Guy Buchanan
Posted: Sat Aug 18, 2007 1:44 pm Post subject: Rotax Voltage Regulator |
All,
It looks like my Rotax 582 three phase voltage regulator's
dying. (It will occasionally go over voltage. I can re-set it and get
it to work, but it's happening more often now.)
Does anyone have a recommended replacement? I've mounted it
in the engine compartment to minimize electrical noise in the cockpit
and I suspect things are a little hot for the stock Rotax unit. Has
anyone tried any of the Harley replacements? Any after-market units?
Or should I just increase the cooling to the Rotax unit?
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
369PL
Posted: Sun Aug 19, 2007 4:33 am Post subject: Re: Rotax Voltage Regulator |
I posted the same question a few months ago. Some one sugested the keywest reggulator. It provides a more constant voltage on my aircraft. I also think it reduced my radio noise. But mine is on the inside of the firewall. I don't know how the heat will affect it.
Mnflyer
Posted: Sun Aug 19, 2007 4:59 am Post subject: Re: Rotax Voltage Regulator |
The Keywest is probaly the best regulator available. I replaced the original Rotax one with a Keywest and it provided steady even voltage both were mounted on the engine side of the firewall didn't notice any noise reduction in the radio.
_________________ GB
MNFlyer
Flying a HKS Kitfox III |
msm_9949(at)yahoo.com Guest
Posted: Sun Aug 19, 2007 5:22 am Post subject: Rotax Voltage Regulator |
Gary:
The Key West solid-state regulator available from LEAF and many other sources (John & Deb?) is inexpensive and works great. I replaced the stock regulator a few years ago with the KW and it has operated flawlessly. There's a good Mike Strattman article on California Power System's website that describes all the alternatives and how they work.
Marco Menezes
KF II 582-90 N99KX
Guy Buchanan <bnn(at)nethere.com> wrote:[quote] --> Kitfox-List message posted by: Guy Buchanan
All,
in the engine compartment to minimize electrical [quote][b]
Float Flyr
Posted: Sun Aug 19, 2007 6:54 am Post subject: Rotax Voltage Regulator |
If this is a problem that has been coming on slowly then I expect there is a problem with a ground in your system somewhere. First step is to make sure all the ground connections between the voltage regulator,battery and engine to the frame of the plane are nice and shiny clean. These solid state units (regardless of brand name) are designed to operate many years without attention. When they quit they normally don't come back.
There is an operating envelope for these regulators in terms of operating temperature and your problems may be temperature related. you can try mounting a piece of 1" scat hose inside the cowl to direct air from the front of the cowl to the regulator.
I have had serious EMI (Electro Magnetic Interference) in the past with my 582. The cause was in the spark plugs. The 582 requires resistor plugs AND resistor caps. because of an engine problem all my plugs shorted the resistor in the plugs I could hear the tower but the tower couldn't copy me at all even though my signal was strength 5. I was operating on batteries.
[img]cid:626171014(at)19082007-0D1B[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
19.77 KB |
676 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Mark.Napier(at)sciatl.com Guest
Posted: Mon Aug 20, 2007 6:55 am Post subject: Rotax Voltage Regulator |
The Key West regulator works well for me.
I had a problem with my system and thought the regulator was the
problem. Swapped it out with no improvement. Turned out the grounding
was not right.
The original one should work fine; $30 if you want it.
Mark Napier
Time: 02:44:23 PM PST US
Subject: Rotax Voltage Regulator
All,
Guy Buchanan
San Diego, CA
- - - - - Appended by Scientific Atlanta, a Cisco company - - - - -
This e-mail and any attachments may contain information which is confidential,
proprietary, privileged or otherwise protected by law. The information is solely
intended for the named addressee (or a person responsible for delivering it to
the addressee). If you are not the intended recipient of this message, you are
not authorized to read, print, retain, copy or disseminate this message or any
part of it. If you have received this e-mail in error, please notify the sender
immediately by return e-mail and delete it from your computer.
Guy Buchanan
Posted: Mon Aug 20, 2007 7:28 pm Post subject: Rotax Voltage Regulator |
At 07:55 AM 8/20/2007, you wrote:
| Quote: | I had a problem with my system and thought the regulator was the
was not right.
Mark,
What was the problem with the grounding? How did your
problem manifest itself?
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
