Europa colours
raimo.toivio(at)rwm-syste
PostPosted: Fri Jul 20, 2007 12:28 am    Post subject: Europa colours Reply with quote
Rob,
I am not going to encourage anybody to paint their
Europa´s undersides any colour but white. I still well
remember Manual´s words: all the Europas must be white.
I still have to point out the energy of the sun is NOT
reflecting out of the black asphalt IMHO. That is why
it is hot when a sunny day. It absorbs allmost all the heat
energy and nothing is reflecting out. White surfaces are
cool because they are reflecting out much more.
So it could be more dangerous to keep it on the snow covered
surface while a sunny day (or on white sand or water w Europa floats!).
In Sweden there has been 10 years a wonderful full colour mid red Lancair 320
and no composite problems at all. Register # is SE-XOP (!). And like
we all know in South America (Columbia?) there is flying a total deep yellow Europa.
I think - with other colour as white - it is better to be even more careful.
Beauty is a good reason for some extra work and some sacrifice.
That is the fact all the women know. That is all.
"Keep your full matt black Europa in the hangar and fly only night time if you wanna be absolutely sure"
Raimo
 Filesize:  48.76 KB
 Viewed:  330 Time(s)
 Filesize:  39.05 KB
 Viewed:  338 Time(s)
robh(at)hyperion-ef.com
PostPosted: Fri Jul 20, 2007 7:03 am    Post subject: Europa colours Reply with quote
Sorry Raimo, but this is dangerous thinking for those of us flying in warmer climes.
In my previous post I deliberately avoided getting into too much technical detail, and I used the word “reflected” where I should have used the technically correct term “emitted.”
First, you seem to misunderstand heat transfer.  You are correct that the sun’s energy is not reflected from a black surface.  However, a “black body” is not only a perfect absorber but also a perfect emitter, which is to say it may not be reflecting solar heating but it surely emits it.  Park on a black surface and the solar energy absorbed by that surface will be re-radiated to the underside of the aircraft, and if that aircraft is any color but white it will absorb too much energy.  Any material absorbing energy will increase in temperature.  Sure, there will be some re-radiation from the dark aircraft structure but that is irrelevant because the epoxy-fiberglass will already have softened.
Second, the Lancair aircraft all use a different composite than Europa.  Here’s how Lancair describes their composites on their web site http://www.lancair.com/Main/legacy.html  ---
“Like every Lancair, the Legacy’s major airframe is constructed of advanced composite materials. Cured at 270 degrees Fahrenheit under vacuum pressure, these NASA tested, epoxy based composites are among the lightest, strongest, stiffest materials known.
The high-temperature, pre-impregnated carbon fiber and/or fiberglass systems combined with Nomex/honeycomb core materials are considered the supreme composite airframe materials of choice worldwide.”
Note that the Lancair’s composites are cured at a much higher temperature than the factory and we cure the Europa structural components.  The “glass transition temperature” is approximately the cure temperature so softening of the composite does not begin until approximately T sub g is reached.  For a detailed explanation to T sub g see http://en.wikipedia.org/wiki/Glass_transition_temperature  For our purposes we can consider the glass transition temperature the softening temperature, above which the structure loses a significant portion of its strength.
Anyone contemplating painting a Europa any color other than white (including yellow) should review the chart in the Builders Manual, Figure 1, Colour-Temperature Relationship, on page 36-1 of the Europa XS Tri-Gear Manual, Issue 1, dated 30 May 1998.
Best regards,
Rob Housman
Irvine, California
Europa XS Tri-Gear
S/N A070
Airframe complete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Raimo Toivio
Sent: Friday, July 20, 2007 1:28 AM
Subject: Re: Europa colours
Rob,
Raimo
----- Original Message -----
Sent: Friday, July 20, 2007 2:32 AM
Subject: RE: Europa-List: Europa rules
Mike –
In re: dark paint
Don’t even think about it. Where we live and fly, on warm days the heat reflected off the ramp will be sufficient to soften the epoxy-fiberglass enough to reduce the strength of the structure. Sure it will be OK at altitude but you still have to climb away from the surface. Folks flying closer to the Arctic Circle don’t have to worry about getting the airframe too hot.
Best regards,
Rob Housman
Irvine, California
Europa XS Tri-Gear
S/N A070
Airframe complete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of DuaneFamly(at)aol.com
Sent: Thursday, July 19, 2007 3:23 PM
Subject: Re: Europa rules
Raimo,
Congratulations to you and your aircraft. I think we can all stand a little taller and more proud when one of "our" planes tops the list of all in an entire country.
Do you have any pix of you panel? Is the underside of your aircraft really painted dark? Black, blue, brown? Any reasoning for this?
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronics.com href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
jthursby(at)tampabay.rr.c
PostPosted: Fri Jul 20, 2007 8:00 am    Post subject: Europa colours Reply with quote
Anyone remember the factory demonstrator N914XS with the blue belly? After two or so years in the US sun that plane needed repairs to the front fuselage as the engine weight was sagging the footwell area of the plane while it was hot. Needless to say after it was reapaired it was repainted white. As Rob H said even yellow can get a bit warmer that white, and I've sprayed one yellow myself.
