Oil thermostatic by pass valves.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
waltmurphy(at)charter.net
PostPosted: Sun Aug 05, 2007 11:12 am    Post subject: Oil thermostatic by pass valves. Reply with quote
Question:
Does anyone know just exactly how far the vern a therm ( by pass valve )
is supposed to stretch when at temperature?
We have an oil temp problem and the by pass valve was replaced. ( ECI
PMA replacement part ) . It did not solve the problem. Looking at the
NEW part there was NO wear mark at all on the seating face of the valve.
Placing it into a cup of boiling water it grew 0.107 from the ambient
length. I also measured another ( old Lycoming part ) it grew 0.180
Also when I look at the ECI part in the oil filter adapter housing , it
sits deeper than the Lycoming part. ( It appears that the ECI part would
need to "grow" over 1/4 inch to make contact compared to maybe 1/16 to
1/8 inch on the Lycoming part.
Walt
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
esmith6(at)satx.rr.com
PostPosted: Sun Aug 05, 2007 12:30 pm    Post subject: Oil thermostatic by pass valves. Reply with quote
Walt...................Lycoming Engines, 652 Oliver St., Williamsport, Pa.
17701.........570-323-6181..........Ask for "SUPPORT CENTER." 0800-1700
EDT, Mon-Fri...I'm sure the engineers will have an answer for
you.....................................www.lycoming.textron.com/index.jsp
CHEERS!!!! and good luck.............Gene Smith.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
