rholder(at)avnet.co.uk Guest
Posted: Mon Jul 23, 2007 8:42 am Post subject: Mod 73 listing |
Team
I don't know if anyone else has been having trouble
reading the list of completed Mod 73 aircraft. I have. I
just get a list with one item on each line.
I have taken the liberty of creating something much more
readable in .pdf format. Of course it is non-editable, but
I suggest that all other reports should come to me and I
will add them to the list and republish - say twice a
week. I am fairly certain that after the "tag your details
onto the end of this" approach, several sets of info have
been lost. I took this list from trevpond's email of this
afternoon.
To that end please check the attached .pdf and mail me
direct with any omissions, changes or additions.
The bad news is that when I post my results I will end up
destroying the perfect symmetry of "no TP6 disbonding
found"
Richard Holder
G-OWWW High Cross
Mod73-20070723.pdf |
22.63 KB |
313 Time(s) |
riddon(at)sent.com Guest
Posted: Mon Jul 23, 2007 9:52 am Post subject: Mod 73 listing |
Richard.
Thanks for taking this on. I have attached the most complete spreadsheet that I have managed to compile from results posted on the forum.
I also paste it below. You should be able to read one or the other.
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365
Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
46
Grass
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
320
Both
Completed
None found
Original
None
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Very slight movement in starboard TP12. Present on installing (1998)- no worse
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
2in.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
20
mixed
Completed
None found
1.9in.
none
Graham Drake
UK
G-CCOV
Mono
60
Mostly Hard
Completed
None found
2in.
Sarah Attubato
UK
G-BWDP
Mono
N/A
N/A
Completed
None found
2in.
These are new replacement tailplanes that had already been built
David Watts
UK
G-BXDY
Mono
1250
Mostly Grass
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
Mike Clews
UK
G-OMIK
Mono
500
Grass
Completed
None found
Original
nothing major
Arthur Orchard
uk
G-JOST
Tri Gear
17.5 hrs
Tar/Mac
completed
none found
original
nothing found
Colin Smallwood
UK
G-DEBR
Tri Gear
Tarmac
W.I.P
None found
2in
TP5 Port,Moved .25" Outboard
Alasdair Milne
UK
G-CBYN
Tri Gear
Completed
None
original
none
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
Richard Iddon G-RIXS
Mod_73.xls |
25 KB |
280 Time(s) |
gregoryf.flyboy(at)comcas Guest
Posted: Mon Jul 23, 2007 10:05 am Post subject: Mod 73 listing |
On July 23rd, Richard wrote:
| Quote: | I have taken the liberty of creating something much more
It doesn’t hurt to have more than one way to present the list. We can pick and choose which presentation to use.
| Quote: | I don't know if anyone else has been having trouble
I do not have any problems reading the mod 73 listings, using MS Outlook. Maybe it is a setting in the editor? Check to see if your editor is using HTML format settings, which may have better table or column support.
| Quote: | I suggest that all other reports should come to me and I
week.
Isn’t someone already doing this? Do they still want to continue?
| Quote: | I am fairly certain that after the "tag your details
been lost.
Since the returned Mod 73 listings (for those who have done the mod) are all the same except for the one line added, it can get a bit time consuming for those that are tracking this information to sort through. It might be easier if the listing is returned to the matronics server with only the header and the one line of new information. For those that are tracking, this will cut down on searching through the list each time, looking for the one (or three) new entries.
Example:
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
There can even be a statement to keep from archiving, so that there are not too many of these on the server. It would also be helpful to be sure to respond to RE: Mod 73 listing only. That way the person(s) tracking the info can do a simple search in his email editor and pull up all the results.
This is only a suggestion, meant for smoother flow of information.
Greg Fuchs A050
‘Working in the wings
Posted: Mon Jul 23, 2007 10:12 am Post subject: Mod 73 listing |
I digress…
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of gregoryf.flyboy
Sent: Monday, July 23, 2007 11:04 AM
Subject: RE: Mod 73 listing
week.
been lost.
Example:
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
There can even be a statement to keep from archiving, so that there are not too many of these on the server. It would also be helpful to be sure to respond to RE: Europa-List: Mod 73 listing only. That way the person(s) tracking the info can do a simple search in his email editor and pull up all the results.
Greg Fuchs A050
‘Working in the wings | Quote: | | http://www.matronics.com/Navigator?Europa-List | 01234
Posted: Mon Jul 23, 2007 11:02 am Post subject: Mod 73 listing |
I am happy to continue to add results to my spreadsheet. I will publish a full listing once or twice a week as required.
Following on from Greg’s suggestion, to keep it simple and save bandwidth / storage space on the server, just send the raw data to the forum or to me directly and I will append it to my table.
Richard Iddon G-RIXS My direct email address is riddon(at)sent.com (riddon(at)sent.com)
-----Original Message-----
Sent: 23 July 2007 19:04
Subject: RE: Europa-List: Mod 73 listing
week.
been lost.
Example:
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
Greg Fuchs A050
22/07/2007 19:02
22/07/2007 19:02
mau11(at)free.fr Guest
Posted: Mon Jul 30, 2007 10:33 am Post subject: Mod 73 listing |
I add my Mod 73 report
Michel Auvray Builder N°145
| Quote: | -----Message d'origine-----
De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com]De la part de Richard Iddon
Envoyé : lundi 23 juillet 2007 19:52
À : europa-list(at)matronics.com
Objet : RE: Mod 73 listing
Richard.
Name
Country
Reg
Type
Hours
Landing sfc.
Mod 73 progress
Disbonding of TP6
Pip Pins
Problems found
Richard Iddon
UK
G-RIXS
Tri gear
365
Tarmac
Completed
None found
2in.
nothing major
Steve Pitt
UK
G-SMDH
Tri gear
46
Grass
Completed
None found
2in.
nothing major
Ron Jones
UK
G-RJWX
Mono
320
Both
Completed
None found
Original
None
Tim Ward
NZ
ZK-TIM
Mono
Not done
None found
Original
Danny Shepherd
UK
G-CERI
Tri Gear
Completed
None found
2in.
Pete Jeffers
UK
G-BVIZ
Tri Gear
Completed
None found
2in.
well within limits
Brian Davies
UK
G-DDBD
Tri Gear
20
mixed
Completed
None found
1.9in.
none
Graham Drake
UK
G-CCOV
Mono
60
Mostly Hard
Completed
None found
2in.
Sarah Attubato
UK
G-BWDP
Mono
N/A
N/A
Completed
None found
2in.
David Watts
UK
G-BXDY
Mono
1250
Mostly Grass
Completed
None found
2in.
Nigel Charles
UK
G-MIME
Mono
Completed
None found
2in.
nothing major
Mike Clews
UK
G-OMIK
Mono
500
Grass
Completed
None found
Original
nothing major
Arthur Orchard
uk
G-JOST
Tri Gear
17.5 hrs
Tar/Mac
completed
none found
original
nothing found
Colin Smallwood
UK
G-DEBR
Tri Gear
Tarmac
W.I.P
None found
2in
Alasdair Milne
UK
G-CBYN
Tri Gear
Completed
None
original
none
Trev Pond
UK
G-LINN
Tri Gear
Grass
Completed
None found
Original
none
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Richard Holder
Sent: 23 July 2007 17:41
Subject: Mod 73 listing
Team
afternoon.
found"
Richard Holder
G-OWWW High Cross
22/07/2007 19:02
Mod_731.xls |
26 KB |
277 Time(s) |
