rjquillin
Posted: Sat Aug 25, 2007 4:22 pm Post subject: Blind Encoder Power Connection to Garmin GTX-327 Transpond |
At 13:12 8/25/2007, you wrote:
| Quote: | Anyone have a blind altitude encoder (like an AK-350) that is
getting it's power from pin 14 (switched power output) on a Garmin
GTX327 transponder?
Yes
| Quote: | I notice that the schematic for the Garmin says that pin is good for
1.5A max. The encoder document says it draws .60 amp for 1 min during warm-up.
OK, no problem there. 0.6A is far less than 1.5A
| Quote: | This seems to me to be OK, but what puzzles me is that the page in
the encoder that lists connections for the 320/327 has pin 15 (main
power for the 327) listed for power.
Yes, that is the supply to the 327, and anything else powered from
pin 14 as well.
Your encoder document shows connections to/from the 327?
Either pin could be used, but should you need/want encoder output
(perhaps for a GPS/LORAN) while the transponder was off, pin 14 would
not be a good choice for encoder power.
| Quote: | What have you guys used for powering up the blind encoder??
Dave
