		PGLong
				 Posted: Thu Aug 16, 2007 6:01 pm    Post subject: Starter Wanted |
				A friend of mine is searching for a starter for his project. Think he said it was for a GO-430 Lycoming. He needs a serviceable Bendix 397-4-B starter. Any one help on this one?
 __________________
  |  | - The Matronics Engines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Engines-List |
  _________________ Pat Long
RV-4, N120PL
Bay City, MI |
		gyoung
  Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
				 Posted: Fri Aug 17, 2007 6:19 am    Post subject: Starter Wanted |
				That's better known as an  Eclipse E-80 starter. I've got one on the GO-480 in my Navion. I just had mine  O/H'd by S&T Aircraft Accessories in New Braunfels, TX. They will be very  expensive buying thru a shop. Normal O/H is $750 - mine was ~$1500 due to some  broken parts. Try to find one at a salvage yard or private - it will likely be  much cheaper. The GO's (435 & 480) were used on Helio's, SeeBee's, Twin  Bo's, Queen Airs, Twin Commanders, Navions and others. The E-80 was also  used on Continental E-series engines and a bunch of radials but you can't use  that version..
  There are MANY variations  of the E-80 so it's important to get the right one. The Lycoming version turns  the opposite of most other applications. They call it right hand turning. The  Lyc's model numbers are even numbers. The Continental/radial types have odd  model numbers. The motor can be rewired to turn either direction but the clutch  and dogs are direction specific so you can't really convert. The clutch dogs are  another variable. Mine has 3. The GO-435 probably does too but there are other  possibilities - I've heard up to 10 dogs. The clutch also gets a torque setting  unique to each engine type. That at least can be reset to whatever the GO-435  needs. There are also different style clutches but they are compatible. My "C"  clutch has a rubber seal rather than the leather seal of the "B" and "A". My  data plate is stamped as a model 10C. Then there is voltage - they come in both  12 and 24 which I believe can be changed (not totally sure of that.)
  Once he goes to install  it, there are both positive and negative studs. Normally there is an insulating  washer only on the positive. It does not ground only thru the case like modern  starters. I was told the clutch housing is magnesium and won't carry the  current. Regardless of the reason, plan on a separate ground strap - it won't  work without it. If you need to run it on the bench to determine pos vs neg,  just bump it. DO NOT let it spin up, it can come apart without a load on  it.
  Unfortunately there is no  alternative starter for the GO-480 or GO-435. The downside is it's old and  heavy but otherwise it's a good starter. BTW, what's your friend's  project?
 Greg Young - Houston (DWH)
 RV-6 N6GY - project  Phoenix
 Navion N5221K - just an XXL RV-6A
  [quote]         From: owner-lycomingengines-list-server(at)matronics.com    [mailto:owner-lycomingengines-list-server(at)matronics.com] On Behalf Of    PGLong(at)aol.com
 Sent: Friday, August 17, 2007 6:47    AM
 To: lycomingengines-list(at)matronics.com
 Subject:    Starter Wanted
 This starter mounts on the accessory case. Any one    help on this one?
 __________________
 Pat Long
 RV-4, N120PL
 Bay City, MI
          title=http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982    href="http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982"    target=_blank>AOL.com.
  	  | Quote: | 	 		  | [b]  href="http://www.matronics.com/Navigator?LycomingEngines-List">http://www.matronics.com/Navigator?LycomingEngines-List href="http://forums.matronics.com">http://forums.matronics.com  Free  Date:    8/15/2007 4:55 PM  |
   8/15/2007 4:55 PM
