lamphere(at)vabb.com Guest
Posted: Sat Aug 25, 2007 12:13 pm Post subject: Blind Encoder Power Connection to Garmin GTX-327 Transponder |
Anyone have a blind altitude encoder (like an AK-350) that is getting it's
power from pin 14 (switched power output) on a Garmin GTX327 transponder?
I notice that the schematic for the Garmin says that pin is good for 1.5A
max. The encoder document says it draws .60 amp for 1 min during warm-up.
This seems to me to be OK, but what puzzles me is that the page in the
encoder that lists connections for the 320/327 has pin 15 (main power for
the 327) listed for power.
What have you guys used for powering up the blind encoder??
Dave
mlas(at)cox.net Guest
Posted: Sat Aug 25, 2007 12:41 pm Post subject: Blind Encoder Power Connection to Garmin GTX-327 Transponder |
Dave,
You can do it either way! Pin 14 is switched out limited to 1.5 amps
which is well below the use of the encoder. If you use an avionics
master you can go to pin 15 which is power into the transponder or you
could go directly to a circuit breaker.
Mike
