CJ Weight and Balance calculator
shankeroid(at)comcast.net
PostPosted: Wed Feb 15, 2006 9:26 am    Post subject: CJ Weight and Balance calculator Reply with quote
    There were some posts a while back of those talking about creating a W&B calculator for the CJ using Excel or whatever.  Has anyone actually created one?
    Mucho appreciado.
    Jim Shanks
    shankeroid(at)comcast.net (shankeroid(at)comcast.net)
brian
PostPosted: Wed Feb 15, 2006 12:29 pm    Post subject: CJ Weight and Balance calculator Reply with quote
created one?
I just made one for someone after weighing their airplane. It is simple
and crude but it works. I think someone had done a really nice one and
posted it a couple years back.
Brian Lloyd
brian-yak(at)lloyd.com
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
gus.fraser(at)gs.com
PostPosted: Wed Feb 15, 2006 1:06 pm    Post subject: CJ Weight and Balance calculator Reply with quote
I wrote one years ago for Mark J which I think is available from Dennis' web
site. Basically it will work for the CJ with a bit of tweaking. If nobody
has tweaked it or you can't get one from somewhere else and you really
really need it then I could do a CJ one huhhhhhh!
No but seriously if someone can promise to give me the arms mac figures
effects of the gear swing etc etc I will do one for the CJ crowd.
Gus
dabear(at)damned.org
PostPosted: Wed Feb 15, 2006 1:24 pm    Post subject: CJ Weight and Balance calculator Reply with quote
I did mine after upgrading the engine with the M14P. If people want it,
email me and I'll send it out. I asked for input from the list on what
stations people are using. I did find some difference between people's
stations, however most were close. I ended up using my own
measurements and that was the same a few of the inputs from people on
the list.
DaBear
BTW, I'm not getting all the email from the yak list as it is getting
stopped by my spam filter on the email provider. If you don't see a
response from me from a list post, I'm either on the road for the week
(be back on the weekends) or the spam filter ate it.
Gus
PostPosted: Thu Feb 16, 2006 5:41 am    Post subject: CJ Weight and Balance calculator Reply with quote
Here is a version of what I use for W&B in the CJ. Note I use multiple
stations for the baggage compartment because I have an extended
compartment and control where the weight goes across those 3 stations.
If someone needs it modified for their stations, let me know.
DaBear
CJ_W&B_N6084F.xls
 Filename:  CJ_W&B_N6084F.xls
 Filesize:  23 KB
 Downloaded:  543 Time(s)
brian
PostPosted: Thu Feb 16, 2006 7:18 am    Post subject: CJ Weight and Balance calculator Reply with quote
Nice. Thanks!
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
Brian Lloyd
