4rcsimmons(at)comcast.net Guest
Posted: Wed Jul 18, 2007 6:08 am Post subject: Leveling |
Another question!
As I am going through leveling my Fuse, Front Floor, Firewall, Gear Channel, whatever else, I am concerned about my digital gauge reading in only 0.1 incaments.
A friend suggested using the water hose level as you can literally carry one point to another if your hose is long enough (Long enough hose??? Don't go there!!)
Have any of you guys used this method before? Any thoughts on leveling before I go any further?
WHAT IS YOUR OPINION?
I live in the world of measurement in the Automotive Industry and I know when it is close enough for a car body etc. . . When is Close enough good enough for my plane as far as these angular measurements? What is your rule of thumb?
Rich Simmons
dkbrooks(at)gmail.com Guest
Posted: Wed Jul 18, 2007 6:24 am Post subject: Leveling |
I have used a water level to do deck construction and it worked great. The one I got at Home Depot has a small box with a sensor and an alarm that goes off when level is reached so you don't have to be able to see both ends at once (handy for big projects).
The only issue I would have with my level is accuracy. In theory, of course, this would be supremely accurate but in reality the meniscus in the plastic tube isn't always uniform all the way around the tube (dirt and dust get in there) so it could be off a millimeter or two. That is obviously not something I have ever worried about while building decks.
Just my 2 cents work of experience (1 1/2 cents worth?), your mileage may very well vary.
Do not archive (ok, so how does this work? and what should and shouldn't be archived?)
Dave
On 7/18/07, Rich Simmons <4rcsimmons(at)comcast.net (4rcsimmons(at)comcast.net)> wrote: Quote: |
Quote: |
Another question!
Rich Simmons
[/b] |
Posted: Wed Jul 18, 2007 6:31 am Post subject: Leveling |
Hi Rich,
Leveling things at distance with a clear water hose is fine, gear,
fuselage etc. For wing leveling, and control surfaces, use a bubble level
or a tool that measures reliably in degrees.
Rich Simmons wrote:
Quote: |
Another question!
Rich Simmons
flydad57(at)neo.rr.com Guest
Posted: Wed Jul 18, 2007 6:56 am Post subject: Leveling |
I got a Black and Decker, self leveling laser level at Big Lots for $39. Works great. Checked it with my $300 unit and it checked out perfectly.
Bob Taylor
Wadsworth, Ohio
N657RT, Res.
planecrazydld(at)yahoo.co Guest
Posted: Wed Jul 18, 2007 7:51 am Post subject: Leveling |
making the miniscus less of an indicating variable is exactly why you put the red food coloring in the water...
David Brooks <dkbrooks(at)gmail.com> wrote: [quote]I have used a water level to do deck construction and it worked great. The one I got at Home Depot has a small box with a sensor and an alarm that goes off when level is reached so you don't have to be able to see both ends at once (handy for big projects).
Dave
On 7/18/07, Rich Simmons <4rcsimmons(at)comcast.net (4rcsimmons(at)comcast.net)> wrote: [quote]
Another question!
A friend suggested using the water hose level as you can literally carry one point to another if your hose is Don't be flakey. [url=http://us.rd.yahoo.com/evt=43909/*http://mobile.yahoo.com/mail]Get Yahoo! Mail for Mobile[/url] and
[url=http://us.rd.yahoo.com/evt=43909/*http://mobile.yahoo.com/mail]always stay connected[/url] to friends. [quote][b]
Kevin Bonds
Joined: 09 Jan 2006 Posts: 171 Location: Nashville, Tn
Posted: Wed Jul 18, 2007 8:00 am Post subject: Leveling |
Rich,
I think you will be fine. I think my new craftsman digital is good to 0.2 deg. Good enough for me. Another builder on this list told me a story recently. He was having trouble getting his firewall dead on. He called Caleb at ZAC, and explained that he had it to within 0.5 of a degree. He laughed and said, “Wow, we haven’t gotten one that close yet”.
Kevin Bonds
Nashville TN
601XL Plans building.
http://home.comcast.net/~kevinbonds
do not archive DO NOT ARCHIVE
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Rich Simmons
Sent: Wednesday, July 18, 2007 9:03 AM
Subject: FW: Leveling
Quote: |
Another question!
