creightonious
Posted: Thu Aug 23, 2007 7:15 am Post subject: Trim Tab drive pins |
Good morning all,
We installed the larger/stronger mod of the TP16P & TP16S drive pins (which doesn't seem to be listed in the current mods list) per instructions and with just a few on/off cycles of the horizontal stabilizers, each has cracked where the 3 layers bid wrap 90deg around the front.
This appears to be a result of the TS05 link rod cocking upon removal and jamming the drive pins in the TS06 bushes (which are a lovely fit) which results in a racking load jamming the drive pins.
Obviously we have to do this again (irritating as the originals exhibited no such symptoms), but I must know if anyone else has experienced this, and what the solution might be.
Stationing a second person at the tail to ensure the link rod does not deviate from perpendicular to the drive pins while the tailplanes are being pulled is obvious but a bit labor intensive.
Creighton Smith A036
_________________ Creighton Smith
A 036 |
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Thu Aug 23, 2007 8:43 am Post subject: Trim Tab drive pins |
Sorry about your difficulties Creighton. I have the larger pins as Mod 58 but haven't
done the install yet as there has been no visible cracking on the original pins. Somehow
Mod 58 disappeared from the Europa 2004 mod list. I wonder if they decided it was
unnecessary or if was just an accidental deletion.
Glenn
Subject: Europa-List: Trim Tab drive pins
Date: Thu, 23 Aug 2007 11:12:38 -0400
| Quote: | Good morning all,
| New home for Mom, no cleanup required. All starts here. [quote][b]
hurstkr(at)redzone.com.au Guest
Posted: Thu Aug 23, 2007 8:33 pm Post subject: Trim Tab drive pins |
Creighton
Do you have a couple of pieces of plywood (or similar) inside the rear of the fuse just ahead of the "T" bar slot to limit the sideways movement of the "T" bar on assembly and disassembly of the tailplanes ? The two guides should have minimum gap between them but still be wide enough to allow full and free movement of the 'T' bar throughout full deflection of the tailplanes.
I don't remember this ever being a mod but was certainly a recommended suggestion. I'm sure it will save your having to employ a second person as you suggested below.
Kingsley in Oz.