Paint em' white, or fly em' at night!
Jim T.
jeff(at)rmmm.net
PostPosted: Fri Jul 20, 2007 8:40 am    Post subject: Europa colours Reply with quote
This is very correct Jim. I have light tan or gold accents on N128LJ.
It is a metallic light gold so I figured it to be a very acceptable
reflective / emitted color. On a sunny day the difference to the touch
is the difference between very warm and neutral to the touch. Even in
the winter months on a sunny day reach out and touch a black car then a
white and you'll know the color to paint your plane. Keep it white and
keep it strong.
Jeff R.
On Jul 20, 2007, at 10:55 AM, James wrote:
[quote] Anyone remember the factory demonstrator N914XS with the blue belly?
 Jim T.
raimo.toivio(at)rwm.fi
PostPosted: Mon Jul 23, 2007 9:56 am    Post subject: Europa colours Reply with quote
Hi Rob
As I wrote
"I am not going to encourage anybody to paint their
remember Manual´s words: all the Europas must be white."
and
"I think - with other colour as white - it is better to be even more careful. "
and
Anyway - I called to my friend Jukka Paavolainen, who has build
and still flies his Lancair 320 OH-XJP. He said his Lancair is
just on ordinary glasfibre - epox system and definetely not baked
in high temparatures. Only the cowlings - because of the engine and
exhaust heat - has been made by more heat resistant phenolresins.
His Lancair kit is year model 1990 and so is my earlier example SE-XOP,
which is overall deepred and beautiful Swedish Lancair 320.
I believe newer models are as you described made by adanced composite materials.
You wrote
" Park on a black surface and the solar energy absorbed by that surface will be re-radiated to the underside of the aircraft, and if that aircraft is any color but white it will absorb too much energy. "
and I still think you are wrong. I am going to talk to one thermodynamist,
who works as a doctor in Tampere Univercity. Maybe he can make this
thing clear. I promise to come back and tell what he know. Also if I am wrong...
Fly it - do not melt it...
Raimo
lgds(at)post6.tele.dk
PostPosted: Mon Jul 23, 2007 10:20 am    Post subject: Europa colours Reply with quote
I only fly at night......    Smile
Gert
http://home19.inet.tele.dk/dalgaard/oygds.jpg
Den 23/07/2007 kl. 20.02 skrev Raimo Toivio:
[quote]Hi Rob
and
and
Raimo
[quote]---
PostPosted: Mon Jul 23, 2007 11:37 am    Post subject: Europa colours Reply with quote
Gert, so beautiful is your plane!
I think we once met in Barkaby.
Anyway - your Europa has been one of my inspiring examples during the years.
But it is obvious - you are living in a country of great design like Bang&Olufsen.
But how dare you make a dark bottom, bad boy you are!
Any difficulties /delaminations?
Let me guess: not at all.
All the others:
By the way, what is the temp inside the cowlings when
taxiing long in a hot day? There, near by the critical areas.
I painted all the inside glass surfaces white and have a
heat reflecting & noise insulating firewall coating.
Moro, Raimo
karelvranken(at)hotmail.c
PostPosted: Tue Jul 24, 2007 1:35 am    Post subject: Europa colours Reply with quote
Do you know the gliders color? They know why!
Karel Vranken # 447 F-PKRL
thomas(at)scherer.com
PostPosted: Wed Jul 25, 2007 7:58 pm    Post subject: Europa colours Reply with quote
my Europa is half blue and shoes no signs of melting after ten years of service. She has been parked and flown in hot cuntries.
<Thomas, N81EU>
----Original Message----
Date: Jul 24, 2007 2:38
To:
Subj: Re: Europa colours
Message v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } shape { BEHAVIOR: url(#default#VML) } <![endif]--> (at)font-face { font-family: Calibri; } (at)font-face { font-family: Tahoma; } (at)font-face { font-family: Consolas; } (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.0in 1.0in 1.0in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } PRE { FONT-SIZE: 10pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New"; mso-style-priority: 99; mso-style-link: "HTML Preformatted Char" } P.MsoAcetate { FONT-SIZE: 8pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Tahoma","sans-serif"; mso-style-priority: 99; mso-style-link: "Balloon Text Char" } LI.MsoAcetate { FONT-SIZE: 8pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Tahoma","sans-serif"; mso-style-priority: 99; mso-style-link: "Balloon Text Char" } DIV.MsoAcetate { FONT-SIZE: 8pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Tahoma","sans-serif"; mso-style-priority: 99; mso-style-link: "Balloon Text Char" } SPAN.HTMLPreformattedChar { FONT-FAMILY: Consolas; mso-style-priority: 99; mso-style-link: "HTML Preformatted"; mso-style-name: "HTML Preformatted Char" } SPAN.BalloonTextChar { FONT-FAMILY: "Tahoma","sans-serif"; mso-style-priority: 99; mso-style-link: "Balloon Text"; mso-style-name: "Balloon Text Char" } SPAN.EmailStyle21 { FONT-WEIGHT: normal; COLOR: #1f497d; FONT-STYLE: normal; FONT-FAMILY: "Arial","sans-serif"; mso-style-type: personal } SPAN.EmailStyle22 { FONT-WEIGHT: normal; COLOR: #1f497d; FONT-STYLE: normal; FONT-FAMILY: "Arial","sans-serif"; mso-style-type: personal-reply } MsoChpDefault { FONT-SIZE: 10pt; mso-style-type: export-only } DIV.Section1 { page: Section1 } Do you know the gliders color? They know why!
