lamphere(at)vabb.com Guest
Posted: Mon Aug 20, 2007 12:17 pm Post subject: KX125 connector |
I would like to know what type of connector is used for a KX125 NAV/COM as I
would like to wire up a used (wires were just cut off) unit and will
probably need to get some pins at least (or is this a "replace the whole
unit" situation?? I found the .pdf listing at the reference materials at
Aeroelectric (thanks!), but not what kind of connector it was (or at least I
didn't see it).
The RF connections look like they are soldered 90 deg, I "think" I can undo
them and attach new cable... but then again, I haven't started working on
them yet..
Thanks in advance,
Dave
peter(at)sportingaero.com Guest
Posted: Mon Aug 20, 2007 1:30 pm Post subject: KX125 connector |
Ebay is a great source for these pins and connectors
Peter
berkut13(at)berkut13.com Guest
Posted: Mon Aug 20, 2007 6:30 pm Post subject: KX125 connector |
Here is some additional information. I think the 125 uses the same
connectors as most of the King series radios.
http://www.berkut13.com/extractor.htm
James Redmon - Race 13
Berkut #013 N97TX
Posted: Tue Aug 21, 2007 4:11 am Post subject: KX125 connector |
Ah yes! That's what I was looking for. Thank you!
David Lamphere
Wittman W10 Tailwind N828DL
(under construction)
