Posted: Sat Jul 21, 2007 6:50 pm Post subject: NSI transmission breather |
I forgot who asked, but I didn't see a reply to the
question about the NSI GB breather.
The person to talk to is Peter Graichen. He has a
good number of mods for his plane pictured on his web
site and I think this breather is there too.
Peter, can you post your web site link again, or at
least the breather pic?
Kurt Schrader
S-5/NSI turbo
Florida and Panama
Check out tonight's top picks on Yahoo! TV.
http://tv.yahoo.com/
m4785(at)bellsouth.net Guest
Posted: Sat Jul 21, 2007 7:06 pm Post subject: NSI transmission breather |
Kurt its me again ...oh shit landing guy
hey you are not that far from me ,do you want to get together and fly our foxes
I live near palatka and gainsville,no one around me flys there birds...all a bunch of hanger pilots..lol
PS: I hope you dont think im gay...we can pic up a couple of chics while were out...
See ya .....Mark N61AC
Quote: |
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Date: 2007/07/21 Sat PM 10:50:02 EDT
Subject: Re: NSI transmission breather
Kurt Schrader
S-5/NSI turbo
Florida and Panama
n10pg(at)neo.rr.com Guest
Posted: Sun Jul 22, 2007 5:16 am Post subject: NSI transmission breather |
Hi Kurt,
I hope these pixs help
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
Description: |
Filesize: |
30.15 KB |
Viewed: |
221 Time(s) |
Description: |
Filesize: |
19.23 KB |
Viewed: |
221 Time(s) |
Description: |
Filesize: |
30.96 KB |
Viewed: |
234 Time(s) |
Description: |
Filesize: |
30.69 KB |
Viewed: |
221 Time(s) |
Description: |
Filesize: |
19.23 KB |
Viewed: |
231 Time(s) |
GENTRYLL(at)aol.com Guest
Posted: Sun Jul 22, 2007 6:36 am Post subject: NSI transmission breather |
Thanks Peter,
Looks like a simple setup. It looks like oil goes all the way to the reservoir. Is that correct?
wingsdown(at)verizon.net Guest
Posted: Sun Jul 22, 2007 7:29 am Post subject: NSI transmission breather |
OK,
My bad. Should have looked and listened a bit closer. I didn’t realize
it was a different redrive. I will go back to seep now.
Rick
Posted: Sun Jul 22, 2007 7:33 am Post subject: NSI transmission breather |
FWIW,
I was told by Lance some time ago that the breather is actually detrimental. The mist created in the gear set is beneficial to lubrication. The vent diminishes this from forming. If the seal are good and the unit is not over filled there should be no need for one. I never needed one in 600 hours of operation. Please I don't care to get commentaries on Lance and get off topic. This is my general understanding of the closed reduction system and how it worked for me.
Rick
Posted: Sun Jul 22, 2007 11:06 am Post subject: NSI transmission breather |
Hi Rick:
As you can see from the pixs I posted, I made a connection from the gearbox bottom drain to a plastic overflow bottle. The tube goes all the way to the bottom of the overflow bottle. The overflow bottle is vented. As the gearbox heats up during operation the internal pressure increases considerably without this vent. This does lead very easily to oil leaks around the seals.
During operation the pressure buildup expells about 5 fluid ounces of oil into the overflow bottle. As the gearbox cools after shut down, it sucks all the oil back into the gearbox. It is basically the same setup as the coolant overflow. As far as oil mist within the gearbox is concerned, I can not see where my setup would make any difference.
Peter Graichen
[url=http:/home.neo.rr.com/n10pg/kitfox.htm]http:/home.neo.rr.com/n10pg/kitfox.htm[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of GENTRYLL(at)aol.com
Sent: Sunday, 22 July, 2007 10:36
Subject: Re: Re: NSI transmission breather
Thanks Peter,
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Sun Jul 22, 2007 2:27 pm Post subject: NSI transmission breather |
Peter,
Since some oil obviously drains out of the gear box and into the tube, do you just try to add enough oil to start with to make the oil level in the gear box and the tube about the same height as the top of the gear box, or do you allow some space there also?
Float Flyr
Posted: Sun Jul 22, 2007 5:46 pm Post subject: NSI transmission breather |
Why is your breather out of the bottom of your redrive instead of the top?
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Fri Jul 27, 2007 7:18 am Post subject: NSI transmission breather |
Looks like you helped (again) Peter. Price of being a
leader.
Kurt Schrader
S-5/NSI turbo
Florida/Panama
--- Peter Graichen <n10pg(at)neo.rr.com> wrote:
Peter Graichen
Posted: Sun Jul 29, 2007 7:44 pm Post subject: NSI transmission breather |
I fill the gearbox with the specified quantity. In my case that is 850 ccm.
Peter Graichen
Sent: Sunday, 22 July, 2007 18:25
Peter,
