mister_murphy(at)yahoo.co Guest
Posted: Mon Aug 13, 2007 4:10 pm Post subject: F-641 / pushrod interference |
Hi everyone,
Has anyone else had any problems with the pushrod
bumping the bottom of the F-641 with the control in
the full forward position? I have checked and double
checked both the pushrod installation and the mounts
for the control column and am unable to get it any
lower. I spoke with vans a while back about it and
they said to just cut a notch in the center of the
F-641 at its lowest spot so it doesnt hit the pushrod.
Also this notch will be between the side panels for
the electric flap actuator.
Any ideas folks? I am at a loss....
Erik
RV-6A Fuse
Pinpoint customers who are looking for what you sell.
http://searchmarketing.yahoo.com/
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Mon Aug 13, 2007 4:24 pm Post subject: F-641 / pushrod interference |
Erik:
I have just a tad of interference as you mention. It is very minimal, and
IMHO will not be a factor.
Unless you do some major acro, how many times are you going to apply full
down elevator?
Jeff Orear
RV6A N782P
Peshtigo, WI
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
kbob(at)cox.net Guest
Posted: Mon Aug 13, 2007 6:30 pm Post subject: F-641 / pushrod interference |
Erik,
I had the same problem on my 6A. The control rods are not adjustable to get this issue resolved. Grab your half round file or dremel and make sure you have ~1/8" clearance underneath. You don't want this part to hang up at any time.
Kelly Patterson
RV-6A N716K Chandler
170 hours (& only 1 emergency landing!)
---- mister murphy <mister_murphy(at)yahoo.com> wrote:
Quote: |
Hi everyone,
Erik
RV-6A Fuse
bertrv6(at)gmail.com Guest
Posted: Wed Aug 15, 2007 7:34 am Post subject: F-641 / pushrod interference |
On 8/13/07, kbob(at)cox.net <kbob(at)cox.net> wrote:
Quote: |
Erik,
Kelly Patterson
> Hi everyone,
> Erik
> RV-6A Fuse
> Do not archive
> Pinpoint customers Eriki: If I remember I used the heavy snips, and remove
some of the material, it was very little, just enough for the push rod, to
move freely.. that is the center, of cockpit center well no?
Just be sure the rod does not trouch anywhere when moving to full
deflection..
bert rv6a
