Fixed or removalble wing tips?
michaega(at)verizon.net
PostPosted: Tue Aug 07, 2007 7:32 am    Post subject: Fixed or removalble wing tips? Reply with quote
Yes a trivial question. Is their a good reason to but all that hardware at the end of the wing to make them with removable tips. [quote][b]
akanka(at)kiamichiwb.org
PostPosted: Tue Aug 07, 2007 8:37 am    Post subject: Fixed or removalble wing tips? Reply with quote
In my opinion, yes. If any repair needs to be done to the position light mounting, the end of the wing, or to inspect the interior of the wing, the removable tips make it a lot easier than cutting the material to accomplish that task. Removing mice and bird nests from the wing interior is really difficult if the tips are not removable. If, for example, there are no position lights and a person wants to install them after the aircraft is built, removable tips make it easier to run the wires and mount the lights. If position lights are installed during construction, and an owner wishes to install strobes on the wingtips at a later time, it's a lot easier with removable tips. In my opinion, installing removable wingtips is a whole lot like painting a floor. Just another way to avoid painting yourself in to a corner.
John Hart
[quote] --
Michel
PostPosted: Tue Aug 07, 2007 9:02 am    Post subject: Fixed or removalble wing tips? Reply with quote
Good point, John. Now, my model 3 has drooping winglets attached by
pop-rivets. How do I make them removable? With "rivnuts?" Incidentally,
it was when reading the "windshield installation" thread that I learnt
about these things. Never heard of it before. I am not sure where to
get them over here but I see that Aircraft Spruce has them.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
lcfitt(at)sbcglobal.net
PostPosted: Tue Aug 07, 2007 9:11 am    Post subject: Fixed or removalble wing tips? Reply with quote
Sue,
I made mine permanent. I did, however make what I call "doors" as I made
plastic lenses that allow for internal nav lights with the strobe tube
mounted like on the early Glasair. I do remove the doors each annual and it
does allow for a limited amount of access to the wiring and for inspection
of that part of the wing structure. It is interesting that with the access
for inspection, I have yet to find anything that I have been concerned with.
The structure looks exactly as it was assembled back in 1994 down to the
color of the wood and the integrety of the epoxy varnish. My guess is that
the airplane has spend about 80 overnights outdoors with some rain and a
couple of hard freezes since built during cross country flights, the rest in
a hangar.
I guess my advice would be to project your airplane's likely exposure level
and your desire to check out the wing tip area from time to time.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 880 hrs.
PostPosted: Tue Aug 07, 2007 9:54 am    Post subject: Fixed or removalble wing tips? Reply with quote
Well, I don't know exactly what's in there along the end rib on your
aircraft, but I'd think a piece of aluminum could be formed to fit against
the rib, then use adhesive and rivets to permanently attach it, then put
rivnuts through the aluminum, and screws thru the wingtip into the rivnuts
to hold it on.
John Hart
Float Flyr
PostPosted: Tue Aug 07, 2007 11:08 am    Post subject: Fixed or removalble wing tips? Reply with quote
Any aviation supply dep0ot should have rivnuts in several different sizes. They are not as strong as bucked rivets but probably stronger than aluminium pop rivets. Don't forget to order an installation tool too.
[img]cid:868420219(at)07082007-26CF[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  357 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Michel
PostPosted: Fri Aug 10, 2007 12:40 pm    Post subject: Fixed or removalble wing tips? Reply with quote
too.
Thank you, Noel, I will look at that.
Michel Verheughe
Norway
Michel
PostPosted: Fri Aug 10, 2007 12:41 pm    Post subject: Fixed or removalble wing tips? Reply with quote
aircraft
Nor do I, John, since I haven't built my aircraft. But I'll look at it
on a rainy day. Thanks for your answer.
Michel Verheughe
Norway
Lynn Matteson
PostPosted: Fri Aug 10, 2007 1:33 pm    Post subject: Fixed or removalble wing tips? Reply with quote
In my sometimes not-so-humble opinion, all metal anchor nuts far
outweigh rivnuts in a couple of ways....weight being one of
them...yes, they weigh more, but they won't ever turn once they are
riveted onto the material to which they are attached. I've been
warned against using the rivnuts if you can possibly get behind the
area where the "nut" is to be installed. If the rivnut and its screw
ever seize up, the rivnut will break loose from the backing material,
and you'll have to drill it out...IF you can get the drill to
actually drill, and not just rotate the whole business. On the other
hand, the two rivets that hold an anchor nut in place will seldom
ever shear off, should the "nut" and screw ever seize up in a similar
situation.
I installed my wingtips with the kit that Skystar sold, (John and
Debra probably have them) which included anchor nuts and attaching
strips, and I attached my windshield/skylight using the same
method...anchor nuts attached to the butt rib capstrips.
Another plus is not having to buy the Rivnut tool.
Lynn Matteson
Grass Lake, Michigan
flying w/369+ hrs
Incidentally, it was when reading the "windshield installation"
thread that I learnt about these things. Never heard of it before.
I am not sure where to get them over here but I see that Aircraft
Spruce has them.
Michel Verheughe
Norway
Lynn
Kitfox IV-Jabiru 2200
N369LM
Float Flyr
PostPosted: Fri Aug 10, 2007 5:44 pm    Post subject: Fixed or removalble wing tips? Reply with quote
There is a special tool that helps in the spacing of the holes for the
anchor nut Wink Hard to get away form "special" tools.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Michael Logan
PostPosted: Sat Aug 11, 2007 5:10 am    Post subject: Fixed or removalble wing tips? Reply with quote
Keep the longer wings, you will never put them back on if you take them off. You get off the ground quicker and have a higher gross weight.
Mike
S 5 Subaru EA81
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of SUE MICHAELS
Sent: Tuesday, August 07, 2007 11:31 AM
Subject: Fixed or removalble wing tips?
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Mike Logan
Fredericksburg, VA
Lynn Matteson
PostPosted: Sat Aug 11, 2007 5:11 am    Post subject: Fixed or removalble wing tips? Reply with quote
I just use the anchor nut itself...drill for the screw, locate the
nut and cleco it on the top of the base material, drill through one
hole, cleco, and drill through for the other hole, remove and drill
the center hole slightly oversize for the screw. Install anchor nut
from below with a screw from above, cleco one side and install rivet,
then remove cleco and install the other rivet. If you want, you can
wait until riveted to oversize the center hole, making sure not to
get down into the threads of the anchor nut.
Lynn Matteson
flying w/369+ hrs
Noel
Lynn
N369LM
