Sample AC680E W&B form
CloudCraft(at)aol.com
PostPosted: Fri Jul 20, 2007 10:54 am    Post subject: Sample AC680E W&B form Reply with quote
Here is an example of how this form was used; it should give you an idea of how the form operates.
It represents a fairly typical flight I would do between Samoan islands in the AC-680E.
Wing Commander Gordon.
SAMPLW&B.DOC
 Filename:  SAMPLW&B.DOC
 Filesize:  146 KB
 Downloaded:  441 Time(s)
n395v
PostPosted: Sat Jul 21, 2007 6:24 am    Post subject: Re: Sample AC680E W&B form Reply with quote
Attached is a W&B spreadsheet for my current plane.
You can modify it for any plane by just changing the titles, arm and weights or adding in items as needed. The principle is the same for all aircraft.
N91TX Weight and Balance calc.xls
Typical XL W&B spreadsheet
 Filename:  N91TX Weight and Balance calc.xls
 Filesize:  18.5 KB
 Downloaded:  454 Time(s)
Milt
