larywil(at)comcast.net Guest
Posted: Sun Aug 05, 2007 7:11 am Post subject: Something We Really Need |
Hi gang,
Many of us have problems with the expense, and availability of
hangars for our RV's. At over $400/month for a "T" in the
Philadelphia area if you could even find one, I and several others
have discussed tie down solutions. None of which are palatable. Any
one who ties down his/her aircraft outside will have to find a
temporary hangar in which to do repairs and maintenance. That's OK,
do-able. But few of us live in a geographical area that is
acceptable for long-term outside storage in terms of heat cold and
moisture. I have recently spent some time in the almost perfect
weather of Albuquerque and Santa Fe, and still find them only
marginal for long term outside storage of an RV.
What many of us really need is a solution that consists of some sort
of shell that covers and protects our aircraft, can be removed
easily, and would be acceptable to the airport and insurance
companies (We don't want the thing blowing away and damaging other
aircraft). Do any of you on this list have any ideas how to create
the "Tie Down Hangar" I am conceptualizing? It would be worth a
fortune to the person who can create and provide a secure "Tie Down
Hangar" that the airport would find acceptable.
Louis I Willig
1640 Oakwood Dr.
Penn Valley, PA 19072
610 668-4964
RV-4, N180PF
190HP IO-360, C/S prop
wdleonard(at)gmail.com Guest
Posted: Sun Aug 05, 2007 11:21 am Post subject: Something We Really Need |
I'm with you, we really do need something (not really an entirely new idea I'm sure). One problem is that my airport will not allow any kind of a tarp or awning. Whatever it is would have to be entirely supported by the aircraft itself...
I have been thinking about some sort of tarp that will cover the canopy area supported by clamps on the wings or fuselage. But a reasonable design escapes me.
David Leonard
Turbo Rotary RV-6 N4VY
http://N4VY.RotaryRoster.net
http://RotaryRoster.net
On 8/5/07, Louis Willig <larywil(at)comcast.net (larywil(at)comcast.net)> wrote: [quote]--> RV-List message posted by: Louis Willig <larywil(at)comcast.net (larywil(at)comcast.net)>
Hi gang,
bjust(at)cox.net Guest
Posted: Sun Aug 05, 2007 11:46 am Post subject: Something We Really Need |
The Plane Pocket may be a suitable alternative.
http://www.planepocket.com/
shempdowling2(at)earthlin Guest
Posted: Mon Aug 06, 2007 1:31 pm Post subject: Something We Really Need |
How about the aerolift.
Jeff
Louis Willig wrote:
Hi gang,
Many of us have problems with the expense, and availability of hangars
for our RV's. At over $400/month for a "T" in the Philadelphia area if
you could even find one, I and several others have discussed tie down
solutions. None of which are palatable. Any one who ties down his/her
aircraft outside will have to find a temporary hangar in which to do
repairs and maintenance. That's OK, do-able. But few of us live in a
geographical area that is acceptable for long-term outside storage in
terms of heat cold and moisture. I have recently spent some time in
the almost perfect weather of Albuquerque and Santa Fe, and still
find them only marginal for long term outside storage of an RV.
of shell that covers and protects our aircraft, can be removed easily,
and would be acceptable to the airport and insurance companies (We
don't want the thing blowing away and damaging other aircraft). Do any
of you on this list have any ideas how to create the "Tie Down Hangar"
I am conceptualizing? It would be worth a fortune to the person who
can create and provide a secure "Tie Down Hangar" that the airport
Louis I Willig
1640 Oakwood Dr.
610 668-4964
RV-4, N180PF
Posted: Mon Aug 06, 2007 3:43 pm Post subject: Something We Really Need |
At 05:30 PM 8/6/2007, you wrote:
Jeff
The aerolift fills some needs, but does solve the problem of having
no hangars available. Most people do not want to share a private
hangar with an aerolift.
