mikefapex
Posted: Tue Aug 21, 2007 7:18 pm Post subject: Z-19 Clarifications |
Hi ,
I am planning to install a Z-19 system and had a couple of clarifying questions. Feedback is very much appreciated.
1. Do all of the contactors in the system have to be Amperage rated at or above the maximum output of the alternator? I guess this is not a z-19 specific question but I'm still unsure.
2. How does the E-bus alternate feed relay work, I am not sure of its intended purpose? I can see the E-bus is normally fed from the Main power bus through a diode but I'm not sure what function the relay provides.
Do you normally start with the E-bus relay switch OFF. Then if your alternator dies you manually switch the E-bus ON?
My E-bus load comes up to 9.5 amps. Do I even need the relay?
3. Should both batteries be connected to the same ground point on the airframe, rather than two separate locations? In my case it means running about 5' of wire to that designed ground stud.
4. Parts - Diodes for the ECU and Fuel pumps - is the B&C Essential Bus Diode and the Perihelion Power-Deuce-Schottky™ Auto-Power Selector Diode Assembly essentially the same component. In the Z-19 the it says 'Note 24', but I cannot find that in my Aeroelectric Connection manual or the website.
Thanks very much,
Mike
nuckollsr(at)cox.net Guest
Posted: Wed Aug 22, 2007 7:20 am Post subject: Z-19 Clarifications |
At 08:18 PM 8/21/2007 -0700, you wrote:
Hi ,
Contactor "ratings" are much like switch ratings. Many
times a device performs quite well even if it appears to
be under-rated. For example, the S701-1 contactors offered
by B&C as battery contactors are rated to switch 70A but will
carry the starter current of several hundred amps when
they're already closed and stable. Suggest you utilize
the contactors recommended in the drawings and don't get
wrapped around the axle on ratings.
| Quote: | 2. How does the E-bus alternate feed relay work, I am not sure of its
Read chapter 17 in the book. A "lite" e-bus (7A or less) gets
alternate power from the battery bus via direct wire and switch.
Crash safety conventions dictate a "mini" battery contactor located
at the battery bus for larger loads.
| Quote: | Do you normally start with the E-bus relay switch OFF. Then if your
Yes and sorta yes. The main bus should also be shut down during
alternator out operations to maximize endurance in the enroute
phase of flight.
| Quote: | My E-bus load comes up to 9.5 amps. Do I even need the relay?
See chapter 17.
| Quote: | 3. Should both batteries be connected to the same ground point on the
What kind of airplane. See:
http://aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html
| Quote: | 4. Parts - Diodes for the ECU and Fuel pumps - is the B&C Essential Bus
There are virtually thousands of diodes that will function
as needed in this circuit. The parts offered by B&C and
Perihelion are but two such devices cited for your convenience.
| Quote: | In the Z-19 the it says 'Note 24', but I cannot find that in my
Note 24 is on page Z-11 of
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
mikefapex
Posted: Wed Aug 22, 2007 11:11 am Post subject: Re: Z-19 Clarifications |
Bob,
Thanks for your input. I found most of the answer per your referenced documents.
Hmm, I think I see. If you start the aircraft with some initial load that is well below the 'rating' for the contactor, you could increase system load use to above those values (by some amount) since the contactors are already closed and flowing.
My concern is that I am considering a fairly large alternator capable of 90+ amps. I know thats a lot but I am flying open cockpit in Colorado winter. The big load is the addition of heated motorcycle clothing for two people. I was also considering a Z-24 installation with an alternator cut-off contactor and wanted to understand alternator-output to contactor-rating concerns.
Thanks again,
Mike
