Mystery Rivets
kentk
PostPosted: Mon Jul 16, 2007 5:39 pm    Post subject: Mystery Rivets Reply with quote
Ok, gotta a little mystery that I am trying to solve, and would love to have your thoughts and input on:
I am building a Model 4-1200 and am at the stage where I attach the Butt Ribs to the fuselage (page WB-13 in the '94 manual). The drawing indicates that I am to use #95006 rivets (1/8 x 3/8 AS) to attach the Butt Ribs to the brackets. I can't find #95006 rivets anywhere. What does "AS" stand for (typo?).
So, I checked the parts list, and guess what??? No #95006 in the wing kit listed anywhere. No 1/8 x 3/8 rivets listed either. However, in the "Cover and Finish" inventory, there are #95006 rivets listed, but they are 1/8 x 1/8 PL rivets (qty. 4).
Thoughts, comments, suggestions???
Thanks in advance,
Kent
Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done
Tom Jones
PostPosted: Mon Jul 16, 2007 6:34 pm    Post subject: Re: Mystery Rivets Reply with quote
I remember I was confused about those rivets too and had to ask on the list what to use. I didn't make any notes in my log but it looks like I used 1/8th SS...stainless steel. believe it or not the old skystar sent me enough rivets to build 4 wings. I have lots of rivets left over. I think you can't go wrong using the 1/8th inch stainless to attach the butt ribs. If you can't find some in your kit let me know and I will mail you some.
AS must be a miss print, my manual says that too.
Tom Jones
Classic IV
Ellensburg, WA
roncarolnikko(at)hotmail.
PostPosted: Mon Jul 16, 2007 7:51 pm    Post subject: Mystery Rivets Reply with quote
I went to my local hardware store where they have a large assortment of
stainless rivets. Instant gratification and only a couple of bucks for a
pack. Ron NB Ore KF IV
Subject: Mystery Rivets
Date: Mon, 16 Jul 2007 18:39:43 -0700
for (typo?).
Thanks in advance,
Kent
Kent Knudsen
College Station, TX
http://forums.matronics.com/viewtopic.php?p=124229#124229
http://im.live.com/messenger/im/home/?source=hmtextlinkjuly07
l.morris(at)tx.rr.com
PostPosted: Tue Jul 17, 2007 7:25 am    Post subject: Mystery Rivets Reply with quote
I used p/n 95005--1/8x3/8 SS rivets.Don't use rivets from a hardware store. They arn't aircraft grade. Leon Morris/Classic 4/50%/Flower Mound,TX
Tom Jones
Classic IV, Phase one
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=124239#124239
kirkhull(at)kc.rr.com
PostPosted: Tue Jul 17, 2007 6:40 pm    Post subject: Mystery Rivets Reply with quote
Only a suggestion but I would never use hardware store hardware on any
aircraft. You do not know what you are getting. I have seen to many
airplanes crashed because parts were not as strong as they should have been.
It may be legal on a homebuilt but there is a reason it is not on a cert
airplane.
flier
PostPosted: Wed Jul 18, 2007 11:06 am    Post subject: Re: Mystery Rivets Reply with quote
Not sure I can figure out the failure mode that could cause a crash due to ANY kind of rivet being used to attach the butt ribs to the brackets?? Rolling Eyes
I wouldn't go switching out the SS rivets for the lift strut brackets on the spars but pretty much any rivet can be used successfully to secure lexan to the doors, etc. whether it's from Aircraft Spruce or the hardware store.
Ted
smokey_bear_40220(at)yaho
PostPosted: Wed Jul 18, 2007 12:37 pm    Post subject: Mystery Rivets Reply with quote
[Rolling Eyes]
the hardware store.
Ted
Sorry Ted. I have to disagree. There have been
several cases of the upper canopy section explosively
blowing up from failure of the butt rib caps letting
go.
There is a lot of lift over the top window augmented
by the prop blast. These butt ribs are as important
as any wing rib, but with you right underneath. If
one fails in any way, it will at least scare the heck
out of you and disrupt the airflow back to the tail.
Not good during a critical phase of flight.
I reinforced the butt rib caps on my plane due to the
advise and experience that came from this list and I
am very thankful for it. I wouldn't recommend risking
unknown rivits here either. These ribs are not
mounted to the spars like the others. All you have
are those rivets.
That is not to say that I don't have a lot of
"roadkill" on my plane, but I keep it in low risk
places. For example I used aluminum 1/4 inch bolts
instead of a steel ones to hold a one pound item in
place. The bolt fits the hole, but doesn't need to
carry 8000 lbs, so I went for light weight instead.
Save weight, but don't compromise strength.
By the way, the item was my master solenoid, since we
are on that subject.
Kurt Schrader
S-5/NSI turbo
Florida and Panama
Shape Yahoo! in your own image. Join our Network Research Panel today! http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
flier
PostPosted: Thu Jul 19, 2007 11:54 am    Post subject: Re: Mystery Rivets Reply with quote
I hear what you're saying Kurt but I'd challenge you to shear off a butt rib from the brackets when secured with regular mandrel standard rivets. You couldn't do it.
I'd more think it possible to peel the lexan up off the butt ribs than to shear the butt ribs off as the rivets holding the plastic down are in tension.
The beauty of homebuilts is that we all have the right to use our own intelligence to the extent we feel comfortable...
Ted
PostPosted: Thu Jul 19, 2007 12:21 pm    Post subject: Mystery Rivets Reply with quote
I would agree that on this installation you would be ok. The problem arises
when the left over rivets get mixed in with other aircraft parts and end up
getting used somewhere where they could cause a problem.
PostPosted: Thu Jul 19, 2007 12:41 pm    Post subject: Mystery Rivets Reply with quote
No problem at all Ted,
I wasn't trying make it an argument, but to keep us
thinking safety first. One of our school trained
safety folks here....
We already know of flapperon brackets pulling the
rivets thru the ribs too. And it isn't the rivets
failing in the canopys either. It is the cap strips
pulling free. Make it stronger, not weaker in my
opinion.
I am just a suspenders and belt guy.... Not inclined
to make substitutes in areas because I don't see how
they can fail. But I do if I clearly see that I've
got plenety of strength and no easy failure mode. Thus
light weight wins where strength is plenty. On the
other hand, I've added strength in some areas too.
Kurt Schrader
couldn't do it.
feel comfortable...
Ted
Be a better Heartthrob. Get better relationship answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545433
kentk
PostPosted: Fri Jul 20, 2007 6:46 pm    Post subject: Re: Mystery Rivets Reply with quote
Thank you everyone for the thoughts and comments! I am going to go with the #95004 1/8 x 1/4 SS rivets from the kit (the #95005 seem to be too long).
Kent
Kent Knudsen
College Station, TX
Float Flyr
PostPosted: Sat Jul 21, 2007 10:56 am    Post subject: Mystery Rivets Reply with quote
There should be around 1.5X the diameter of the rivet showing through the hole before the shop tail is formed. If there is more than that amount cut the rivet to the right length.
[img]cid:153364618(at)21072007-2FB3[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  779 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