Rich Simmons
http://www.matronics.com/Navigator?Zenith-List | 01234
_________________ KevinBonds
Nashville, TN
Plans-building Zenith CH601XL w/Corvair Power
http://home.comcast.net/~kevinbonds |
Posted: Wed Jul 18, 2007 8:24 am Post subject: Leveling |
Does the red food coloring reduce the surface tension of the water (and thereby making the meniscus 'smaller') or does it just make it easier to see the bottom of the 'bowl'? If it doesn't make the meniscus smaller then the little alarm box thingie probably would still have some inaccuracies.
I am asking out of real curiosity, not to be snarky. I think that others have suggested better tools for the job anyway and I really doubt that this sort of accuracy will ever be necessary in my fence & deck projects. But this is exactly the sort of thing that I much prefer to ponder than the real work that is piling up around me on my desk.
Dave
On 7/18/07, David Downey <planecrazydld(at)yahoo.com (planecrazydld(at)yahoo.com)> wrote:[quote] making the miniscus less of an indicating variable is exactly why you put the red food coloring in the water...
David Brooks < dkbrooks(at)gmail.com (dkbrooks(at)gmail.com)> wrote: Quote: | I have used a water level to do deck construction and it worked great. The one I got at Home Depot has a small box with a sensor and an alarm that goes off when level is reached so you don't have to be able to see both ends at once (handy for big projects).
Dave
| [b]
crvsecretary
Joined: 18 Mar 2007 Posts: 38 Location: Naugatuck, CT
Posted: Wed Jul 18, 2007 8:37 am Post subject: Leveling |
The food coloring should be water-based, so I cannot see how it would change the surface tension of the water....if it was alcohol-based I think you might have a good point. I add just a few drops of food coloring into my water level just to give my eyes a break and make the meniscus easier to see.
As far as the alarm being affected by the food coloring I am not in a position to say.
Tracy Smith
601XL N458XL (reserved)
working on wings
In a message dated 7/18/2007 11:26:49 AM Eastern Standard Time, dkbrooks(at)gmail.com writes:
Quote: | Does the red food coloring reduce the surface tension of the water (and thereby making the meniscus 'smaller') or does it just make it easier to see the bottom of the 'bowl'? If it doesn't make the meniscus smaller then the little alarm box thingie probably would still have some inaccuracies.
Dave
On 7/18/07, David Downey <planecrazydld(at)yahoo.com (planecrazydld(at)yahoo.com)> wrote: Quote: | making the miniscus less of an indicating variable is exactly why you put the red food coloring in the water...
Dave
_________________ Zenith 601XL N458XL (reserved)
Naugatuck, CT
Tail Complete; working on wings |
gboothe(at)calply.com Guest
Posted: Wed Jul 18, 2007 9:04 am Post subject: Leveling |
The coloring only makes it easier to see. If you have no bubbles (let the water level set for a few hours after filling), and always read to the bottom of the meniscus, you will be incredibly accurate. The Zenith airplanes were designed for building with a minimum of tools. It is doubtful that the rest of a homebuilder’s construction would be that exact, any how.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of David Brooks
Sent: Wednesday, July 18, 2007 9:21 AM
Subject: Re: FW: Leveling
Dave
Dave
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Jul 18, 2007 10:09 am Post subject: Re: Leveling |
Wow, I only used the angle templates and bubble levels as shown in the assembly guides. I doubt my bubble levels are accurate to 0.1 degrees. I did at least make sure that all three of my levels agreed with each other.
If you see me flying by all catty-whompus (warning: technical term) then I guess I did it all wrong. I will not know how it flies for another year or two though.
Good luck,
_________________ David Gallagher
Cincinnati, OH area |
dredmoody(at)cox.net Guest
Posted: Wed Jul 18, 2007 10:41 am Post subject: Leveling |
Have beer and go with the digital level.
Dred
---- Rich Simmons <4rcsimmons(at)comcast.net> wrote:
Quote: |
Another question!
Rich Simmons
Posted: Wed Jul 18, 2007 10:48 am Post subject: Leveling |
I still like the beer and digital level technique. If the plane flies in circles at least you won't get far from the airport and get lost! Honestly guys, if you can get the parts to within even .2 to .3 degrees of what the drawings call for, you should be fine.
