rampil
Posted: Mon Aug 06, 2007 11:33 am Post subject: A new air-data system tricket for Europas |
Last year I installed this 5-hose rapid disconnect between my panel and
fuselage for my airdata tubing (I have an AOA (2 tubes) aside from the
usual Pitot static.
It has worked quite well for the past year and I am now installing another
in my port wing root. I thought other Europaphile might want to evaluate
it for their application.
I obtained them from Cumulus Soaring and they obtain it from Winter
Instrument in Germany. About $35.
2.52 MB |
410 Time(s) |
keithhickling(at)clear.ne Guest
Posted: Mon Aug 06, 2007 10:29 pm Post subject: A new air-data system tricket for Europas |
Ira,
This 5 hose rapid connector looks nice. My AOA has small diameter tubing,
around 1.5 or 2 mm ID I think, though my pitot and static are the standard
Europa size. Does Winter have different size ports available for different
diam tubing?
Keith Hickling,
New Zealand.
rampil
Posted: Tue Aug 07, 2007 6:09 am Post subject: Re: A new air-data system tricket for Europas |
Hi Keith,
I do not believe that Winter supplies any other than described.
The OEM that actually manufactures the connector might, but it might
be easier to use brass or plastic fittings to change the tubing size
