josok-e(at)ukolo.fi Guest
Posted: Fri Jul 27, 2007 7:20 am Post subject: anr headsets |
If there is still somebody around and not redoing tail planes or visiting Oshkosh:
While i have a pair of very well rated David Clark headsets, my test pilot suggested that ANR would be better. I tend to agree, because these passive sets are probably tuned to reduce the noise of Lycosauruses and the like. So, if you have experienced the one and the other, what's your opinion? I know already which is the most expensive one. They have an offer for CFI's, which they no doubt charge back on the end user. Don't have to say that i hate that kind of "marketing" Smells of a bribe. So is there a good, less expensive alternative?
Kind Regards,
Jos Okhuijsen
Visit - www.EuropaOwners.org
willie.harrison(at)tinyon Guest
Posted: Fri Jul 27, 2007 8:42 am Post subject: anr headsets |
Hello Jos
I have used three types of anr. My experience is that you get what
you pay for. I used a cheapo "Pilot" set for several years. They were
OK, they worked reasonably well but they were not robust: the strain
relief on the cable was inadequate and a solder joint failed at an
"inconvenient" time; also, one of the jack plugs fractured when it
took a small knock. I also used an ebay bargain second hand Peltor
set which I believe was only marketed in the US. That was rubbish on
active noise reduction although like all Peltors it has good passive
noise reduction and is very tough. I decided to stop messing around,
and so I bought a Bose set 2 years ago. Astonishingly expensive but
the best of the three I've used. The passive nr on it is minimal but
the active nr is terrific. Fortunately, my wife never saw the invoice...
One other thought. I have some special earphones for use on a
motorbike (iPod, satnav etc). These are moulded to the shape of the
individual customer's ear so they allow almost zero ambient noise in
and therefore enable you to hear with the sound volume at quite a low
level. The supplier (Ultimate Hearing) told me they could make a set
if I wanted with the right impedence and the right jack plug to work
in an aircraft - it might make a useful experiment although it would
need an additional mike, of course.
Best wishes
Willie
On 27 Jul 2007, at 16:16, josok wrote:
visiting Oshkosh:
Kind Regards,
Jos Okhuijsen
rholder(at)avnet.co.uk Guest
Posted: Fri Jul 27, 2007 10:06 am Post subject: anr headsets |
Second attempt - one picture in each mail !
Dear Jos and all Europaphiles
Wow an opportunity to push what I do ! Sometimes.
So long as you don't have H20-10 (H10-20 is OK)
I convert headsets to ANR using a kit from Headsets Inc in
the US. I have done quite a few.
Two ways of doing it (actually also others) as per the
pictures
attached.
I don't do it quite the way they suggest but my method is
an improvement !
In my Europa I do not have jack sockets. I have 5 pin XLR
sockets and my headsets are converted with the ANR modules
and they take their power from the XLR socket. I have an
adapter if someone wants to use their own non-ANR-non-XLR
headset.
I could take pictures.
If you want to retain the jacks then I could provide two
sockets-with-9v-regulator-chip for installation in your
plane. This is shown with the new lead in the "AMP_2"
image, and you would get battery boxes to go with the
headset if you took it to another plane.
Or I could sell you the kit(s) and cables, it isn't rocket
science !
eMail me direct for further details
The ANR effect is not as good as Bose but it is 1/4 of the
price, and avoids having yet another headset or two
stuffed in a drawer. It is, however, as good as, or even
better than the DC ANR set.
Richard Holder
G-OWWW High Cross, ungrounded as of today (for 10 hours !)
josok wrote:
<josok-e(at)ukolo.fi>
161.89 KB |
346 Time(s) |
The other picture
Richard Holder
G-OWWW High Cross
671.59 KB |
350 Time(s) |
jimpuglise(at)comcast.net Guest
Posted: Fri Jul 27, 2007 10:36 am Post subject: anr headsets |
Jos-
There was an excellent article in Kitplanes about a year ago comparing them all. They rated one of the Telex sets as best bang for the buck. I tried the set on at Lakelnad last year and liked if very much. I don't remember the model, but I'm sure someone at Telex could help. Also, Kitplanes will reprint an article for a fee. You may want to e-mail them and see if you can get a reprint. My magazine is gone.
Jim Puglise
BTW - Got that hinge off with no problem using a solering iron and razor blade. Thnks !
[quote]-------------- Original message --------------
[quote] --> Europa-List message posted by: "josok"
Oshkosh:
carl(at)flyers.freeserve. Guest
Posted: Fri Jul 27, 2007 11:08 am Post subject: anr headsets |
ANR Headsets
A word of warning on the use of ANR headsets. If your intercom setup dosent
include squelch on the mic circuit it can make the best headsets appear
worse than useless. Our intercom was built into the ICOM A2000 radio and
these do not have any microphone squelch.
We initially used a set of cheapo "Skyforce" ANR headsets and to be honest
they werent up to much (or so we thought).
