Tim_Lewis(at)msm.umr.edu Guest
Posted: Thu Aug 16, 2007 4:27 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
I'm thinking of buying either a 60 Amp alternator made by either Plane
Power ($375 including internal regulator and OV from Van's) or B&C
($595 + $228 for regulator & OV = $823) for my RV-10. The Plane Power
price and simplicity are quite appealing. I've heard good things about
Plane Power, and have heard of only a single failure in the field. B&C
also has a very good reputation. So I'm seeking experiences, both good
and bad, from people who have put a few hours on a Plane Power (or B&C)
alternator.
Tim Lewis
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 900 hrs
RV-10 #40059 under construction
n142ds(at)gmail.com Guest
Posted: Thu Aug 16, 2007 4:57 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
I have two B&C alternators... one 60AMP and one 20AMP on the vaccuum pad. They just work ! No problems so far.
On 8/16/07, Tim Lewis <Tim_Lewis(at)msm.umr.edu (Tim_Lewis(at)msm.umr.edu)> wrote:[quote]--> RV-List message posted by: Tim Lewis < Tim_Lewis(at)msm.umr.edu (Tim_Lewis(at)msm.umr.edu)>
alternator.
Tim Lewis
RV-6A N142DS "Geek One"
TMX-IOF360 FADEC, Hartzell Blended Airfoil, GRT EFIS
www.n142ds.com [quote][b]
Gary.A.Sobek
Posted: Thu Aug 16, 2007 5:11 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
B&C 60 A alternator and B&C regulator. All the problems that I have had (3)
are from wiring problems that were MY problems. Twice I had a bad
connection and one was a wire that had the insulation rub off and
intermittently shorted to ground killing the alternator output. B&C
troubleshooting guide that they have on their web site was used to find all
the problems that I caused. Problems that I caused were spread out over
almost 10 years. I made the airplane's first flight in September 1997.
B&C alternator and regulator has had no problems in almost 10-years of
operation.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
2,050 + Flying Hours So. CA, USA
----Original Message Follows----
Reply-To: rv-list(at)matronics.com
To: rv-list(at)matronics.com, rv10-list(at)matronics.com
Subject: Seeking good and bad experiences with Plane Power, B&C
alternators
Date: Thu, 16 Aug 2007 20:26:18 -0400
I'm thinking of buying either a 60 Amp alternator made by either Plane Power
($375 including internal regulator and OV from Van's) or B&C ($595 + $228
for regulator & OV = $823) for my RV-10. The Plane Power price and
simplicity are quite appealing. I've heard good things about Plane Power,
and have heard of only a single failure in the field. B&C also has a very
good reputation. So I'm seeking experiences, both good and bad, from people
who have put a few hours on a Plane Power (or B&C) alternator.
Tim Lewis
Find a local pizza place, movie theater, and more….then map the best route!
http://maps.live.com/default.aspx?v &ss=yp.bars~yp.pizza~yp.movie%20theater&cp=42.358996~-71.056691&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=950607&encType=1&FORM=MGAC01
Vanremog(at)aol.com Guest
Posted: Thu Aug 16, 2007 7:00 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
In a message dated 8/16/2007 5:29:50 P.M. Pacific Daylight Time, Tim_Lewis(at)msm.umr.edu writes:
| Quote: | So I'm seeking experiences, both good
alternator.
Tim-
B&C 60A running A-OK since day one.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 864hrs, Silicon Valley, CA)
AOL.com.
gmcjetpilot
Posted: Fri Aug 17, 2007 6:20 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
Tim: there both good but you hit the nail on the head cost. Both have good products and service.
I can point out to some nice features of the Plane Power unit that the B&C does not have:
-Custom cooling fans for proper rotation (B&C runs stock fan backward)
-High Altitude Brushes
Plane power also like B&C is anodized, balanced and they use top parts. Plane power manufactures many parts in house.
The OV production uses the same type of crow-bar OV module that Bob recommends and B&C sells, but it is integrated into the unit.
You can't go wrong with either, but one advantage that may not be obvious is getting an emergency temp replacement on a X-C trip. Away from home base, the plane power could in a pinch be replaced with a stock alternator from an automotive parts store. Even though the Plane power units are modified, the wiring is basically the same as a stock internally regulated alternator.
Plane power has a larger output unit 70 amps verses 60 amps. If you want to accept the weight, I would consider the 70 amp unit, especially if you are going with a fancy panel and inflight entertainment. It's about 3 lbs more. It's nice to keep your total load below say 50-60% of max rating. It's simple math, heat. Lower the heat the better the service life/reliability. Since the Plane-power has the regulator on-board, protecting it from heat with heat a shield and blast tube is value added.
Cheers George
B&C alternators
alternator.
Tim Lewis
Posted: Fri Aug 17, 2007 6:54 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
In a message dated 8/17/2007 7:22:04 P.M. Pacific Daylight Time, gmcjetpilot(at)yahoo.com writes:
| Quote: | | Plane power also like B&C is anodized, balanced and they use top parts. |
I believe that George meant to say alodined (chem film per MIL-C-5541) rather than anodized (per MIL-A-8625) because, if you were to anodize the housing, you would have to do it selectively (not in the area that makes chassis ground contact), since anodizing is insulative. My B&C is chem filmed and chem film (chromate) is conductive.
AOL.com.
rocketbob(at)gmail.com Guest
Posted: Fri Aug 17, 2007 7:30 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
Alternatively consider the Denso 100211-1680 alternator, available brand new from many sources for about $200. Its rated at 42A and weighs 6lbs. This is the same alternator that Niagara Airparts used to sell, and it has built-in OV protection. I have had one for 700+ hours and its been rock-solid reliable. The most appealing thing about this alternator is the availability of it as a rebuilt unit at a local auto parts store. Once I had a friend I was flying with have an alternator crap out on a trip, and we were able to get him going again after a short hop to the a auto parts store after landing at the nearest airport along our route. His alternator was one of Van's old 35A units.
I have a source for these new alternators, email me off-line if interested. Niagara will still sell the brackets for $75.00.
Bob Japundza
RV-6 flying F1 under const.
baremetl(at)gvtc.com Guest
Posted: Sat Aug 18, 2007 8:20 pm Post subject: Seeking good and bad experiences with Plane Power, B&C alter |
Bob,
I have one of Van's original (circa 1990) 35A alternators on my -4. Do you know whether a Denso 100211-1680 will fit the mount (boss type) that came with that alternator? If so, could you give me some info about cost for a new alternator that you alluded to below?
Ivan Haecker -4 1381hrs. S. Cen TX
(also with F-1 under very slow construction)
-------Original Message -----
[quote] From: Bob J. (rocketbob(at)gmail.com)
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Sent: Friday, August 17, 2007 10:29 PM
Subject: Re: Re: Seeking good and bad experiences with Plane Power, B&C alter...
Bob Japundza
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
