gus.fraser(at)gs.com Guest
Posted: Tue Feb 14, 2006 9:42 am Post subject: 4340 Alloy steel sheet needed. |
I need to get a specific steel sheet I need not a lot about 4 inches sq of 4340 alloy. The Russian part I am replacing is made of GOST4543-71 who's US equiv is 4340. Trouble is aircraft spruce etc only supply 4340 in bars.
4130 is not quite hard enough.
Any help much appreciated.
See spec below
Gus
steel grade GOST
TU fraction total mass of elements, %
C Si Mn Cr Ni Ti Mo V Co S P
not more than
30čçóá GOST 4543-71 0.28-0.34 0.9-1.2 0.8-1.1 0.8-1.1 0.035 0.035
dsavarese(at)elmore.rr.co Guest
Posted: Tue Feb 14, 2006 9:58 am Post subject: 4340 Alloy steel sheet needed. |
See if these folks can help.
http://www.advancedglobalmaterials.com/4130-4340sheet.asp
Dennis
Alloy Steels
4340Mod
4620
4720
6150
8620
8740
9310
52100
H11
HY60 - 100
D6AC
HP 9 - 4 - 20
300M
HP 9 - 4 - 30
D6-AC
HY - TUF
Maxel 3 1/2
Maraging 250, 300, 350
Aircraft Quality & Vacuum Melted
*All materials available in the following:
Plate, Sheet, Rod, Bar, Tubing, Pipe, Wire, Forgings, Custom Shapes & Sizes
Posted: Tue Feb 14, 2006 10:18 am Post subject: 4340 Alloy steel sheet needed. |
Dennis,
Thanks for that I called them yesterday and they only have larger sizes available. .1 and up. For reference this is the steel used for undercarriage units also.
Thanks again
Gus
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Tuesday, February 14, 2006 12:57 PM
To: yak-list(at)matronics.com
Subject: Re: 4340 Alloy steel sheet needed.
Dennis
Alloy Steels
4340Mod
4620
4720
6150
8620
8740
9310
52100
H11
HY60 - 100
D6AC
HP 9 - 4 - 20
300M
HP 9 - 4 - 30
D6-AC
HY - TUF
Maxel 3 1/2
cgalley(at)qcbc.org Guest
Posted: Tue Feb 14, 2006 1:24 pm Post subject: 4340 Alloy steel sheet needed. |
Have you tried Dillsworth