So we upgraded to a middle of the range Sennheiser HMEC300 and there was
little or no improvement - that is till we realised the mics were picking up
the cockpit noise and feeding it back through the intercom. We have now
fitted a separate (portable) intercom with separate squelch control and the
reduction in noise levels is considerable.
If you arent sure if the mics are feeding excessive noise into the amplifier
circuit try muffling them with a towel and seeing what difference this makes
to incoming transmissions (or simply to the ambient noise in the headsets) -
in flight of course.
Im not saying dont buy ANR as I would opt for them every time. Given the
choice I would have opted for the BOSE ones it was a hell of a job
persuading Mrs P that £350 (each) was worth spending never mind £600 !!!
Carl Pattinson
G-LABS
BTW - IMHO noise cancelling microphones dont seem to cancel out very much
noise - maybe someone with a superior technical understanding might
volunteer an explanation.
Posted: Fri Jul 27, 2007 12:31 pm Post subject: anr headsets |
Hi Richard,
If it's possible to equip my DC's 20-10 with ANR, i will be very happy. But please explain a bit how it's working, is there a mike on the box or on the headphone(s) to pick up the sound to be neutralized? How much work is involved in the change-over? Btw, i have an Xcom radio, with a built in proper intercom, with good intercom squelch.
Did a spectrum analysis on a pair of great sounding Bose speakers once, to discover that the frequency response was not even close. This was after complaints from a customer, a violin builder. But that was 20 years ago.
Jos Okhuijsen
topglock(at)cox.net Guest
Posted: Fri Jul 27, 2007 3:31 pm Post subject: anr headsets |
I have a couple of Lightspeed 15xc's which work just fine. At $350 USD,
the price wasn't bad, either. Don't know if they are still available,
though...
Jeff - Baby Blue
304 hrs
josok wrote:
Kind Regards,
Jos Okhuijsen
sidsel.svein(at)oslo.onli Guest
Posted: Fri Jul 27, 2007 9:59 pm Post subject: anr headsets |
Jeremy,
To your question:
| Quote: | I have heard it said that the Bose ANR headsets (Aviation X) aren't
brilliant with a Rotax - due to the frequencies being so much higher than
with a Lycosaurus. Can anyone out their comment?
I have used this headset for about two years, but have no experience with
other ANR sets. To my ears they are as effective (and very noticeably
effective) in my Europa with Rotax as in Cessna 172s and Piper Cherokees
with Lycomings.
Apart from the comfort of much less noise in the ears, a side effect is that
you speak in a more normal voice on the radio - no need to "shout" to
overcome noise. Also, using the cell phone via an adapter (I have
SafetyCell's) for the headset's mike and headphones works fine.
I have padded the metal going over the top of my head to avoid scratches in
the window in bumpy air.
Svein
LN-SKJ
TELEDYNMCS(at)aol.com Guest
Posted: Sat Jul 28, 2007 3:48 am Post subject: ANR Headsets |
In a message dated 7/28/2007 2:58:40 AM Eastern Daylight Time, europa-list(at)matronics.com writes:
| Quote: | I have a couple of Lightspeed 15xc's which work just fine. At $350 USD,
though... |
Hey Jeff,
I will echo what you've said about Lightspeed. I have a set of 20XL's and I've been using them almost daily for about 5 years now. They were under $400/ea from Spruce. I've used them both with the Europa/Jabiru and the Ximango/Rotax and they work equally well. I've also used them in a Pawnee, Citabria, C-210, Navion and a T-6 excellent results. Battery life for the ANR seems to be in excess of 40 hours on two AA batteries. I once broke part of the earpiece after sitting on it and Lightspeed sent replacement parts at no charge.
My only gripe is the audio quality from my XM radio isn't the best, IOW, not enough bass response. However, after looking at the schematic for my Flightcom intercom, the lack of bass in the audio probably has more to do with the size of the capacitors they used in the intercom as opposed to a problem with bass response in the the 20XL's. I would highly recommend Lightspeed headsets.
John Lawton
Whitwell, TN (TN89)
N245E - Putting the pieces back together after annual inspection
Dave Miller
Posted: Mon Jul 30, 2007 6:15 am Post subject: anr headsets |
I borrowed a friends Bose headset, and was not that impressed due to the lack of passive noise reduction.
I did not realise how much high frequency clatter the 912S generates.
Checking the ANR headsets at Oshkosh last year, I liked the Sennheiser, had excellent passive reduction, but priced
high enough to make me stay with my old Sigtronics set for the time being.
Dave A061
"Jeremy Davey" <europaflyer_3(at)msn.com>
Sent by: owner-europa-list-server(at)matronics.com
07/27/2007 06:05 PM Please respond to
To
<europa-list(at)matronics.com> cc
Subject
RE: anr headsets
--> Europa-List message posted by: "Jeremy Davey" <europaflyer_3(at)msn.com>
Jeremy
