agustafson(at)chartermi.n Guest
Posted: Fri Jul 06, 2007 3:59 pm Post subject: 0-200 oil temp |
I'm looking for some help on my freshly ringed 0-200. The oil temp climbs slowly beyond 200 degrees. This is especially true when the outside temps are greater than 75 and when the RPMs are over 1800. There is 15 hours on the engine since new rings and crank, 220 SMOH. The CHT during climbout goes to 400 or slightly higher and comes down to 325-350 at 1800 RPM. I have Phillips 20W50 oil now, having run straight mineral oil for 7 hours (the oil pressure was a little low with the 30 weight oil but now is good). I opened up the front inlets openings(this brought the CHTs down but not the oil temp), Installed a 'Cool Collar' (w/ fresh air duct on the filter) ,which helped a little, Removed my bottom cowl flap completely, which helped a little again, and added a scoop to bring fresh air onto the sump, again this helped a little. But in 80 degree weather above 1800 it still climbs over 200. My question is, Do I add an oil cooler now or hope that break-in will bring temps down enough that I don't need a cooler. The engine is installed in a Zenair 601. I had been told that I should not need a cooler by numerous people. I have checked the gauge and it is accurate. Anybody have any advise?
Aaron Gustafson
| - The Matronics Continental-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Continental-List |
shoskins(at)mchsi.com Guest
Posted: Fri Jul 06, 2007 7:34 pm Post subject: 0-200 oil temp |
BAFFLING, BAFFLING, BAFFLING.
Get your baffling right and your oil temp problems will go away.
You can read what I did here: http://samhoskins.blogspot.com/2005/10/baffling-evolution.html
Sam Hoskins
Murphysboro, IL
On 7/6/07, Aaron Gustafson <agustafson(at)chartermi.net (agustafson(at)chartermi.net)> wrote: [quote] I'm looking for some help on my freshly ringed 0-200. The oil temp climbs slowly beyond 200 degrees. This is especially true when the outside temps are greater than 75 and when the RPMs are over 1800. There is 15 hours on the engine since new rings and crank, 220 SMOH. The CHT during climbout goes to 400 or slightly higher and comes down to 325-350 at 1800 RPM. I have Phillips 20W50 oil now, having run straight mineral oil for 7 hours (the oil pressure was a little low with the 30 weight oil but now is good). I opened up the front inlets openings(this brought the CHTs down but not the oil temp), Installed a 'Cool Collar' (w/ fresh air duct on the filter) ,which helped a little, Removed my bottom cowl flap completely, which helped a little again, and added a scoop to bring fresh air onto the sump, again this helped a little. But in 80 degree weather above 1800 it still climbs over 200. My question is, Do I add an oil cooler now or hope that break-in will bring temps down enough that I don't need a cooler. The engine is installed in a Zenair 601. I had been told that I should not need a cooler by numerous people. I have checked the gauge and it is accurate. Anybody have any advise?
Aaron Gustafson
[quote][b] http://www.matronics.com/Navigator?Continental-List http://forums.matronics.com
www.MistakeProofing.net/blog/
618-967-0016 ph.
312-212-4086 fax [quote][b]
Posted: Sat Jul 07, 2007 8:17 am Post subject: 0-200 oil temp |
I just discovered this morning that I do not have the baffles that run along the bottom of the case halves. I did not know that there were any, but looking at another 0-200 installation, I noticed them. I will try this next. I do not want to add an oil cooler. My upper baffles are close fitting and sealed well.
Aaron G.
Posted: Sat Jul 07, 2007 11:52 am Post subject: 0-200 oil temp |
In my experience that trough didn't do to much.
Sam
On 7/7/07, Aaron Gustafson <agustafson(at)chartermi.net (agustafson(at)chartermi.net)> wrote:[quote] I just discovered this morning that I do not have the baffles that run along the bottom of the case halves. I did not know that there were any, but looking at another 0-200 installation, I noticed them. I will try this next. I do not want to add an oil cooler. My upper baffles are close fitting and sealed well.
Aaron G.
618-967-0016 ph.
waltdak(at)verizon.net Guest
Posted: Sat Jul 07, 2007 12:18 pm Post subject: 0-200 oil temp |
Aaron,
With my A-65, that I rebuilt under the eye of my AP mentor, recommended an oil that we use in work. "Terressic #68" which is a pure mineral oil with viscosity of 20. He had me run that quite a number of hours. Then went to the multi vis aircraft oil. I have eyebrows with no lower baffleing, including no "gull wing" baffle under the gap between the cyl. bottoms.
My oil temp guage starts at 120 or 140, And only twice in 75 hours of flying has it came off the lower stop.
Did you break the glaze nicely on the cylinders? If not, you'll get heat , and the engine will always use oil. I rarely add oil
Walt Evans
NX140DL
"No one ever learned anything by talking"
Posted: Sun Jul 08, 2007 2:59 am Post subject: 0-200 oil temp |
Walt
I am using no oil to speak of. Yes the cylinders were deglazed and I do have the intercylinder baffles(both top and bottom). CHT is not a problem. I had 30 viscosity(Aeroshell #65) mineral oil in it but the pressure would drop as it warmed up. That is why I changed to the heavier oil and the pressure came up nicely. I put in the lower baffles(trough) yesterday and two 1 1/2" holes in the cowl to feed them, so will test that as soon as the thunderstorms depart the area. Thanks.
Aaron
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