Send flowers after I crash,
Dred
Good luck,
David Gallagher
601 XL, tail and wings completed,
fueslage almost done, engine next.
http://forums.matronics.com/viewtopic.php?p=124606#124606
Posted: Wed Jul 18, 2007 1:43 pm Post subject: Leveling |
the reason I mentioned it is that I love water levels - they always work (unless you have a kink or other blockage - ask how I know this...). I also think I can get inside 1/32" pretty easily. Th ebetter levels have 3/4" diameter tubing at the indicating ends. When you use colored water, the "bowl" as you aptly described it is flat bottomed and you can sight right through the meniscus (probably won't be as easy now that I have old eyes). Unless you have a machinists level it is really hard to get that kind of precision. Certainly do not ever consider using a line level...
David Brooks <dkbrooks(at)gmail.com> wrote: [quote]Does the red food coloring reduce the surface tension of the water (and thereby making the meniscus 'smaller') or does it just make it easier to see the bottom of the 'bowl'? If it doesn't make the meniscus smaller then the little alarm box thingie probably would still have some inaccuracies.
Dave
On 7/18/07, David Downey <planecrazydld(at)yahoo.com (planecrazydld(at)yahoo.com)> wrote: [quote]making the miniscus less of an indicating variable is exactly why you put the red food coloring in the water...
David Brooks < dkbrooks(at)gmail.com (dkbrooks(at)gmail.com)> wrote: [quote]I have used a water level to do deck construction and it worked great. The one I got at Home Depot has a small box with a sensor and an alarm that goes off when level is reached so you don't have to be able to see both ends at once (handy for big projects).
Do not archive (ok, so how Get the Yahoo! toolbar and [url=http://us.rd.yahoo.com/evt=48225/*http://new.toolbar.yahoo.com/toolbar/features/mail/index.php]be alerted to new email [/url]wherever you're surfing. [quote][b]
psm(at)ATT.NET Guest
Posted: Thu Jul 19, 2007 3:38 am Post subject: Leveling |
At 11:09 AM 7/18/2007, you wrote:
Quote: | If you see me flying by all catty-whompus (warning: technical term)
Actually, I learned many years ago when trying to learn RC airplane
piloting that anything will fly. After the first few major crashes,
my airplanes tended to be very crooked contraptions held together by
large globs of epoxy glue. They still flew just fine. Well, perhaps
their airspeed wasn't quite as good as when they were new.
For leveling my work bench I used one of the home depot style laser
levels. I used this to insert shims under 2 x 4 cross pieces on top
of my work bench. This gave me a 12 foot long by four foot wide work
space where the top edges of the 2 x 4s were level to within 1 mm throughout.
Paul
XL fuselage
milreed(at)wildblue.net Guest
Posted: Thu Jul 19, 2007 9:56 am Post subject: Leveling |
I check my level by switching ends on the same surface. Do you folks think that would work? I never have asked an expert about that yet (since I thought about that in 1958 and ended up in a big argument). If the bubble is in the same place ok, if not you have an error? right??
Mil
crvsecretary
Posted: Thu Jul 19, 2007 10:04 am Post subject: Leveling |
Yes, your method is absolutely correct.
If there is an imperfection in the glass tube the bubble should hang up there; since the sample location does not change, but the bubble DOES, it's time to get a new level.
I always check my level at first use as well.
I can't imagine what the arguement could be.....
Tracy
In a message dated 7/19/2007 12:57:33 PM Eastern Standard Time, milreed(at)wildblue.net writes:
Quote: | I check my level by switching ends on the same surface. Do you folks think that would work? I never have asked an expert about that yet (since I thought about that in 1958 and ended up in a big argument). If the bubble is in the same place ok, if not you have an error? right??
Mil
Naugatuck, CT
Posted: Fri Jul 20, 2007 5:58 am Post subject: Leveling |
Sheez! It's a wonder the knowledege that can flow from . . . nevermind!
Actually, I got some really good information off the list from list users.
Thanks. The water/tube method for leveling those far away places works awsome.
Now, whne I fly, I wont have to add a lot of left/right/up/down trim like I too have had to do to my R/C planeas that I repaired after crashing because I had too many beers and could only fly in circles around the runway till I lnaded/crashed or crashed landed!.
Really, thanks to those with the useful information and to the others, thanks for the laughs!
Rich Simmons
