propeller balance?
lcottrell
PostPosted: Sat Jul 14, 2007 10:38 am    Post subject: propeller balance? Reply with quote
Hi,
I am trying to get Possum's video camera to the point that I can use it, but vibration is killing me. Due to the enclosure I have to hard mount it to the frame up by the nose cone. I have it as solid as I can and braced as well. Even with the camera stabilization there is noticeable vibration. John H and John W helped me set my blade angle when they were here, but I painted the tip to get it ready for its Air worthy inspection. I suspected that I got a bit more paint on one tip than the other, so I rigged up this set up to balance it. Spraying paint on what appeared to be the lightest tip until it balanced out. Every thing was level as well. If my methods are correct then the vibration (still more there than I would like) is not going to go away. Blades were rechecked and are still right on for angle. The blades were set in varying positions and did not move from setting.
Larry C
[img]cid:002301c7c645(at)usermj5tjr71vq[/img][img]cid:002401c7c645(at)usermj5tjr71vq[/img]
 Filesize:  72.2 KB
 Viewed:  401 Time(s)
 Filesize:  74.73 KB
 Viewed:  401 Time(s)
Richard Pike
PostPosted: Sat Jul 14, 2007 11:48 am    Post subject: propeller balance? Reply with quote
I got some good movies from my Kolb, but used a non-solid mounting method. If I remember right, you have a Firestar? So maybe you can use this? If not, it was free...
If you have the hoop skid for underneath the nose cone like the MKIII does, you can use that, because that is what I used. I hose clamped about a 3' length of aluminum tubing to the nose hoop, kinda close to the fuselage, extending toward the front beyond the hoop. The hose clamps were twisted up, but it was still good and solid.
Then you take another slightly shorter piece of tubing and suspend it just below the first tube, ahead of the hoop, by hose clamping short lengths of bungee cord to each tube, so that the second is parallel to the first and just below it, supported by the bungees. Now you attach whatever you are using for a camera bracket to the lower tube. The camera is now vibration-free and hanging just ahead of the hoop. You want the tubes long enough to stabilize the camera so that it can't wig-wag or twist in the wind. I had to add a bit of nose up trim, but not bad.
It looks like the pits but it works. Just don't nose over on landing...
Richard Pike
MKIII N420P (420ldPoops)
 Filesize:  72.2 KB
 Viewed:  402 Time(s)
 Filesize:  74.73 KB
 Viewed:  404 Time(s)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
lcottrell
PostPosted: Sat Jul 14, 2007 12:44 pm    Post subject: propeller balance? Reply with quote
Thanks for the tip Mr Pike, but I don't have a hoop. Here is how I have it mounted on the plane. I think that without having it shock mounted I am going to get this vibration. Perhaps a three blade would be smoother, but I guess I will never know.
Larry
[img]cid:003901c7c657$82297d40(at)usermj5tjr71vq[/img]
 Filesize:  53.64 KB
 Viewed:  423 Time(s)
Thom Riddle
PostPosted: Sat Jul 14, 2007 3:27 pm    Post subject: Re: propeller balance? Reply with quote
I've had very good vibration free video by mounting the camera on a wing strut with 1" thick (before compression) foam rubber separating the mount and the strut. There are countless ways of doing the mounting but making the mount shock absorbing is the key.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
JRatcli256(at)aol.com
PostPosted: Sat Jul 14, 2007 5:30 pm    Post subject: propeller balance? Reply with quote
Gents,
Is it a requirement to paint the prop tips or just a safe thing to do?
John Ratcliffe
Get a sneak peak of the all-new AOL.com.
ElleryWeld(at)aol.com
PostPosted: Sun Jul 15, 2007 3:44 am    Post subject: propeller balance? Reply with quote
I have another design of a Prop balancer I built that is easy to build and works great I will get a pic of it and post it asap
Ellery N447EB
Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [quote][b]
possums(at)bellsouth.net
PostPosted: Sun Jul 15, 2007 5:40 pm    Post subject: propeller balance? Reply with quote
At 02:36 PM 7/14/2007, you wrote:
Hi,
I always had the same problem when I hard mounted it to the frame.
You could always duck tape it to your head or I've found - most of the
vibration goes away when you turn you engine off, albeit for a short while.
lcottrell
PostPosted: Sun Jul 15, 2007 8:25 pm    Post subject: propeller balance? Reply with quote
I have tried putting a bit of stiff foam under the camera, wind has been blowing too hard to make it fun, so I am biding my time waiting for a bit of calm. I have a Sony High 8 camera, so I had a lot of batterys that fit the camera. Most of them will last the Sony for as much as four hours. Man that thing eats batteries like candy. I had hoped that I would be able to smooth the plane out with balancing the prop. It is balanced but there is still enough vibration that it over powers the stabilization feature. I stuck the camera to the side of my headset, and got a great view of the hinge in the windscreen and the heater tube. I am a bit afraid that the duct tape would pull out my whiskers when I took it off. Smile Not only that, I find that I am a good pilot in that my head any eyes are scanning all over the place and I get a bit seasick when trying to watch the video.
Larry
jbhart(at)onlyinternet.ne
PostPosted: Mon Jul 16, 2007 3:25 am    Post subject: propeller balance? Reply with quote
...........I had hoped that I would be able to smooth the plane out with
Larry,
What you are seeing is the effect of torsional firing impulse on the air
frame. As the propeller moment of inertia increases it becomes more
difficult to speed or slow the propeller. The causes the firing impulse to
be transmitted back to the crank shaft, to the crank case, mounts and
finally to the air frame. If you wish to see less vibration, mount a
lighter lower inertia propeller.
You may be able to fool the camera by changing vibration frequency. Reduce
engine speed and at some speed the stabilizer should be able to keep up.
Just hope that it is a sustainable flight engine speed.
Jack B. Hart FF004
Winchester, IN
by0ung(at)brigham.net
PostPosted: Mon Jul 16, 2007 1:16 pm    Post subject: propeller balance? Reply with quote
I had a friend that was going to build a model helo blade balancer….. it was to consist of an accelerometer and a processor that would take all the guess work out of balancing the prop…. I found when balancing a helo blade…. You could static balance it like you did in the photo…. But when it was spinning up to speed it still needed some fine tuning… I used a wrap of electrical tape at the mid blade ( the cg of the blade) and tried it to see if it was worse or better…. Then adjusted it from there… either more or less tape on that blade or the other…. I will try and see if my friend built something he could market or sell me and find out how much $$$
Boyd
