,
Utah
See what you’re getting into…before you go there
http://newlivehotmail.com/?ocid=TXT_TAGHM_migration_HM_viral_preview_0507
39.94 KB |
589 Time(s) |
dhkey(at)msn.com Guest
Posted: Sun Aug 26, 2007 11:15 am Post subject: Name that plane!! |
Let me guess...Fergy came out with a new design!!
| Quote: | From: "Mike Welch" <mdnanwelch7(at)hotmail.com>
Reply-To: kolb-list(at)matronics.com
Subject: RE: Name that plane!!
Date: Sun, 26 Aug 2007 11:26:47 -0700
> Hello all,
>Utah
| Quote: | << MkIIInose.JPG >>
Posted: Sun Aug 26, 2007 11:22 am Post subject: Name that plane!! |
Nope! Not a Fergy bone in it's body. Mike
| Quote: | From: "David Key" <dhkey(at)msn.com>
Date: Sun, 26 Aug 2007 14:14:20 -0500
>> Hello all,
>> Thank you, Mike in
>>SW Utah
>_________________________________________________________________
><< MkIIInose.JPG >>
Puzzles, trivia teasers, word scrambles and more. Play for your chance to
win! http://club.live.com/home.aspx?icid=CLUB_hotmailtextlink
grabo172
Posted: Sun Aug 26, 2007 12:13 pm Post subject: Re: Name that plane!! |
mark IIIX?
_________________ -Erik Grabowski
N?????
CFI/CFII/LS-I |
Posted: Sun Aug 26, 2007 12:21 pm Post subject: Name that plane!! |
IN IT's DREAMS!!!
Learn.Laugh.Share. Reallivemoms is right place!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
planecrazzzy Guest
Posted: Sun Aug 26, 2007 1:06 pm Post subject: Re: Name that plane!! |
The Only picture "I" see , is a Mark III X
Gotta Fly...
Mike & "Jaz" in MN
cstonex(at)msn.com Guest
Posted: Sun Aug 26, 2007 1:18 pm Post subject: Name that plane!! |
Kolb Extra?
LEBTF
Chuck
> From: mdnanwelch7(at)hotmail.com
[quote] To: kolb-list(at)matronics.com
> Hello all,
>Utah
Posted: Sun Aug 26, 2007 2:03 pm Post subject: Name that plane!! |
Nope. It is not a Kolb MkIII Xtra. Close, but no ceegar!
Mike
Do not archive.
jindoguy(at)gmail.com Guest
Posted: Sun Aug 26, 2007 2:38 pm Post subject: Name that plane!! |
A Mark IIIC with rhinoplasty?
Rick
On 8/26/07, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Posted: Sun Aug 26, 2007 3:28 pm Post subject: Name that plane!! |
Rick nailed it. Yes, a MlII Classic doing its best imitation of an Xtra.
Rick wins a cupie doll.
This my MkIIIC well on its way to being converted to an imitation Xtra.
Some history: Our good chap Pat Ladd (of British persuation) crunched
his MkIIIX into a building, messing up the frame at the left wing mount. He
replaced his frame, and gave his old frame to John Brown. John was kind
enough to take precise measurements and photos of this stripped down frame
(the lower portion of the frame was NOT affected at all by the accident,
only the wing mount area).
I then proceeded to cut away virtually ALL of the frame from the hips
forward. Virtually NOTHING is interchangable between the two, MkIIIC to
MkIIIX. Angles are different, dimensions are different. Actually, nothing
is the same. But, with essentially a set of plans I reconstructed the
entire front end, including adjustable rudder pedals, elevator trim, etc. I
then made the NEW side swinging doors. The front end where the nosecone
mounts came out so EXACT, that I could have used a stock nosecone!! Wished
I had, too. I fabricated the nosecone that you see, and it was a Lot of
work!! (But, seeing as how I am between careers, I have more time than
money.)
Now, I know it is NOT a true Xtra. But, when I am finished you'd be hard
pressed to tell the difference!!! There WILL be subtle differences, but
they will be just that, subtle!! I got my chrome moly tubing from A/C
Spruce, used oxy/acetelene & TIG for the welds, and shaped the nosecone from
urathane carving foam, and then glassed over the final shape.
Left to go: A) I have to finish the nosecone fiberglass.
B) Finsih the doors, to contour to new widened shoulder
posts. At first, I was going to leave this place alone, but a true Xtra is
quite a bit different here(than a M3C), so I decided to come closer to the
Xtra shape even at this location. I am leaving the original posts, for
strength, and adding a couple of tubes for a more modern appearance.
C) Clean and prep the fuselage, and then repaint the
fuselage. And then recover the new frame.
At this point, I would say I am about 90% finished toward the MkIIIC to
MkIIIX conversion. The frame portion is virtually completed. Brakes
reserviors, and pedals installed, rudder and trim linkages hooked up, doors
done, except for minor change,
Oh, and I decided to stay with my DOOR MOUNTED THROTTLE, similar to what I
had before the changes.
This may not be for you, but I am doing it MY way~~~!!! Mike
in SW Utah
PS. Little pieces of yellow string indicate a fully welded, inspected
joint. Kind of like a checklist....after inspecting a joint, and it looks
good, it gets string. If it doesn't have string, I can't verify it is
finished, yet!
| Quote: | From: "Richard Girard" <jindoguy(at)gmail.com>
Subject: Re: Re: Name that plane!!
Date: Sun, 26 Aug 2007 17:37:59 -0500
Rick
> Mike
> Do not archive.
> >From: "planecrazzzy" <planecrazzzy(at)yahoo.com>
> >Subject: Re: Name that plane!!
> >Date: Sun, 26 Aug 2007 14:06:02 -0700
> >Gotta Fly...
> >Mike & "Jaz" in MN
> >Do Not Archive
> >Read this topic online here:
> >http://forums.matronics.com/viewtopic.php?p=131102#131102
> See what you're getting into…before you go there
Rick Girard
"Ya'll drop on in"
when you live at the airport.
46.15 KB |
555 Time(s) |
planecrazzzy Guest
Posted: Sun Aug 26, 2007 4:53 pm Post subject: Re: Name that plane!! |
Most of us have a "reason" behind naming our planes....
My plane is "Miss Lucky Stars" , because , When I'm flying
I'm Thanking my "Lucky Stars"
This conversion should "inspire" some kind of name...( Classix ? )
Anywho, Let us know if you already have a name in mind.....
Gotta Fly...
Mike & "Jaz" in MN
Posted: Sun Aug 26, 2007 6:01 pm Post subject: Name that plane!! |
Cyrano
Rick
On 8/26/07, planecrazzzy <planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)> wrote:[quote] --> Kolb-List message posted by: "planecrazzzy" <planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)>
Gotta Fly...
Mike & "Jaz" in MN
"Ya'll drop on in"
George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Mon Aug 27, 2007 3:49 am Post subject: Name that plane!! |
Duckbilled Planepus?
