Vanremog(at)aol.com Guest
Posted: Tue Jul 10, 2007 7:34 pm Post subject: VM1000 fuel pressure sender (carbureted) |
VMS sent me the new Honeywell sender (with the collective plug) and I would like to confirm the function of the four numbered terminals. VMS sent me no info on this and have not returned my call. My original sender had four discrete quick disconnect tabs that were individually wired as:
SENDER pin 1 WHT TO DPU J3.5
SENDER.pin 2 BLK TO DPU J3.8
SENDER.pin 3 GRN TO DPU J3.6
SENDER.pin 4 RED TO DPU J3.7
Can anyone with the P/N 3010016 sender (with the collective plug) and the VM1000 (not the VM1000C) confirm that the new sender has the same pin correspondence and hooks up pin for pin the same way?
If it is not the same, please advise.
-Thx
GV (RV-6A N1GV O-360-A1A, C/S, Flying 859hrs, Silicon Valley, CA)
See what's free at AOL.com.
n616tb(at)btsapps.com Guest
Posted: Wed Jul 11, 2007 4:37 am Post subject: VM1000 fuel pressure sender (carbureted) |
My VM system has a 37 pin DB connector which contains the fuel pressure as such:
Pin 34 – Black
Pin 35 – Red
Pin 36 – Green
Pin 37 – White
On the sender itself, the cap when you take it apart has numbers on the pins. They go like this
Pin 1 – White
Pin 2 – Black
Pin 3 – Green
Pin 4 – Red
From the looks of your post, it appears you have a different type connection to the DPU. I will see if I can send you some pictures from my manual today after I scan them. Maybe it will help, maybe not. Where are you located?
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com
Sent: Tuesday, July 10, 2007 10:32 PM
To: rv-list(at)matronics.com
Subject: Re: VM1000 fuel pressure sender (carbureted)
-Thx
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
Posted: Wed Jul 11, 2007 7:48 am Post subject: VM1000 fuel pressure sender (carbureted) |
In a message dated 7/11/2007 5:39:03 A.M. Pacific Daylight Time, n616tb(at)btsapps.com writes:
From the looks of your post, it appears you have a different type connection to the DPU. I will see if I can send you some pictures from my manual today after I scan them. Maybe it will help, maybe not. Where are you located? |
Tim-
Thanks. I'm in the SF Bay area.
