Fuel System Design
Ron Lendon
PostPosted: Wed Aug 22, 2007 6:08 pm    Post subject: Fuel System Design Reply with quote
Hey gang, It's time to begin the design of the fuel system. I have little experience but I have placed a design document at this location:
http://home.comcast.net/~rlendon/Fuel_System_design_document_for_Zodiac_XL.doc
and would like feedback. If I am off base here, let me know.
Basically I'm following the prints but substituting Stainless Braided line and fittings from Earls. The document is linear in that it starts at the tank and ends at the line to the carb.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
amyvega2005(at)earthlink.
PostPosted: Thu Aug 23, 2007 5:59 am    Post subject: Fuel System Design Reply with quote
just stick to the plans, its a good design.
craig(at)craigandjean.com
PostPosted: Thu Aug 23, 2007 1:59 pm    Post subject: Fuel System Design Reply with quote
A few comments:
- since you are going with the Corvair I presume you will be following
William's design.
- consider adding a fuel flow sender and gauge. Fuel exhaustion is an all to
common cause of accidents and fuel flow can provide an instantaneous check
on the health of your fuel system and also help you track your fuel more
accurately.
- I'm paranoid enough about vapor-lock that I went with the Andair
extensions so I can mount my valve on the floor and the knob on the center
console.
-- Craig
Ron Lendon
PostPosted: Thu Aug 23, 2007 6:28 pm    Post subject: Re: Fuel System Design Reply with quote
Craig,
I have allowed for the pressure gage but hadn't thought about the flow. And yes it is a Corvair the WW way. I have been waiting for him to publish the 601 book but have gotten to the point I need to move forward.
Got any pictures of the Andair Valve mounted?
Thanks for the ideas.
Ron Lendon
CH 601 XLB
N601LT - Flying
PostPosted: Thu Aug 23, 2007 6:44 pm    Post subject: Fuel System Design Reply with quote
Mine is still mounted in its box. But I've attached pictures of somebody
else's installation. Unfortunately I've lost track of whose plane it is.
-- Craig
 Filesize:  107.52 KB
 Viewed:  811 Time(s)
 Filesize:  116.69 KB
 Viewed:  858 Time(s)
davidhwright(at)mac.com
PostPosted: Fri Aug 24, 2007 2:13 am    Post subject: Fuel System Design Reply with quote
Ron
I am more or less at the same stage as you are - I was considering
quick disconnects at each wing root - any thoughts on these?
Dave Wright
Washington UK
601XL Wings, Scratchbuild
On 24 Aug 2007, at 03:28, Ron Lendon wrote:
Craig,
to move forward.
Ron Lendon, Clinton Township, MI
Corvair Zodiac XL, ScrapBuilder Wink
http://forums.matronics.com/viewtopic.php?p=130646#130646
Afterfxllc(at)aol.com
PostPosted: Fri Aug 24, 2007 2:20 am    Post subject: Fuel System Design Reply with quote
I can send you pics of the complete fuel system I installed for the corvair install if you need them?
Jeff
Jaybannist(at)cs.com
PostPosted: Fri Aug 24, 2007 5:04 am    Post subject: Fuel System Design Reply with quote
David,
I have an XL with the dual stick option. The outboard bearing brackets for the system have holes in them for fuel line support. In these holes, I mounted a AN bulkhead fitting. The inboard side is connected to the fuel selector with braided fuel line. I installed a hose barb fitting on the outboard side. When I attach my wings, I will route the ZAC-furnished rubber hose from the fuel tank, thru the side skin and to this hose barb. In that location, the connection, with a clamp, will be real easy to make. That is about as close to a quick disconnect as I want to be.
Jay in Dallas
David Wright <davidhwright(at)mac.com> wrote:
Ron
Dave Wright
Washington UK
> Craig,
> to move forward.
> http://www.mykitlog.com/rlendon
archerm
PostPosted: Fri Aug 24, 2007 6:02 pm    Post subject: Fuel System Design Reply with quote
That is from my web site.
http://www.zodiacxl.com/Brake%20and%20Fuel%20system.htm
I wasn't happy with the location up on the panel. So I moved it low to keep
a pressure head on the valve. It works fine.
Cheers
Matt
www.zodiacxl.com
Matt
www.zodiacxl.com
Ron Lendon
PostPosted: Fri Aug 24, 2007 6:54 pm    Post subject: Re: Fuel System Design Reply with quote
Craig and others,
Added a Floscan 210B to the design just down from the second pump, filter will come after that. It will connect right to the Dynon unit I plan to install.
I don't see the need for a quick disconnect at the wings, once they go on I hope to keep them on. I am planing on using the Stainless Braided hose though and keeping all the pressure on the engine side of the firewall. The braided hose is much less likely to rupture if the worse thing happens.
I am going to have to experiment with some clear line to decide about mounting the selector valve low.
Thanks for all the feedback, keep it coming,
Ron Lendon
CH 601 XLB
N601LT - Flying
doffill(at)cableone.net
PostPosted: Fri Aug 24, 2007 7:21 pm    Post subject: Fuel System Design Reply with quote
Matt what did you use to paint the inside of the fuselage with. It looks
great.
Danny
PostPosted: Fri Aug 24, 2007 8:28 pm    Post subject: Fuel System Design Reply with quote
Thanks, I'll make a note.
BTW: Matt's site contains a link to a very good article on fuel systems that
I've read in the past:
www.ellison-fluid-systems.com/article/fuelsystemsforhomebuilts/fuelsystems.h
tm
-- Craig
archerm
PostPosted: Sat Aug 25, 2007 1:22 pm    Post subject: Fuel System Design Reply with quote
I used Stewart Systems water based paint. It takes a little getting used
to. But I really like it. This stuff is very durable and very safe. I
tried it on the interior to get the feel of it. I am glad I did. If you
order paint from them they will send you a video that shows how to do it.
They are really great to work with.
http://www.aircraftfinishing.com/
Good luck and happy building
Matt
www.zodiacxl.com
Matt
www.zodiacxl.com
Ron Lendon
PostPosted: Sun Aug 26, 2007 11:10 am    Post subject: Re: Fuel System Design Reply with quote
Send the pictures.
Jeff
Ron Lendon
CH 601 XLB
N601LT - Flying