PostPosted: Wed Jul 25, 2007 10:09 pm    Post subject: Europa colours Reply with quote
Wau, an another bad boy again!
In fact I found few days ago nice pics of N81EU
and it was parked in Utah Salt Lake City may I guess.
I think it is one of the hottiest place in the world. And fastest!
I noticed your Europa´s sides also have been painted blue,
not only down side.
Maybe you fly so much that it has no time enough to melt...
Karel: people do things many times just because it is just a "habit".
Like painting gliders only white. Some times an individual decides
to do something other way. It can be a disaster or success. You know.
They call it experimental.
Thanks, Raimo
PostPosted: Thu Jul 26, 2007 11:14 am    Post subject: Europa colours Reply with quote
You're lucky, but how long to you want to tempt fate?
Jim T.
PostPosted: Thu Jul 26, 2007 1:45 pm    Post subject: Europa colours Reply with quote
Raimo,
The only one glider with another color than white was a Finnish Pik 20 B in the World Championships in Waikiri (Australia). It was light yellow.
Seems that in Suomi they experiment to reinvent the wheel even if only to attract attention. Differences in temperature for the same structure is not desirable for glass constructions. But I understand that you want to keep the belly warm.
Best regards,
Karel Vranken, # 447 F-PKRL.
PostPosted: Tue Jul 31, 2007 2:08 am    Post subject: Europa colours Reply with quote
Dear Karel,
Yes in Suomi we like to reinvent things and make them better.
Like a phone and the result is history like www.nokia.com
(and it is not created to attract attention only you know!).
Despite that I have to mention Thomas S & Co are not Finnish.
There are also some other people on the ball thinking by their own brains.
By the way you have on your Europa sides golden strips pointing straight to the sun.
What a hot spot!
Aren´t you worried one day the fuselage joint will be melt and you
have a canoe stage again during your flight Wink
Sorry I forgot those little dark strips, pics, stars, letters, numbers etc mean nothing...
Kind Regards, Raimo
Raimo M W Toivio
OH-XRT Europa XS Mono #417, The Experimental of The Year
OH-CVK C172 Skyhawk, totally restored 2006-2007
OH-BLL Beechcraft C45, w radial engines (grounded)
37500 Lempaala
Finland
tel + 358 3 3753 777
fax + 358 3 3753 100
gsm + 358 40 590 1450
raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)
www.rwm.fi
PostPosted: Tue Jul 31, 2007 5:49 am    Post subject: Europa colours Reply with quote
Anyone that has a dark color on their plane as a secondary color and not a stripe, can joke all they want. I saw what went into fixing N914XS and I can tell you it wasn't funny knowing I had been flying acro in an airplane that could have at the least had the power plant hanging by half the firewall halfway thru a loop, or at the worst losing the firewall forward. You can't reinvent TG. But you CAN reflow epoxy at elevated temps. At about 200F aeropoxy WILL start to soften. You CAN remove redux with a hairdryer. And a dark painted composite plane WILL deform sooner or later.
If you think it works on you're aircraft that's fine, but don't go recommending it to somebody else.
If you cant keep you're hand on it in the sun then it's too hot.
I can't believe so many are willing to kick the devil in the gonads.
Jim T.
PostPosted: Tue Jul 31, 2007 8:56 am    Post subject: Europa colours Reply with quote
Dear Jim,
as I have stated earlier
painting dark (underside only)
is only my decision and it is valid
here in Scandinavian, quite near
Polar Circle. When not in airborne,
it is in hangar - not under the sun.
I wish pure white colour makes you happy
in every climate in every temperature.
It must be like a prayer - with it you can
do what ever you like - w/o own judgement.
I have a headache - you have kicked my
head to the hot asshole.
Raimo, still the beauty is first of all
attached a pic of my "dark & dangerous" Europa
 Filesize:  60.11 KB
 Viewed:  318 Time(s)
gregoryf.flyboy(at)comcas
PostPosted: Tue Jul 31, 2007 10:51 am    Post subject: Europa colours Reply with quote
Raimo,
That sure is a beautiful looking bird, you must be proud. Up there near the polar circle, you might need that darkness to keep the belly from getting too cold!
Greg
Sent: Tuesday, July 31, 2007 10:03 AM
Dear Jim,
PostPosted: Tue Jul 31, 2007 11:43 pm    Post subject: Europa colours Reply with quote
Raimo,
The golden color I choose for the striping is a special effect color. It reflects the heat. Though it is expensif, the color and application was a 1000 Euro cost. And gold is nearly yellow what after white is the second choise. Better than big black letters.
Best regards,
Karel Vranken
