Airport Code: LAT
barry.collman(at)air-brit
PostPosted: Thu Jul 19, 2007 10:03 am    Post subject: Airport Code: LAT Reply with quote
Hi Gang,
I have a slide of a NASA Commander taken in December 1968, at "LAT" airport.
This doesn't seem to be a current code.
My memory is saying Los Angeles Air Terminal, but that source of data just cannot be relied upon.
Any 'old -timers' out there who can help?
Very Best Regards,
Barry
PostPosted: Thu Jul 19, 2007 11:08 am    Post subject: Airport Code: LAT Reply with quote
Hi Gang,
Ah! Memory recall - a rare event nowadays ;-0
I think "LAT" is Lockheed Air Terminal, at Burbank.
If I'm wrong, no doubt somebody well let me know.
Best Regards,
Barry
BobsV35B(at)aol.com
PostPosted: Thu Jul 19, 2007 2:57 pm    Post subject: Airport Code: LAT Reply with quote
In a message dated 7/19/2007 1:04:49 P.M. Central Daylight Time, barry.collman(at)air-britain.co.uk writes:
Hi Gang,
Very Best Regards,
Barry
How About Lockheed Air Terminal?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
PostPosted: Thu Jul 19, 2007 3:33 pm    Post subject: Airport Code: LAT Reply with quote
Hi Bob,
Yep! That's what I finally deduced too!
CloudCraft(at)aol.com
PostPosted: Fri Jul 20, 2007 7:14 am    Post subject: Airport Code: LAT Reply with quote
In a message dated 19-Jul-07 12:09:44 Pacific Daylight Time, barry.collman(at)air-britain.co.uk writes:
Sir Barry,
Can you scan the photo and upload it? I bet one or two of us would actually recognize the field!
Wing Commander Gordon
PostPosted: Fri Jul 20, 2007 8:17 am    Post subject: Airport Code: LAT Reply with quote
Hi Keith,
I've attached a scan of the color slide in question. As you'll see, there isn't much to go on in the way detail in the background.
I'm sure though now that "LAT" is Lockheed Air Terminal and this had its name changed in 1975, to "Burbank Glendale-Pasadena Airport".
Very Best Regards,
Barry
 Filesize:  575.57 KB
 Viewed:  367 Time(s)
PostPosted: Fri Jul 20, 2007 8:33 am    Post subject: Airport Code: LAT Reply with quote
Was it Old Bob, Ancient Aviator, that called it Lockheed Air Terminal?
I grew up down there. From the ridge line and the small hill to the right of the tail, the vegetation (lack of) and smog layer, I'd say it looks like the area for sure.
moe(at)rosspistons.com
PostPosted: Fri Jul 20, 2007 8:52 am    Post subject: Airport Code: LAT Reply with quote
Not to mention the smog!
Looks like Burbank to me.
Moe
N680RR
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of CloudCraft(at)aol.com
Sent: Friday, July 20, 2007 9:32 AM
Subject: Re: Commander-List: Airport Code: LAT
[b]Was it Old Bob, Ancient Aviator, that called it Lockheed Air Terminal?[/b]
[b]I grew up down there. From the ridge line and the small hill to the right of the tail, the vegetation (lack of) and smog layer, I'd say it looks like the area for sure.[/b]
[b]Wing Commander Gordon[/b]
dowens(at)aerialviewpoint
PostPosted: Fri Jul 20, 2007 9:53 am    Post subject: Airport Code: LAT Reply with quote
Not in answer to your LAT question, but at least some trivia about the Lockheed Airport(s) beginnings... go to http://www.airfields-freeman.com/CA/Airfields_CA_SanFernan.htm#lockheedb1 to view these "ghost-airfields" of the day... very cool.
David Owens
Aerial Viewpoint
N14AV
AC-500A-Colemill
PostPosted: Fri Jul 20, 2007 10:00 am    Post subject: Airport Code: LAT Reply with quote
"The Lockheed factory airstrip was in use until about 1941, when the P-38 came out.
The P-38s were towed down Empire Street in the middle of the night to the newly acquired Burbank (Union) Air Terminal,
which was renamed 'Lockheed Air Terminal'".
David Owens
Aerial Viewpoint
N14AV
AC-500A-Colemill
PostPosted: Fri Jul 20, 2007 11:59 am    Post subject: Airport Code: LAT Reply with quote
Hi Guys!
Thanks! Lockheed Air Terminal (later Burbank) it is then Wink
Best Regards,
Barry
