charlesmcg(at)citlink.net Guest
Posted: Thu Aug 23, 2007 8:26 pm Post subject: Choice of engine for the CH 601HDS |
Having acquired a partially complete 601 HDS kit, which I intend to
complete as an E-LSA, I would like to hear comments on the broad
question below!
How do the Subaru and Corvair engines stack up against Rotax & Jabiru
when you take cost, installation, available technical support, weight
and final performance into account? And are there any 601 builders
reasonably close to Sacramento, CA?
Sincerely
Charles McGloughlin Email - charlesmcg(at)citlink.net
8654 Bluefield Way Phones - Cell (916)832-0654
Sacramento, CA 95823 Home (916)689-7701
charlesmcg.vcf |
130 Bytes |
630 Time(s) |
zodierocket(at)hsfx.ca Guest
Posted: Thu Aug 23, 2007 8:43 pm Post subject: Choice of engine for the CH 601HDS |
If you want it to be an ELSA, I believe that you will need it flying by
December of this year. However I may be wrong as I am a Canadian and not
fully up on the U.S. LSA. IF it is true and to meet the ELSA category by
December, you will have to order a Rotax or Jabiru in the next week in
order to have a chance to make the deadline. IF you go auto conversion,
typically add another year to your construction. Also a missed deadline.
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com
www.can-zacaviation.com
psm(at)ATT.NET Guest
Posted: Fri Aug 24, 2007 3:03 am Post subject: Choice of engine for the CH 601HDS |
Hi Mark,
I believe you are correct about the deadline for E-LSA certificates
for our planes, but the deadline is actually January 31, 2008. I
don't think it matters very much, though. After that date all of the
planes we build will need E-AB airworthiness certificates. This is
not a problem -- just a few small differences in the phase 1 flight
test requirements and repairman certificate qualifications. E-AB
planes qualify for Sport Pilot use with exactly the same
qualifications and restrictions as E-LSA.
For Charles -- All of the engines you mentioned can be used in a
CH601HDS. The auto conversions are the heaviest and seem to provide
the least performance for the lowest dollar cost. The Rotax and
Jabiru cost about the same new and weigh about the same. Performance
from the Rotax seems slightly better than the auto conversions while
the Jabiru is significantly more powerful than the Rotax.
I don't know the current lead times for Rotax engines. Jabiru 3300
had a 3-5 month lead time when I ordered mine in April this year.
One small point on the HDS. To qualify as LSA you need to pay
attention to the stall speed and cruise speed for this model. You
get to specify the exact numbers for your plane when it is certified,
but if you choose the wrong numbers it will not qualify as LSA. Some
HDS examples have a stall speed that is too high for this purpose,
while others just go too fast. Once again, this is not related to
the choice of airworthiness certificate but it will impact whether or
not a Sport Pilot can fly your plane.
Paul
XL fuselage
Mark Townsend
rickpitcher
Posted: Fri Aug 24, 2007 7:24 am Post subject: Re: Choice of engine for the CH 601HDS |
| charlesmcg(at)citlink.net wrote: | Having acquired a partially complete 601 HDS kit, which I intend to
question below!
Sincerely
Sacramento, CA 95823 Home (916)689-7701 |
I went through the same thing a few years ago when it was time to pick a powerplant. So many choices it's hard to decide which one to use. You have to decide if you want the max performance or the lowest initial price. I ended up going with the Jabiru 3300. It's the lightest of the group, and the most horsepower. I'm happy with the choice.
The auto conversions are really inviting because of their lower cost and familiarity, but by the time you add the PSRU the extra weight and $$$ starts to add up. You might wish later that you'd spent a couple thousand more for a lighter/stronger powerplant in the first place.
You're going to have to come in on the lightweight side if you want those little HDS wings to be meet LSA stall speeds.
While you're building and contemplating "improvements", remember the homebuilder's adage: "Add only lightness and simplicity".
Rick Pitcher
CH601HD
(considering another build...)
Gig Giacona
Posted: Fri Aug 24, 2007 7:39 am Post subject: Re: Choice of engine for the CH 601HDS |
And just to reduce possible future confusion there isn't a need for a PSRU on the Corvair auto coversion.
| rickpitcher wrote: |
601XL Under Construction
rickpitcher
