air.guerner(at)wanadoo.fr Guest
Posted: Sat Aug 11, 2007 11:37 pm Post subject: Mono wheel tyre |
Niels,
I am using the same Air Trac 8.00x6 and never had this problem. May be this is because I always inflate to 30-35 psi. This provides a better prop clearance and better directional control. I do not think it causes more bouncing on landing.
I suggest you try with higher pressure.
Hope that helps.
Remi
F-PGKL, XS S/N395 monowheel, 912S, Airmaster, 510 hours <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I've just put on a new mono-tyre, McReady Air-trac 8.00 x 6. pumped
to 15 psi.
It turns out that the tyre is in contact with the sides of the wheel
leg, emitting sgueals during taxy like a couple
of fighting piglets.
nielskock(at)get2net.dk Guest
Posted: Sun Aug 12, 2007 10:35 am Post subject: Mono wheel tyre |
Hi Remi
If what I described in my reply to Jim Brown should prove to be unsactisfactory, I certainly
will go for the high pressure. It would, of course, have been a much simpler solution to start with.
But let's see how it turns out.
Niels
