Is anyone using this 2-cycle oil?
R. Hankins
PostPosted: Fri Jul 13, 2007 11:24 pm    Post subject: Is anyone using this 2-cycle oil? Reply with quote
Hello all:
I'm having difficulty getting Pennzoil air-colled 2-C oil locally. This product seems to be similar. Is anyone using this oil? It is priced very similarly to Pennzoil and soulds like it would meet Rotax specs. Any thoughts? Here is a link to the info:
http://www.76lubricants.com/NR/rdonlyres/88A1712C-5E21-4311-8039-AC01D27B3C4C/0/76_Airkool_HP_2Cycle_Oil.pdf
Roger in Oregon
1992 KXP 503 - N1782C
aoldman(at)xtra.co.nz
PostPosted: Sat Jul 14, 2007 2:36 am    Post subject: Is anyone using this 2-cycle oil? Reply with quote
When it comes to asking opinions on oil to use, you open a whole can of
worms.Ask 10 people get 10 different opinions. I have always used castrol TT
or its replacement Castrol super. I have put up over 500 hours on two
different 503s without having a bearing fail. One of the engines did stick
the top ring but was easily freed up.Cylinders have not been scuffed.After
freeing the top ring this engine was still in-service at 800 hrs. There are
a lot of people using Pennzoil in this part of the world but I personally
have seen no evidence that they out last any other oils. I have seen engines
with stuck rings and others ,mostly early 582s with run bearings that have
been on Pennzoil.Also 582s with run bearings on almost any type of oil
that's available.The other thing to look at is the price you pay for some of
these oils, if you are going to rebuild your engine at say 500 hours the
extra cost of some oils will have exceeded the cost of the rebuild. I think
its a personal choice thing if you believe one oil is giving you better
protection than another then stay with it. Who can put a price on piece of
mind when in a steep climb with a passenger over some unfriendly country
just after take off.
If the replacement oil meets the specs and you are happy to fly with it then
I see no reason that it will not perform as well ,just keep an eye on the
CHT and EXT temps if these are different than what you are used to {
higher } then I would change back.
Just my $00:02 worth
Tony
from down under MK111 classic
lucien
PostPosted: Sat Jul 14, 2007 2:47 am    Post subject: Re: Is anyone using this 2-cycle oil? Reply with quote
Well, I'll say what I always say about 2-stroke oil.... The brand isn't that important, the important thing is the service grade.
Rotax now recommends the API TC spec oil be used in the 2-strokes. Before there was a TC spec, though, they recommended TCW-III grade oil.
Both of these oil grades will lubricate a 2-stroke, though the TC rating is more strenuous.
The original owner of my FS II used the Walmart marine oil in that 503, which went more than 500 hours. the motor was still developing full power and ran fine at the time I took it off (I only replaced it becuase it was rotting away).
I use the air cooled pennzoil too, but I have the save availability problems as you and will likely switch to the locally available TCW-III oil when I finish this last case of pennzoil I have....
LS
LS
Titan II SS
planecrazzzy
PostPosted: Sat Jul 14, 2007 3:34 am    Post subject: Re: Is anyone using this 2-cycle oil? Reply with quote
I was going to use Koltz , but after seeing the trouble it was going to be just trying to buy it.....it made me realize that if I'm flying X country ,
what would be an oil that I could find....
I heard stories like this one , So I figured that would be the one I use...
Seems to be doing just fine , although I'm "low hours"
It probably helps that I've got oil injection....Thinner at idle...
Gotta Fly...
Mike & "Jaz" in MN
Getting ready for another X country next weekend....Going to a
"Tailwind" Fly-in....Thinking about changing plans & building a Buttercup.
(40mph stall - 140mph cruise)
LS
 Filesize:  60.64 KB
 Viewed:  536 Time(s)
herbgh
PostPosted: Sat Jul 14, 2007 4:01 am    Post subject: Is anyone using this 2-cycle oil? Reply with quote
Roger
Stick your zip code in the box...Herb
http://www.pennzoil.com/products/outdoor/2cycle_aircooled.html
On Sat, 14 Jul 2007 00:24:45 -0700 "R. Hankins" <rphanks(at)grantspass.com>
writes:
Hello all:
Roger in Oregon
1992 KXP 503
http://forums.matronics.com/viewtopic.php?p=123738#123738
jbhart(at)onlyinternet.ne
PostPosted: Sat Jul 14, 2007 4:39 am    Post subject: Is anyone using this 2-cycle oil? Reply with quote
At 06:59 AM 7/14/07 -0500, you wrote:
Roger
Better yet:
http://oilstore.stores.yahoo.net/penaircool2c.html
And they will deliver it right to your door.
Jack B. Hart FF004
Winchester, IN
herbgh
PostPosted: Sat Jul 14, 2007 4:57 am    Post subject: Is anyone using this 2-cycle oil? Reply with quote
Jack
I just received abt 30 lbs of goodies from Aircraft Spruce..
Atlanta,,,and I am in Extreme south cent Ky... over 40 dollars shipping
with UPS..
Wondering what the shipping would be on a case of Penzoil ? Herb
On Sat, 14 Jul 2007 08:24:44 -0500 "Jack B. Hart"
<jbhart(at)onlyinternet.net> writes:
>Roger
Better yet:
Jack B. Hart FF004
Winchester, IN
rowedenny(at)windstream.n
PostPosted: Sat Jul 14, 2007 5:57 am    Post subject: Is anyone using this 2-cycle oil? Reply with quote
Thay oil will be fine for your Rotax.
Denny Rowe
Mk-3 PA
Richard Pike
PostPosted: Sat Jul 14, 2007 9:17 am    Post subject: Is anyone using this 2-cycle oil? Reply with quote
Pennzoil seesm to tbe the universal standard oil for Rotax engines, however,
there remains a small pocket of resistance in Northeast Tennessee which has
been using Phillips Injex since 1983 with no failures yet. (Probably close
to 3,000 hours of Rotax/Phillips Injex time) So if you can't find Pennzoil,
and Phillips is available, you might want to try it -
PS - it doesn't leave as greasy a soot as Pennzoil does, for what that's
worth -
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Ralph B
PostPosted: Sun Jul 15, 2007 8:23 am    Post subject: Re: Is anyone using this 2-cycle oil? Reply with quote
No no Richard, it's Klotz synthetic is the oil of choice for the Rotax 2-stroke. There's very little wear with this oil and it's super clean inside and on the plugs.
Ralph B
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
Richard Pike
PostPosted: Sun Jul 15, 2007 12:40 pm    Post subject: Is anyone using this 2-cycle oil? Reply with quote
I'm not that rich. Went to the Klotz webpage, and the cheapest Klotz 2-cycle
oil I could find was $11.41 a quart. So unless you have some inside
connection, I think I'll stay with Phillips Injex at $2.36 a quart, thanks
anyway. And that's delivered to my door, if you buy a case at a time, the
local distributor delivers it for free.
Richard Pike
Richard Pike
Kingsport, TN 3TN0
Ralph B
PostPosted: Sun Jul 15, 2007 5:32 pm    Post subject: Re: Is anyone using this 2-cycle oil? Reply with quote
Klotz and all oils are getting expensive like gasoline. I buy the Klotz in bulk from the local dealer for $22/gallon and it lasts a long time.
Ralph B
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
