Craymondw(at)aol.com Guest
Posted: Mon Jul 16, 2007 8:24 am Post subject: Props |
EAA adviser, Joe Gauthier N2622(at)aol.com (N2622(at)aol.com) reported a 10 knot speed difference between props of Venture Aircraft.
A friend and I flew our Glasair 2's FT with 200 HP engines side by side and he pulls away with his McCauley prop. I average 210 MPH and he claims 220 mph. For further information, his name is Monte McClaine and he owns a KR, a Glasair 2 FT and a Glasair 111. He further humiliated me when we were flying side by side and reported he was pulling 19 inches to my 22 inches. When he aplied 22 inches he pulled right away from me. His address is Montemac(at)cox ([email]Montemac(at)cox[/email]). net. My Glasair is the 2S and is wider than the Glasair 2. Monte also uses an engine plenum and the combination of the two may account for the 10MPH speed difference.
Two other builders up on speed mods are Ken Johnson and Charlie Gray.
Get a sneak peak of the all-new AOL.com.
| | - The Matronics Glasair-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
AHPlowman(at)varicore.com Guest
Posted: Tue Jul 17, 2007 6:55 am Post subject: Props |
Gentlemen,
I am somewhat new to the list. I have a Glasair Super II S, FT with 180hp and the 68" Hartzell paddle blade CS prop. The best cruise I can get is about 175 mph and it doesn't seem to matter if I run at 75% or flat out, the speed doesn't improve much.
Have you ever heard of a 2-S FT that was that slow? Is it all in the prop? It has the factory pants and I can see gaps around the brake covers, etc but can it make that much difference?
Arnie Plowman 68DJ
145 Bytes |
9089 Time(s) |
Posted: Tue Jul 17, 2007 7:18 am Post subject: Props |
Glasair 2S FT that cruises (at) 175 mph. First I have to ask at what altitude. If you only get 175 mph at 8,000 feet, then something is wrong. First I would check to see if a twist was built into the wing. I would check wing angle of attack, check to see if your flaps are reflexed a few degrees, any flap drag will slow you way down, I would slightly reflex the alerons and if the wings appear unstable lower the flaps to a point where the plane is stable. Seal any gaps between control surfaces and any air that bleeds out of the flap wells, check engine off set, your induction and cooling inlets may be too large for that size engine, check to see if the main wheel pants are parallel to the centerline of the fuselage because you could have a built in wheel pant yaw that needs to be off set by the rudder and that will slow you way down.
s_korney(at)hotmail.com Guest
Posted: Tue Jul 17, 2007 8:39 am Post subject: Props |
Craymond...
I have a Glasair 1 retractable.... IO-320 hopped up.... Constant speed
Hartzell 72" prop... What top speed should I expect... WOT, 2700 rpm's, sea
level, standard day...?
Best... Steve
----Original Message Follows----
Reply-To: glasair-list(at)matronics.com
Subject: Props
Date: Mon, 16 Jul 2007 12:22:27 EDT
EAA adviser, Joe Gauthier _N2622(at)aol.com_ (mailto:N2622(at)aol.com) reported
220
a
flying
aplied 22 inches he pulled right away from me. His address is _Montemac(at)cox_
(mailto:Montemac(at)cox) . net. My Glasair is the 2S and is wider than the
Glasair
************************************** Get a sneak peak of the all-new AOL
at
http://discover.aol.com/memed/aolcom30tour
http://newlivehotmail.com
Posted: Tue Jul 17, 2007 12:08 pm Post subject: Props |
Steve,
I have had no experience what speed you should have with that configuration.
icovey(at)nc.rr.com Guest
Posted: Tue Jul 17, 2007 2:44 pm Post subject: Props |
What engine and propeller do you have on your Glasair?
Posted: Wed Jul 18, 2007 6:55 am Post subject: Props |
icovery,
IO360 200 hp Lyc and Hartzell
Posted: Thu Jul 19, 2007 1:14 am Post subject: Props |
Which Hartzell? The newer "blended airfoil?" The model recommended by Glasair? Other?
With respect to the G-III: Stoddard-Hamilton published a report of a comparison test of the recommended McCauley and Hartzell propellers. It was in the old factory newsletter. As I recall, there wasn't much difference in overallperformance. Better propellers are available today. Anyone have experience with the new composite props?
BJC
