harley(at)AgelessWings.co Guest
Posted: Wed Aug 15, 2007 4:36 am Post subject: B&C SD 8 Alternator |
Morning, Everyone...
Now that I'm dumping all my remaining vacuum instruments (the one I have
left!) and the associated pump and gauge, and settling for an all
electric panel (except for the static gauges), I am starting to look at
alternator options.
I've kept up on the past discussions here, and Bob's Connection info,
and have a pretty good
idea of what's involved.
But, I just noticed the B&C model SD-8 alternator that fits on the
vacuum pump pad! What a great replacement for a gasket and a cover!
I also see that Bob does mention it's use in one of his articles, but as
a backup alternator.
Seeing that the original Long Ez plans call out an alternator only as an
option if you plan on IFR or night flying, or if you use a starter, and
strongly recommend just the VariEZE solar panel to keep the battery
charged, has anyone here installed the SD-8 and used it as the main
unit. It only has a maximum 10 amp output, and a nominal 8 amp, but I
would think that would be enough to keep the battery charged and operate
the newer low current instruments quite well.
I have yet to calculate my panel's consumption (don't have all the
instruments yet), let alone the plane's, so it's still in the planning
stage. Open to all suggestions. Redundancy is always best, but if one
can save some weight and still do the job (I also have two P-mags with
their own generators so the engine should keep running on the electronic
ignition even if the battery and alternator go down) then I'm all for it.
Harley Dixon
Long EZ N28EZ
Airport Hangar 29
Canandaigua, NY
BobsV35B(at)aol.com Guest
Posted: Wed Aug 15, 2007 5:20 am Post subject: B&C SD 8 Alternator |
Good Morning Harley,
The B&C 20 ampere unit fits on the same pad. It is a bit heavier but it is also a more robust looking device. I am very electronically challenged, but I did install one of the twenty amp units on my airplane about ten years ago. Very happy with the result.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 8/15/2007 7:41:01 A.M. Central Daylight Time, harley(at)AgelessWings.com writes:
| Quote: | But, I just noticed the B&C model SD-8 alternator that fits on the
Posted: Wed Aug 15, 2007 6:05 am Post subject: B&C SD 8 Alternator |
Mornin', Bob...
I guess I didn't look far enough! Didn't see the 20 amp version!
Now that looks like a winner...guess it pays to ask, doesn't it!
Have to see if I have room for it on the Long between the firewall and
the case, but at 6", it should fit. Otherwise, I like it.
I see they have a couple of others as well...should have browsed B&Cs
site before I started asking questions, I guess!
Thanks for the heads up...
Now, back to sealing my driveway today......
Harley Dixon
Long EZ N28EZ
Airport Hangar 29
Canandaigua, NY
BobsV35B(at)aol.com wrote:
| Quote: | Good Morning Harley,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
chasb(at)satx.rr.com Guest
Posted: Thu Aug 16, 2007 4:25 am Post subject: B&C SD 8 Alternator |
Harley, et al,
I have a friend with a Pitts who has a SD 8 as his only power source
other than the battery. He has no electronics other than a radio and
the starter. His SD 8 is more than adequate to run the radio with
enough current left over to charge the battery.
The only concern I would have with the SD 8 or the SD 20 as a sole
power source is that both require fairly high RPM to produce adequate
current for much of anything. Our usual high amp alternators produce
enough juice at idle to charge the battery.
Charlie Brame
RV-6A N11CB
San Antonio
| Quote: | Time: 05:36:52 AM PST US
Subject: B&C SD 8 Alternator
have
look at
alternator options.
but as
as an
and
operate
one
electronic
for it.
Harley Dixon
nuckollsr(at)cox.net Guest
Posted: Sat Aug 18, 2007 9:34 pm Post subject: B&C SD 8 Alternator |
At 07:19 AM 8/16/2007 -0500, you wrote:
Harley, et al,
Which is no worse than generators used to offer. There
are hundreds of OBAM light aircraft flying with vacuum
pump driven alternator products from B&C as their sole
source of engine driven power. These are, of course,
mostly day VFR aircraft. A few night VFR too . . . but
if one had LED based position and strobes, then perhaps
night VFR on 8A would be quite comfortably managed.
It can be done now and is going to get easier in the
near future.
jmfpublic(at)comcast.net Guest
Posted: Sun Aug 19, 2007 12:57 pm Post subject: B&C SD 8 Alternator |
Bob wrote: "if one had LED based position and strobes, then perhaps
night VFR on 8A would be quite comfortably managed."
