Jerry Sprayberry
Joined: 10 Jan 2006 Posts: 15 Location: Summerville, GA
Posted: Wed Aug 08, 2007 5:18 am Post subject: Oil Pressure IGSO 540 B1A |
Moe, and all Commander Folks,
Thanks for your reply on the Oil Pressure, Input's from the other AC 680 Owners and Drivers will be appreciated.
I was not aware that the Oil Pump had a history of being weak, (Morris) said it was capable of up to 400 PSI.
1. I have not checked my O/P Gage, It was ok on the old Engine
2. Columbia Aircraft Services has checked the Pressure at four different places and it is the same.
3. NO. The Pressure drop's to around 63 PSI in flight, Green Band is 70-80.
4. The O/P is OK for Ground OPS with a lot of power, 1500 Plus.
Jerry,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Thanks for the tip, I will contact <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Gary.
Regarding the oil pressure problem. It is generally accepted that the oil pumps on the IGSO 540 series are too small. I can’t remember the GPM (gallons per minute), however, this has been, as I understand it, a long standing problem. Once the pump has in-adequate volume, no amount of spring shimming will raise the oil pressure. Some suggestions: - Have you checked the accuracy of your oil pressure gage? (Laugh, but I have heard some real horror stories)
- Screw an oil pressure gage into the oil galley at the front of the engine and compare the oil pressure on the two gages. Lycoming has a maximum differential that is acceptable, again, I can’t remember what it is, but will look it up for you if necessary.
- Will the oil pressure stay in the green while in flight?
- Will the engine maintain a minimum of 35 PSI at hot idle and about 1,500 RPM (minimum for the fuel pump computer to work)?
Moe
N680RR
680F(p)
Jerry Sprayberry
706 506-3167
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
_________________ Capn Spray |
kamala(at)MSN.COM Guest
Posted: Wed Aug 08, 2007 6:25 am Post subject: Oil Pressure IGSO 540 B1A |
js, there is a ball/socket on the io 720 that when worn or corrosion will cause a lower o/p reading. interestingly enough it will decrease w/ altitude and increase on the way back down. there is a factory fix but suspect at overhaul is most cost efficient time to do it. mason
[quote] From: capnspray_611(at)hotmail.com
Subject: Oil Pressure IGSO 540 B1A
Date: Wed, 8 Aug 2007 09:16:29 -0400
Jerry,
Thanks for the tip, I will contact Gary.
Moe
N680RR
680F(p)
Jerry Sprayberry
706 506-3167
mashley2(at)kc.rr.com Guest
Posted: Wed Aug 08, 2007 7:13 am Post subject: Oil Pressure IGSO 540 B1A |
Hello Jerry,
I am not an engine expert but I have a little hydraulic experience. Here is a viewpoint from a hydraulic perspective.
Pumps - Oil pressure is the measurement of resistance to flow. A pump does not produce pressure, it produces flow. The pump has a pressure rating that is the pressure that it can withstand before failure. With that being said, low oil pressure means that the pump is not producing the same flow as before (defective or worn pump), or the oil has found an alternate path of least resistance (a crack or a missing internal plug in an oil galley).
The function of a relief valve is to protect the hydraulic system from going over a certain pressure setting. A relief valve is a normally closed valve that only opens when oil pressure exceeds the spring setting. A faulty relief valve (weak spring or valve does not completely reseat therefore it is leaking) will also cause low oil pressure because it is opening before the desired pressure setting.
The most likely cause of low oil pressure would be a pump not producing correct flow (faulty or worn pump) or relief valve opening before desired system pressure (spring setting) is achieved (faulty spring or valve seat).
I hope this helps!
Myron Ashley
CloudCraft(at)aol.com Guest
Posted: Wed Aug 08, 2007 7:28 am Post subject: Oil Pressure IGSO 540 B1A |
Jerry,
In my days of IGSO-540 flying, it was suggested that an oil pressure drop that could not be adjusted at pump output was a sign of a main bearing going bad.
Hard to imagine that with a recent o/h engine but stranger things have happened.
Wing Commander Gordon
AOL.com.
moe(at)rosspistons.com Guest
Posted: Wed Aug 08, 2007 8:57 am Post subject: Oil Pressure IGSO 540 B1A |
Jerry,
The oil pump on these engines seems to be capable of lots of pressure, but not much volume. It is entirely possible to have a pump which will put out lots of PSI pressure at a very low volume, but as the volume demand increases (too much clearance between the rod and/or main bearings and the crankshaft, a missing oil spray nozzle for the underside of the pistons, ect.) the pressure goes down dramatically. Myron and Wing Commander Gordon are correct. Generally, if the engine is very worn with lots of clearance between the worn parts, which allows the oil to escape back into the sump using the path of least resistance, your biggest problem will be at hot idle (low oil pump speed and lots of clearance for the oil to squirt out at). When I had two very worn engines in my bird the oil pressure would barely stay in the green in the air, however, on the ground and hot there was not enough oil pressure (below 35PSI) to make the fuel metering system work, so it would run so rich that it was hard to keep it lit when landing, and you had to manually lean it out on the roll out.
Since you can maintain pressure at high idle (1,500 RPM) on the ground, but not at higher RPM, based on my old race car experience, be sure that the inlet oil line from the tank to the pump does not have a “flapper” in it that is reducing the amount of oil that is available for the pump. Check all of the fittings on the inlet side for restrictions. In short be sure that the line from the dry sump tank to the oil pump is not restricted. Did you say that the pump relief spring was already shimmed with seven washers when it came from Perf. Aero, or did someone else add these at a later time?
Moe
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jerry Sprayberry
Sent: Wednesday, August 08, 2007 6:16 AM
Jerry,
Moe
N680RR
680F(p)
Jerry Sprayberry
706 506-3167
| Quote: | | http://www.matronics.com/Navigator?Commander-List | 01234
Jerry Sprayberry
Posted: Wed Aug 08, 2007 1:22 pm Post subject: Oil Pressure IGSO 540 B1A |
Moe,
The Engine was delivered in a crate with Performance Engines written on all sides.
I unpacked the engine and removed the clear plastic wrapping myself, The washers were in the regulator.
We found the washers when we tried to adjust the pressure to 75 PSI at 2200 RPM.
JS
