701 engine weight
JerryHey
PostPosted: Mon Jul 09, 2007 4:33 pm    Post subject: 701 engine weight Reply with quote
The 701 is restricted by CH to 200 lbs engine weight and 100 hp. My
question is what is included in the engine weight? Is it everything
firewall forward? Is it wet? and so on. Thanks Jerry
jetboy
PostPosted: Wed Jul 11, 2007 12:31 am    Post subject: Re: 701 engine weight Reply with quote
Its listed in my plans as 'powerplant installed weight' and I feel that would mean to include all coolant / oil, accessories. fuel pumps, propellor and engine mount system.
I feel the limit is at an appropriate level, I have 880 lbs empty wt (including unuseable fuel and radio / transponder) and the handling becomes noticably different when operating close to full gross.
Ralph
Ralph - CH701 / 2200a
John Bolding
PostPosted: Wed Jul 11, 2007 2:59 am    Post subject: 701 engine weight Reply with quote
Ralph, is 880# a misprint?? 660# maybe? John
Ralph
arno7452(at)bellsouth.net
PostPosted: Wed Jul 11, 2007 4:16 am    Post subject: 701 engine weight Reply with quote
Listers,
I am building a 701 and was hopeful that EW would be close to Zenith's estimate. With 1100# GW, an EW of less than 600# is good target.
What EWs have others achieved?
Ken Arnold
CH701 912ULS 80%
NYTerminat(at)AOL.COM
PostPosted: Wed Jul 11, 2007 6:24 am    Post subject: 701 engine weight Reply with quote
I thought mine was loaded and heavy at 703 lbs. Bob
In a message dated 7/11/2007 7:00:43 A.M. Eastern Daylight Time, jnbolding1(at)teleshare.net writes:
Ralph
See what's free at AOL.com.
WClagg
PostPosted: Wed Jul 11, 2007 7:34 am    Post subject: 701 engine weight Reply with quote
I would be interested in knowing the empty weight and equipment list of several of the 701s flying also. I have mine on the gear and I am about ready to install the wings. I might want to rethink my panel and other stuff as I am just starting on the systems. Anyone else have any input?
Richard Clagg
701 plans built
Wayne Clagg
kissell
PostPosted: Wed Jul 11, 2007 5:47 pm    Post subject: 701 engine weight Reply with quote
Hi,
I just completed my CH701SP this month. Inspection by FAA will take place next Monday. But back to your question, my 701 weighs in at 596 lbs empty. It has a nice panel and is painted. The CG is good with full fuel (20 gal.) and two 180 lb. people but can only carry about 18 lbs of baggage without going over gross weight. My aircraft was constructed from a full up Zenith kit with the Rotax 912ULS and WarpDrive prop.
Bob Kissell
Beavercreek, Ohio N701UB
kissell
PostPosted: Wed Jul 11, 2007 5:56 pm    Post subject: 701 engine weight Reply with quote
Hey Ralph,
If your 701 is really at 880 lbs empty then you only have 1100 -880 -> 220
lbs for you and fuel by my figuring. Thats not much to work with. I am
interested in what has added so much weight. The Zenith empty weight per the
drawing is about 580 lbs. with a Rotax engine. What powerplant and prop do
you have on your bird?
regards,
Bob N701UB CH701SP
WClagg
PostPosted: Wed Jul 11, 2007 6:29 pm    Post subject: 701 engine weight Reply with quote
Bob,
Thanks for the reply, I like the sound of that weight better. Planning on a nice panel myself with electric flaps etc. Does anyone know the difference between the earlier two notch flap settings and the current single setup on the 701? Is there a structural change in the flaperon control or just elimination of the second notch for sport pilot reasons? Any help is greatly appreciated. I emailed Zenith but have not heard back and its been a couple of weeks.
See everyone at OSH?
Richard Clagg
Milton Wv. Ona Airpark, 12V
701 plans building
Get a sneak peak of the all-new AOL.com.
Wayne Clagg
jetboy
PostPosted: Wed Jul 11, 2007 9:40 pm    Post subject: Re: 701 engine weight Reply with quote
Apologies all, I read the empty weigt wrongly it was 267.5 KG which is around 590 lbs. - much more like it
Ralph
WClagg
PostPosted: Thu Jul 12, 2007 3:03 am    Post subject: 701 engine weight Reply with quote
Whew, I was worried about that!
R. Clagg
Wayne Clagg
