dean.psiropoulos(at)veriz Guest
Posted: Sun Jul 22, 2007 8:58 pm Post subject: Firewall shields |
Question on stainless steel firewall shields. I'm using two of them, one
covers my EGT/CHT harness (8 cables each containing two individual insulated
thermocouple wires surrounded by a yellow or brown cover of, I believe,
tefzel). The second one covers my VM-1000 sensor cables (half dozen 4
conductor with foil shield and tefzel outer cover).
The CHT/EGT hole in the stainless firewall has a plastic busing installed
and the harness fits through this bushing slightly snug and the firewall
shield just fits around the whole thing without having to squeeze the shield
against the wires.
The sensor cables make use of a hole I originally cut through the firewall
for an eye-ball control cable mount. The hole is quite large and a bushing
would still leave the harness not centered in the firewall shield and
sitting on the thin firewall shield material.
I've cleaned up the shear marks and smoothed the edges on the firewall
shields but am still a bit nervous about the thin material chaffing the
wires, especially the large sensor wire hole. Any thoughts/ideas on this?
Am I being too paranoid? Since we can no longer procure asbestos to make
gaskets to go under the shield what is everyone doing here? Are you using
some sort of grommet over the edges of the stainless shields to protect your
cables from chaffing....or? Thanks.
Dean Psiropoulos
RV-6A N197DM
Last of the wiring.