This is a good point, and opens up the topic of LED position lights. I have a Jabiru J400, and the alternator is good for 20 amps max, closer to 15 amps continuous. I had planned to put an SD20 alternator on the crank splined shaft to get more total power, but the complication of two alternators and two batteries seemed far too great for what will be mainly a day and night VFR plane with pretensions.
The Whelan strobe and position light system has two lamps per wingtip and the strobe supply. Each lamp is two amps, and the strobe supply is 6 amps. Yikes! That is 14 amps for running lights. The gold plated pins that go into DB connectors and also the circular plastic locking connectors are very easy to use, but should not be used for much over 4 amps. I could parallel these critters, but that gets to be more work. By going to the LED system from either Kunzleman or GS, the current draw is between 150 and 300 ma per wingtip. The strobe systems run 2 to 4 amps.
Are these wingtip nav lights equivalent to the Whelan incandescent? I have bought both GS and Kunztleman systems for testing. I just made a simple turntable marked off in degrees to rotate the wingtip unit to measure lux output vs. angle. I'm using the nice primer on lighting requirements that Eric Jones posted on his website, Perihelion Designs. http://www.periheliondesign.com/
To measure the light output, I got a lux meter, calibrated in lux. Photographic light meters can be converted from exposure value to lux, but these meters are intrinsically logarithmic in response, and I don't trust it.
The horizontal plane measurement will be relatively easy, but the vertical plane may be harder. Eric himself does not believe that present commercial units meet the FARs, but for experimental, they do not need to. Of course, the low power strobes don't, but any strobe is far better than none, and the logarithmic response of the eye comes to our rescue here.
James Foerster, J400, wiring.
bakerocb
Posted: Mon Aug 20, 2007 5:22 am Post subject: B&C SD 8 Alternator |
8/20/2007
Hello James, You wrote: "Eric himself does not believe that present
commercial units meet the FARs, but for experimental, they do not need to."
I am questioning your statement that stobe and position lights installed on
amateur built experimental aircraft do not need to meet FAR requirements.
What is your basis for that statement?
A) Each amateur built experimental aircraft will have a set of Operating
Limitations that are part of that aircraft's special airworthiness
certificate. The Operating Limitations will include the words:
"After completion of Phase I flight testing, unless appropriately equipped
for night and/or instrument flight in accordance with 91.205, this aircraft
is to be operated under VFR, day only."
B) FAR Sec. 91.205 paragraphs (c) (1) and (2) read:
"(c) Visual flight rules (night). For VFR flight at night, the following
instruments and equipment are required:
(2) Approved position lights.
(3) An approved aviation red or aviation white anticollision light system on
all U.S.-registered civil aircraft......skip....."
C) Here is a quote from the introduction to my table on the subject of
amateur built aircraft equipment requirements:
"The builder should note that some items required by the FAR's are
described in the FAR's as needing to be approved, but since there are no
certification standards established for amateur built experimental aircraft,
no formal individual item approval, such as meeting a TSO (Technical
Standard Order) or FAR Part 23, is required. However certain items must
interface properly with ATC (Air Traffic Control), other aircraft, or other
entities external to the aircraft. Transponders, communication radios,
exterior lighting and ELT's (Emergency Locator Transmitters) are examples of
such equipment. Therefore, the builder can expect that the initial
airworthiness inspection of his aircraft will require evidence that this
type of equipment in the aircraft is acceptable to the FAA."
D) It would appear that the inspector performing the original airworthiness
inspection of an amateur built experimental aircraft would have the
prerogative of insisting that the strobe and position lights of that
aircraft (if installed) meet the requirements of FAR Part 23 regarding
strobe and position light performance. The presumption being made that the
installation of such lights indicates an intention to fly at night on some
occasions.
Your comments?
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 01:57:41 PM PST US
Subject: Re: B&C SD 8 Alternator
amps.
trust it.
our rescue here.
Posted: Wed Aug 22, 2007 8:13 am Post subject: B&C SD 8 Alternator |
OC wrote
8/20/2007
to."
on
My basis was misremembering your original explaination-sorry. Thanks for
setting the record straight once again. That said, I am trying to measure
the available commercial units to see how close they come.
Since that post, my sources tell me that the inspectors for exerimental and
amateur built aircraft are taking a closer, and more jaundiced, look at the
LED position lights. I did see some units molded into the wing at the last
Oshkosh that clearly did not meet the field of view requirements, although
brightness is impossible to judge in the daylight.
Jim
