mbrenner(at)htc.net Guest
Posted: Wed Aug 01, 2007 10:06 am Post subject: Comm won't transmit |
I just started flying off the test hours on my Zodiac 601 HDS. Everything seemed to be operating normally
until I realized today that I'm getting a very weak transmission on my ICOM A200 Comm. The reception is fine
but today when I was trying to communicate with another aircradft at my non-towered field it became obvious that
the other pilot couldn't hear me. When I got back on the ground I asked another pilot to see if I was transmittting.
He said the signal was very weak on the first transmission and then non-existent on subsequent transmissions. The
radio is wired through a Flightcom intercom. I have the transmission problem regardless of whether I have the intercom
switched to "All" or "Iso". Reception is fine either way.
I did notice that when I push the PTT button, the LED on my Ray Allan trim indicator goes out, which seems rather odd
but may be a clue as to what is going on . When I release the PTT button the LED comes back on. I'm guessing I have
a short in the PTT circuit but before I start ripping things apart I'd like some opinions on what to check first. Thanks.
Mike Brenner
Zodiac 601 HDS
Posted: Wed Aug 01, 2007 11:07 am Post subject: Comm won't transmit |
Mike,
Though you didn't say the trim and com buttons are in near proximity on
the stick, I'd check that proximity and work toward isolating the com
from any wires or common connections. It could be a wire crossing
another, but the most logical is a connection near the switches.
Look carefully at your comm wires first working back thru to the radio
if it's involved and fuses. I'm using a A200 with a Sigtronics intercom
that
had problems with the main Molex plugs and Molex Connector in the back
of the radio. Making good connections back there is crucial. None of
the Molex plugs and wires in the rear of the A200 should be loose or
wobbly. My reception and transmit were soft until that Molex Connector and
the Molex plugs (purchased from Mouser components ) was replaced by a
professional.
Mike Brenner wrote:
| Quote: | I just started flying off the test hours on my Zodiac 601 HDS.
Mike Brenner
Zodiac 601 HDS
frank.hinde(at)hp.com Guest
Posted: Wed Aug 01, 2007 11:17 am Post subject: Comm won't transmit |
My first guess is you have a bad ground. The ICOM will consume the most power when it is transmitting. The fact that it does something weired with a totally unrelated piece of equipment when demanding a lot of current normally always means bad grounding.
Frank Rv7a...Ex Zenair Zodiac 601HDS.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Brenner
Sent: Wednesday, August 01, 2007 10:58 AM
Subject: Comm won't transmit
Mike Brenner
Zodiac 601 HDS
aadamson(at)highrf.com Guest
Posted: Wed Aug 01, 2007 12:07 pm Post subject: Comm won't transmit |
Mike, it sounds like you are getting RFI into other things when
transmitting... I'd suspect the antenna connector(ions). While it might RX
just fine, a bad connection will make TX flaky and will spew RFI around that
will make trim indicators do odd things and other things work funky too.
Check the Sheild on the connector and also the center pin and remember, just
because it shows good at DC, doesn't mean it works at RF.
Alan
Posted: Wed Aug 01, 2007 1:51 pm Post subject: Comm won't transmit |
Larry,
The trim switch and LED are both on the panel and PTT is on the stick so I'm pretty sure it isn't a switch crossover problem. I will check the ground and the connector tomorrow. I also have a headset with a PTT button on one of the ear muffs. I've never used it before but I'll try transmitting with that and see what happens.
Mike Brenner
mprather(at)spro.net Guest
Posted: Wed Aug 01, 2007 3:12 pm Post subject: Comm won't transmit |
Hello Mike,
I sort of doubt that the problem is actually with the PTT button..
Looking at the manual for the radio:
http://www.icomamerica.com/downloads/manuals/avionics/ic-a200.pdf
I notice that the display has a "TX" indicator which should be visible
whenever the transmit circuit is being selected by the PTT button. I'd
guess that a problem with the PTT would cause the "TX" indicator to
flicker, and the output to be noisy, but have normal strength..
I agree with the other posters that have suggested checking the RF side of
things. It appears that energy broadcast from the antenna is low, and
likely is being lost within the airframe - as evidenced by other circuitry
being affected - trim circuit.
A few questions:
- Is this overall installation typical of other 601's?
- Is the antenna mounted to an aluminum skin?
- What kind of antenna are you using?
- What's the cable routing like?
- What kind of coax and connectors are you using?
- Do you have a copy of the Aeroelectric Connection?
Good luck.. Let us know what you find.
Matt-
| Quote: | I just started flying off the test hours on my Zodiac 601 HDS. Everything
Mike Brenner
Zodiac 601 HDS
Posted: Wed Aug 01, 2007 4:01 pm Post subject: Comm won't transmit |
Mike,
The grounds on that Molex plug need to be solid and not wobbly. Frank
is right about the grounding. Molex contact terminals in that plug
are easy to bend and foul. The wires should feel secure and not "loose
in a hole". Placing the wiring for these plugs is something I screwed up
badly. The Molex plug that is part of the A200 mounting rack is one that
the buyer/builder gets to wire and that was the part that
gave me all the trouble. See image of Molex plug on mount rack. I have
a removable forward top skin, so the fix was only difficult
to get to from above between tank and radio rack. I found the
transmission signal would go quiet to very loud when I fingered the
loose ground
wires coming out of this Molex plug which ultimately was replaced as
were the contact terminals. I'd suggest you turn it on and "finger those
wires"
coming out of the plug to see if your signal strength changes on transmit.
http://www.macsmachine.com/images/electrical/full/encoder.gif
Good luck,
Larry
Mike Brenner wrote:
| Quote: | Larry,
Mike Brenner
